Old 06-14-2006, 03:30 AM   #4321
Dan415ms's Avatar
Any suggestions for a good spool and driveshafts for the cyclone in modified?
I ran mine in open modified at the Scottish GP with a Novak 4.5r brushless system and after 2 or 3 runs the standard steel spool was worn away and I threw it away. Also, both front driveshafts were bent, like really bent - they looked like the curvature of the sydney harbour bridge!! The TiR thick titanium driveshafts look decent? I heard that HB are making thicker ones too? Maybe a spool with replaceable delrin outdrives would be the way forward?
Also, I run permanent 4WD so I bought the fixed centre layshaft and use a 16 tooth solid pulley from a 415 as it fits nicely....only thing is, there's now gaps between the pulleys and the spur gear holder, is that normal?
Thanks,
Dan
www.sdrcc.co.uk
Dan415ms is offline   Reply With Quote
Old 06-14-2006, 05:39 AM   #4322
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
The steel front dogbones are a must if you are the kind of person who hits things. What you can do is:
Get the Tamiya 44MM steel dogbones, get some corally driveshaft blade protector things, and file, mill dremel the slots on the spool out so the driveshaft blade protector things fit in them. You will just have to replace the blades alot.
dontfeelcold is offline   Reply With Quote
Old 06-14-2006, 05:56 AM   #4323
Dan415ms's Avatar
I try not to be!
Cheers, I have some 44mm tamiya dogbones in my pitbox I believe.
Dan
Old 06-14-2006, 07:48 AM   #4324
rc-zombies's Avatar
what are the part # for the 44mm steel dogbones?
All I was able to find are 42mm ones...
Old 06-14-2006, 07:49 AM   #4325
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Thanks,
Dan
www.sdrcc.co.uk
dont get the spool with the delrin outdrives, I had them on my pro 4 and running the 4.5 motor i keep tearing them up, with my Cyclone my good friend Jason (BMI) machined a awesome front spool for my Cyclone ,and along with the HotBodies steel axles the front end is almost bulletproof. I ran it a bout 8 races and no sign of wear.
Old 06-14-2006, 09:05 AM   #4326
wagonman72's Avatar
Part number 61398.
wagonman72 is offline   Reply With Quote
Old 06-14-2006, 09:51 AM   #4327
Ballsie's Avatar
Thanks,
Dan
www.sdrcc.co.uk
Dan - your best bet is to get the spool from the hara cyclone and set of the hardened front drive shafts from HB. I've got a set on mine on the car that I had ready for the GP. I think all the new style driveshafts (with the grove on the middle of the shaft to seperate them from the old version) are aluminium. The HB ones that I'm using are steel - just like the one for the 415.
Ballsie is offline   Reply With Quote
Old 06-14-2006, 09:56 AM   #4328
Ballsie's Avatar
This is a good read - http://www.hbeurope.com/news/en/2006050401.html
You need the new HD ones if your running the new one-way, but my car appears to work fine with the old HD ones with the new spool.
Mirage have the new HD's in stock btw.
Old 06-14-2006, 10:10 AM   #4329
Ballsie's Avatar
I've noticed something really weird in the Reedy Race pics on the HB website.
Why does Hara's car in the top right of the picture have a Marc Rheinard name sticker on the back window?
Answers on a post card please!
Old 06-14-2006, 10:13 AM   #4330
Ballsie's Avatar
Originally Posted by wagonman72
Part number 61398.
That's an HB part number.
Tamiya don't do dogbones in 44mm, only 42, 46 and 48.
Old 06-14-2006, 10:23 AM   #4331
Dan415ms's Avatar
Cheers Ballsie
I must have some 46mm's then.....
Old 06-14-2006, 10:23 AM   #4332
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
it may be psychology effect to Marc "smell no smoke"
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-14-2006, 10:26 AM   #4333
Dan415ms's Avatar
Is it definately Hara's shell - looks like there's someone elses underneath.....just cos it has a hara sticker and it's black can we assume it's his shell? Marc uses the Twister ESC remember.....although the checkpoint sticker points towards hara I agree....
D
Old 06-14-2006, 10:42 AM   #4334
does anyone know what kind of soldering iron hara uses
HEWITT is offline   Reply With Quote
Old 06-14-2006, 10:47 AM   #4335
rc-zombies's Avatar
Hara used the same body at last weekend Nats..
during the finals..Mark's name was no longer there.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
