Old 05-22-2006, 06:32 PM   #3991
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Guo Chean
are you sure is 2.75mm thick chassis?? i brought 2 version Suriarn and Hara both a the same thickness chassis than the standard version just the revised cutoff on the front diff part chassis only.
When you asked for someone to confirm… I when and measure it… This is the reading I got…. 2.75mm thick… we are talking about the bottom chassis plate aren’t we…. As the top desk is thinner…..
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-22-2006, 06:41 PM   #3992
Trader Rating: 16 (94%+)
my original cyclone is 2.5mm, and my hara is 2.75mm
with both cars sitting side by side the hara chassis is noticably thicker...
edit: yes the bottom chassis plate, I haven't checked the top deck
domo is offline   Reply With Quote
Old 05-22-2006, 06:55 PM   #3993
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
ok i check it again maybe Japan spec is different.
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 05-22-2006, 07:26 PM   #3994
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
According to my measurements, my Hara edition chassis (bottom plate) is 2.5mm thick - using digital verniers. Also, has anyone noticed that the battery slots are about 5mm wider than the actual cells?
Was the standard cyclone like this?
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 05-22-2006, 07:36 PM   #3995
protc3's Avatar
i have seen some carbon fiber have tolerances of + or - 10% of the thickness.the higher quality materials are + or - 5% of the thickness but even at that,you will have variations.i guess its just tough to hold the exact thickness when they lay it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-22-2006, 07:40 PM   #3996
protc3's Avatar
yes,my stock cyclone cell slots are longer than the cell.i usually cut them a little longer in my chassis kits but they made them a little longer than they really need to be.i do this on my kits because the edge of the cell has a smaller radius than the corner of the cell slots so you need to lengthen them to clear the corners of the cell.im sure there reasoning is the same.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-22-2006, 07:44 PM   #3997
Trader Rating: 239 (99%+)
I thought about using the T2 battery peices to hold my cells in on the chassis. As soon as I get some I will try it and let you all know how it works out.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 05-22-2006, 08:10 PM   #3998
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Just get the blue strapping tape from Speedtech!!!!!!!!!!!! Oh then give me the purple strapping tape if you have any!!!!!!!!!!!!
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-22-2006, 09:30 PM   #3999
JimmyMac's Avatar
My Surikarn lower chassis plate is 2.49~2.50mm. My front shock tower is about 3.30mm. And my rear tower about 3.33mm.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-22-2006, 09:46 PM   #4000
rc-zombies's Avatar
My Hara is the same.. approx. 2.50mm for the chassis and 3.3+/- for the shocktowers.
Old 05-22-2006, 10:02 PM   #4001
Guo Chean's Avatar
My Surikarn is 2.52 chassis and 3.4 for shock tower and my hara is 2.6 for chassis and 3.5 for the shock tower. the deck i using G-Style racing 2.1mm deck for more stiffer all carbon fiber will have torelence .05 no perfect thick
Old 05-22-2006, 10:29 PM   #4002
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
There probably doing it for two reasons.. One is a tuning aid.. we have it on oval cars.. we move the batteries in and out to adjust the way the car transfers weight.. also with the way cells are going, come are larger then others..
burbs is offline   Reply With Quote
Old 05-23-2006, 11:38 AM   #4003
tim fry's Avatar
Has anyone experienced the shock collars moving during a run as they seem a little loose?
Is there anything I can do to them to tighten them up on the thread?
Tim
tim fry is offline   Reply With Quote
Old 05-23-2006, 11:44 AM   #4004
rc-zombies's Avatar
Tim
you can also use blue blue thread-lock on it.
that is due to no O-ring to hold them in place.
I've replaced mine with the shock collar from the Pro-4 that has the O-rings and they look better...they're purple.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGPA9&P=7
Old 05-23-2006, 11:59 AM   #4005
Phil C's Avatar
What do people think of the new HotBodies Bodyshells?
As some of you may know they've been in development for a while now, in the hands of Andy Moore and other UK Hotbodies drivers such as Ben Cosgrove and Jonny Bowdon etc.
Cant wait to try mine out, they seem to be alot more aerodynamic than the Protoform versions.
For those of you that havent seen or heard about them heres a link...
http://www.hbeurope.com/feature.php?partNo=66811&lang=en
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
