Old 04-29-2006, 10:49 AM   #3736
Nathan Parker's Avatar
Originally Posted by noline
Can I please get more Replys on gearing Thanks
Its all going to depend on the track you run at Im afraid.
Our tracks in the UK with 19t can range from around 4.5 to 5.4fdr it really depends on the track.
Nathan Parker is offline   Reply With Quote
Old 04-29-2006, 03:50 PM   #3737
drew85's Avatar
4.5, 5.0 finial drive!! wow it does not get hot or a big flowing track?
drew85 is offline   Reply With Quote
Old 04-29-2006, 04:18 PM   #3738
protc3's Avatar
I have some questions about the 1mm 2mm and 3mm shims for the Cyclone when you put these shims under the arm mounts and toe in pivot blocks what does that do.
I know it changes the roll center but what kind of handling characteristics do you get do you get more traction or less traction more rotation in the turns or less rotation in the turns
The reason why I ask is Im running on a low to med bite asphault with rubber tires I just want to know if you get more or less traction
when you shim the blocks it will lose traction.BUT!!!!!!,when you have the blocks too low(smaller or no shims),you can actually have too much traction or roll at that end of the car and cause your tires to overheat.you want to run them at a height where you have maximum traction without heating up the tires.when you find this your car will run the most efficient.what i do is start with no shims,then i run a battery pack in the car and run it for the 5 minute period.i check my laptimes and feel if the car fades towards the end of the run.i also check for excessive chassis roll or scratches on the chassis from roll.then i start raising the blocks in .25mm increments until i achieve maximum traction with minimal chassis roll and heat from the tires.as soon as you feel the car to start losing its traction you have raised them too much.after this i start with adjusting the shimming of the inboard camber link for the fine tuning.this works the same but is just not as much of a coarse adjustment.i hope i am making sense here.if i am not clear on my explination please let me know and i will explain it differently.hope i helped out
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-30-2006, 12:44 AM   #3739
Skill's Avatar
Originally Posted by domo
unsure about tir spool
the hara edition dogbones don't fit in the old one-way cups, according to http://www.hpiracing.co.jp/contents/...e/new_old.html
Thanks for the info, seems like HB want to be very awkward I think I may have to get the steel ones and file them down to fit if they don't, I wonder why Mirage no longer list the front steel dogbones?
Skill is offline   Reply With Quote
Old 04-30-2006, 02:04 PM   #3740
Not especially www.wlrc.co.uk is around 5.3 fdr on a C2 maybe less depending on layout used
Old 04-30-2006, 06:58 PM   #3741
A Ilievski's Avatar
Trader Rating: 39 (100%+)
anyone got a set up for carpet racing with foam tires. Im also running stock
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIGE BEARINGS*
A Ilievski is offline   Reply With Quote
Old 04-30-2006, 07:30 PM   #3742
lookinco's Avatar
My TiR CVD axle snapped off today. It snapped right between the steering knuckle and the hex hub. I was pretty surprised as I didn't crash very hard prior to it snapping.
Anyways anyone know where I could get TiR parts other then titaniumracing.com ?
Also for those who are running the STEEL universal drive shaft in the front, do they get bent easily?
lookinco is offline   Reply With Quote
Old 04-30-2006, 07:43 PM   #3743
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
try Schumacher they carry TiR, I just bought some Tir's for my Pro4
Old 04-30-2006, 09:06 PM   #3744
Aurra Sing's Avatar
So what store have the Hara Cyclone's in stock right now?
Aurra Sing is offline   Reply With Quote
Old 04-30-2006, 10:43 PM   #3745
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
did you have their web site or email to contact them because i plan to get the CVD also. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-30-2006, 11:01 PM   #3746
http://www.titaniumracing.com/produc...asp?menuid=204
There you go
Old 04-30-2006, 11:52 PM   #3747
Hey Kid, talk to Rick Austin he runs Cyclone at Natex and wins most of the races, i know he uses UFRA tyres 42R on the front and 40R on the rear with a one way, he will be at the enduro so you can speak to him there.
When did you get a Cyclone?
Nick
warex is offline   Reply With Quote
Old 05-01-2006, 01:23 AM   #3748
wagonman72's Avatar
Aurra Sing
Try Stormer.
wagonman72 is offline   Reply With Quote
Old 05-01-2006, 06:32 AM   #3749
GCT69's Avatar
good day to all, I am planning in acquiring a cyclone and have some questions about this car.(I tried searching the thread but I have dial up it's just so slow) anyways I hope you guys can lend a hand.
?durabilty?-- my friend drives a Pro4 and to my understanding they share some of the parts, my friends pro4 easily breaks, specially the spindles and arms; is this the same thing with the cyclone? what parts are they similar?
I only run on carpet, does HB or any aftermarket manufacturer makes a ball diff. or can you use your rear diff for the front.
Also one last thing, I'm just getting a cyclone not the hara or Sur, ed. is it still worth it purchasing just the standard ed.?
Thanks in advnce, any help is appreciated.
GCT69
GCT69 is offline   Reply With Quote
Old 05-01-2006, 06:57 AM   #3750
Skill's Avatar
The Cyclone and the Pro 4 share their hubs and wishbones, amongst other parts. I agree that the standard knuckles and possibly C-hubs aren't too strong but you can always get some aluminium ones which will sort your problem out forever.
The rear diff will fit in the front.
It depends what sort of things you are likely to buy for your standard Cyclone as to whether it's worth it or not. There are a few interesting parts in there which may be worthwhile, such as the updated bulkheads, thicker driveshafts. Also, if you are wanting a spool then the Hara/Surikarn ed is probably worth the extra money as you will then not have to buy a spool and solid pulley separately. The next question is are you bothered about the bling and speciality factor? The Hara/Surikarn eds look extrememly nice and from what I gather they are quite limited as to how many there will be.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
