Old 06-04-2006, 05:39 PM   #4216
wagonman72's Avatar
http://www.tamiyausa.com/articles/fe...e-id=182#rules Starting with rule #9.
wagonman72 is offline   Reply With Quote
Old 06-04-2006, 05:48 PM   #4217
N4S
N4S's Avatar
WHO GIVES A FREGGIN" CRAP ABOUT THE DAMN BODIES !!!!!!!!!!!!!!!!!!!!!!!!!!!
N4S is offline   Reply With Quote
Old 06-04-2006, 05:49 PM   #4218
N4S
N4S's Avatar
Old 06-04-2006, 05:51 PM   #4219
N4S
N4S's Avatar
Originally Posted by protc3
I'll make you one tomorrow
Sweet . Thanks man......
Old 06-04-2006, 06:38 PM   #4220
protc3's Avatar
Originally Posted by N4S
Sweet,do you know any single men?
im sure you will find someone in the sausage personals.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-04-2006, 06:55 PM   #4221
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Has anyone used the blades on the spool? I know it would require some modification, but imo it would save some wear and tear on cvds and the spool itself.
Had my second weekend on my car yesterday. Picked up a lap from last time, got in the 13.1 lap range. Pretty happy so far. I have been doing alot of changes on the car trying to learn how it changes the feel. Made wholesale changes for the main and the car felt overall better but I had a tire come off the inner side of the rim on the right rear. So that killed it on two of the high speed corners. Its was either slam the brakes and creep around the corner or go in there like normal and hope no was one close behind when the car snapped around lol.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 06-04-2006, 07:32 PM   #4222
protc3's Avatar
im not sure of the blade size on the newer kits.i am looking to release a spool in the next few weeks that will have lightened hardened steel outdrives that are removable.it has been holding up very well so far.no signs of wear.they work with the standard or steel outdrives.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-04-2006, 08:02 PM   #4223
JimmyMac's Avatar
Now I know here stateside... "to my knowledge"... The new Hara/Surikarn/Black dogbones are not available yet. But has anyone tried the Pro3/4 MIP axles with TC4 dogbones? I'm not sure if the dogbones would be too long or not. I may have to try this out until someone gets a stash of "new" bones for sale stateside.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-04-2006, 08:15 PM   #4224
I bent a surikarn front bone and use a pro4 axle with a blue tc3 bone and it worked just fine.
Maclin | VP-Pro USA
Old 06-04-2006, 09:49 PM   #4225
rc-zombies's Avatar
pro4/tc4 bones are too long...
you can use the Tamiya 42mm steel cv bones work fine... I use them in the front..and front purple ones are now my spares.
Old 06-04-2006, 10:34 PM   #4226
JimmyMac's Avatar
Aren't the pins on the bone too thin for the outdrives? This "slop" would cause excessive wear. I'm mainly talking about the spools. I know on the oneways you can change the outdrives from TC3/4 to BD to SD to 415MS to EvoIV to Corally to Pro4, etc.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-04-2006, 11:04 PM   #4227
wagonman72's Avatar
There are some new black bones and steel bones in along with new black outdrives for the front one way diff, I'll get the part numbers up tomorrow.
Old 06-04-2006, 11:44 PM   #4228
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Originally Posted by wagonman72
Isn't there a list of approved bodies, if so are the new Moorespeed bodies on the approved list?
From the Reedy Race page on Tamiya's web site
"9. Invitational Class Body Rules: For 2006 IFMAR sedan bodies are the only bodies legal for the Invitational class. Legal bodies must be on the IFMAR approved list found here http://www.ifmar.org/
10. Minimum roof height 115 mm all classes.
11. Maximum car width without body 190MM all classes.
12. Maximum car width with body 195MM all classes.
13. Wing maximum height 115mm all classes."
Go to this link
http://www.ifmar.org/pdf/Ifmar_BodiesAdd_onList2006.pdf
Granted while that may not be a complete list of approved bodies it is at the very least a list of bodies submitted/approved for the 2006 season.
That should help clear everything up.
thank you! this is what I was talking about. IFMAR rules. From what I saw at the Reedy, it was all stratus and mazda's, all protoforms...are those all yours Dale??? What's the new body Dale? I think we'd all like to see a new "hot body." Any "skunk work" projects brewing?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 06-05-2006, 12:59 AM   #4229
stegger's Avatar
Am i right in thinking that the moorespeed shells arn't BRCA legal until 1st july in the UK?
stegger is offline   Reply With Quote
Old 06-05-2006, 01:27 AM   #4230
ooliganRC's Avatar
Send a message via MSN to ooliganRC
Originally Posted by Andrew_Carter
Yer defo we dont have a major problem over here wid heat issuses as the sun never seems to make and apperance in the UK,i just wonderd if it would make the car and stiffer?
Wat a wonderful weekend we had in south of england yesterday.
track temp of 44 degrees celsius at aldershot yesterday....the mid alloy heat sink did help....and looks the daddy too.
my problem was so much grip that i was overheating tyres damn preguled rubbish
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
