Old 06-07-2006, 01:20 AM   #4261
Skill's Avatar
Originally Posted by tomislav
Hi,
what parts do i need to convert standard one way central pulley on cyclone(black standard version) for spool on front? I have the spool but i need constant drive on central pulley but dont know the parts that i need for conversion.
You just need another solid pulley like you have for the rear of the car as you should already have the layshaft to fit it on (comes in the kit).
Skill is offline   Reply With Quote
Old 06-07-2006, 01:26 AM   #4262
wagonman72's Avatar
Steve should have all of the blue stuff and the purple stuff within the next couple of days. I suggest you call him in the morning or order tonite.
wagonman72 is offline   Reply With Quote
Old 06-07-2006, 03:43 PM   #4263
rc-zombies's Avatar
from LiveRC.com
As usual..Hara is setting the pace at the Nats. @ 14.434 sec.lap.
even though it's just controlled practice today..and will probably get faster soon as qualifying starts on Friday.
Old 06-07-2006, 07:42 PM   #4264
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by rc-zombies
at Speedworld track..
it's ballistic at around 5.6FDR.. +/-
with the atlas brushes and stock springs. next time will try with the infinity brushes and the harder springs.
just wish my driving was a little better though... those boards keep getting in my way.
Stupid boards always making us look bad! Thanks for the help.
RayWarner is offline   Reply With Quote
Old 06-08-2006, 01:34 PM   #4265
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
How much droop would you recommend to start with on a medium bite asphalt track?
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 06-08-2006, 01:36 PM   #4266
rc-zombies's Avatar
first you'll have to change your name to lawtoncyclone..
try 6mm f/r
Old 06-08-2006, 01:49 PM   #4267
Na I still drive the losi offroad stuff :P
That has been my identity since 98 lol.
I do need to update my avatar one of these days though.
Maclin | VP-Pro USA
Old 06-11-2006, 02:06 PM   #4268
tim fry's Avatar
Has anyone had any problems with their driveshaft pins moving even with the grub screw tight and locktighted?
tim fry is offline   Reply With Quote
Old 06-11-2006, 02:17 PM   #4269
protc3's Avatar
yeah,i think the barrels are not threaded deep enough.i disassembeled the cvd and removed the pin.then i ran the set screw into the barrel until it looked deep enough and then reassembled the cvd with some lock tight.this seemed to work
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-11-2006, 08:09 PM   #4270
Yeh I had the same problem...used Tamyia threadlock and had no more problems.I also found the Alloy dogboes at the front wearing out very quickly were the pin goes thru and goes into the cup on each side(hope this is clear enough)causing a lot of slop in the front driveshafts(I only run stock)Is there a steel dogone avaliable for the Hara yet?
Barger is offline   Reply With Quote
Old 06-11-2006, 08:55 PM   #4271
rc-zombies's Avatar
congrats to Hara
2006 Roar Mod champion...
Old 06-11-2006, 09:17 PM   #4272
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
congrats to Hara
great...my idol
but where to get the full result & review?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-11-2006, 09:19 PM   #4273
jfc_tech's Avatar
ok, sorry, i got it. up there!
Old 06-12-2006, 12:25 AM   #4274
XrayFK's Avatar
Went to some shops in Akihabara on Saturday, saw some new parts. They now sell a complete ball diff set for 3780yen, there are also the new aluminum diff outdrives for 2757yen and solid anodized spools for 1575yen. And for 3192yen you can get the Square middle bulkhead that is straight over the cells instead of curved. Of course, all the original cyclone parts are now available in blue, like pivot blocks.
XrayFK is offline   Reply With Quote
Old 06-12-2006, 02:51 AM   #4275
diesel's Avatar
Hiya, does anyone know what are the brands of anti-wear grease, bearing lube and shock slime hara's using in his step-by-step building guide of the cyclone?
Here is the translated reference:
http://translate.google.com/translat...lr%3D%26sa%3DG
diesel is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
