Old 06-05-2006, 05:04 AM   #4231
Stew Noble's Avatar
Originally Posted by stegger
Am i right in thinking that the moorespeed shells arn't BRCA legal until 1st july in the UK?
yep
// S N F //
Stew Noble is offline   Reply With Quote
Old 06-05-2006, 09:55 AM   #4232
wagonman72's Avatar
OK guys here's the part numbers I promised.
61396 – Aluminum Drive Shaft Ver.2 (1pc) Black
61397 – Front One-Way Cup Joint Ver.2 (2pcs) Black
61398 – 44mm HD Universal Drive Shaft Ver.2 (Front/2pcs) Black
wagonman72 is offline   Reply With Quote
Old 06-05-2006, 12:05 PM   #4233
Originally Posted by Antonio Sabato
I got an observation for ya….Leave your propaganda BS off our forum.
wow i have not seen any propaganda at all.
i really think people should eighter read english dictionary or shut up.
jeoulousy?were has he been jeoilouse
propaganda?show me proof of that?
i think you lot are so up hot bodies a''es that you dont like anything said towards them.
all dale was saying is i wander why andy diont take his own range of shells.
wow,u guys need to chill.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 06-05-2006, 12:19 PM   #4234
rc-zombies's Avatar
Originally Posted by Andrew_Carter
Whos tried the rear alloy top deck then?
Any diffrence? Or is it just helping to keep the motor cooler?
Everyones OPINIONS are welcome!
I just recieved mine today... I don't think it will drastically reduce the motor temp. a clip on heatsink will probably do a better job in cooling the motor since it covers more surface area on the motor.
I just bought it just to have one... having more purple increase your speed by .0001mph...
after installing the new brace...you can use the old brace and bolt it on the side of the chassis by the motor and use it as a motor guard...similar to what is made for the T2.
Old 06-05-2006, 03:42 PM   #4235
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by N4S
Hey jason , whats the BMI part # for that brace ?????
Sean ,! I see you got a Cyclone
Old 06-05-2006, 04:11 PM   #4236
N4S
N4S's Avatar
Yeah , Couldn't resist............................ So far I like it .
N4S is offline   Reply With Quote
Old 06-05-2006, 04:14 PM   #4237
Super Moderator
Marcos.J's Avatar
i knew you would
Old 06-05-2006, 04:15 PM   #4238
rc-zombies's Avatar
A few racers from our local track have switched from the RDX or T2 to the Hara or Surikarn Edition...
Their track times have drastically improved.
Old 06-05-2006, 07:50 PM   #4239
Trader Rating: 16 (94%+)
i am still having no luck finding a uk store with the moorespeed mazda6 bodies, both microtech and apex have no stock, are there any others worth trying??
domo is offline   Reply With Quote
Old 06-05-2006, 08:18 PM   #4240
Trader Rating: 237 (99%+)
Ok guys....whats the cure for the broken diff screw and better thrust bearing?
Part #'s too if you have them.
Thanks!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 06-05-2006, 08:19 PM   #4241
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I havent broke the stock one, but put an associated diff screw and nut in mine. It appears to be beefier. Thrust bearing, I would like to find a captured one if it exsists.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 06-05-2006, 11:24 PM   #4242
rc-zombies's Avatar
the AE diff screw and nut works perfect...but for the cyclone
it will work too .... but you won't be able to adjust the nut from the 2 external holes... you'll have to take the cv out to tighten. the AE screw used a 2mm hex.
Old 06-05-2006, 11:26 PM   #4243
rc-zombies's Avatar
well... here's what I did with the CF mid brace:
motor guard and fan mount..
the paper clamp is temporary..til I drill a couple of countersunk holes..
Old 06-05-2006, 11:34 PM   #4244
rc-zombies's Avatar
There's a variety of clip on motor heatsinks out there..
but majority of them the fins go perpendicular with the chassis...
Wagonman...
something you may want to suggest to HPI/HB R&D dept.
a heatsink with fins that parallel the chassis for better cooling..that goes with the air flow through the chassis.. something similar to the one pictured on my car... made by TOP for the old Yok original belt TC....
unfortunately it doesn't fit the cyclone...
Looks good though...
Old 06-05-2006, 11:40 PM   #4245
ngo8's Avatar
Send a message via ICQ to ngo8
Wagonman...
in the voice of 2 irish brewers( BRILIANT!!!)
Xray|Kyosho|Exotek|Hobbywing|Sanwa|Trinity|Xpert|KoPropo
ngo8 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
