Old 06-27-2006, 09:21 AM   #4456
rc-zombies's Avatar
just remember Hara insert come in 2 types:
Version 1: thicker great for permenant high traction tracks.
Version 2: thinner good for parking lot tracks or low traction
3 compounds.. soft. med. and firm.
Old 06-27-2006, 01:06 PM   #4457
gijoe64's Avatar
Trader Rating: 30 (100%+)
Ok guys I need your help, I have been looking at the Cyclone for awhile and I was so put off by the Pro4 when I had one it carried over to this car because the HPI is apart of Hotbodies. I keep hearing that this is probley the best rubber tire car out their next to the 415 Refine, how true is this statement? Should I buy this car? because in the mid west I have yet to see anyone use the Cyclone in rubber carpet racing or asphalt, could someone please set me straight
gijoe64 is offline   Reply With Quote
Old 06-27-2006, 01:35 PM   #4458
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Im probably not a good reference for the car, cause my past cars were all losi for the most part. But, ive had the car for 3 race weekends and like it pretty well. It reacts well to setup changes, pretty easy to work on, durable too. Only issues I have had were operator error and fixed easily once I pulled my head out of my rear. I bought it cause... it shares a bunch of pro4 parts which made finding spare pretty easy, didnt want an xray or schuie. It is a lil pricy but it comes with the goodies in the box... the special edition car that is... It comes with a full sway bar setup, one way, spool, both locked and one way pulleys, all the blue or purple goodies depending on which kit, etc. I have just really been impressed.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 06-28-2006, 03:06 PM   #4459
stegger's Avatar
Does anybody know if the Pro4 purple alloy Shock Spring Adjust Nuts fit the cyclone shock bodies??? The original ones move to easily.
stegger is offline   Reply With Quote
Old 06-28-2006, 03:10 PM   #4460
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Yes they do
SchuMi2 is offline   Reply With Quote
Old 06-28-2006, 03:25 PM   #4461
rc-zombies's Avatar
most racers have swapped out the original with the Pro4's.
and there are some that put a drop of blue locktite that will keep it in place.
Old 06-28-2006, 03:50 PM   #4462
hi all,
Just about to run my surikarn car, was wonderin how well the front drive shafts hold up, as i know the original cyclone had problems with bending. any solutions if they do bend easy other then the obvious TIR.
Cheers
Xrayskid is offline   Reply With Quote
Old 06-28-2006, 03:54 PM   #4463
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by Xrayskid
hi all,
Cheers
change them for the steel driveshafts from hotbodies and you wont have any problems
Old 06-28-2006, 03:58 PM   #4464
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
hi all,
Cheers
I have had my Hara cyclone now for about 2 months and have used both a one-way and a spool and there have been no signs of the cvd shafts bending, twisting or wearing.
Spool = 30 runs (mod and 19t)
I have been using the Tamiya Anti-wear grease on all drive train parts (cvds, outdrives, blades)
And to my surprise, and relief, running the spool doesn't seem to wear the outdrives or the cvd shafts (ends or pins).
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 06-28-2006, 04:00 PM   #4465
At this stage, I think the v.2 shafts are holding up very nicely. Much better than the first versions.
Old 06-28-2006, 05:29 PM   #4466
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Hello Racers! I should get my Cyclone later this week. I would like your help for a good stock rubber carpet set up. I will be racing the Summer Sizzler at S&N Trackside on the 16th. Traction will be medium to medium high. Any help is appreciated.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 06-29-2006, 01:12 AM   #4467
does any one know if the following part fits the cyclone?
Tamiya TRF Damper Titanium Coated Piston Rod (2pcs)
Cheers
Old 06-29-2006, 06:27 AM   #4468
dizzy1's Avatar
Trader Rating: 24 (100%+)
stegger-unscrew the included threaded spring collar, use your hot solder iron to make a small melt line across the threads, only a little will do. After that they are perfect and you can't see it once its done.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 06-29-2006, 07:39 AM   #4469
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
or you can put a tiny dab of silicone in the threads....TINY
floodo1 is offline   Reply With Quote
Old 06-29-2006, 08:13 AM   #4470
rc-zombies's Avatar
Cheers
if it's 3mmx28mm...it should fit...
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
