Old 04-18-2006, 05:26 PM   #3631
protc3's Avatar
Originally Posted by RC Old Man
Ok guys. Stupid question. I was building my Cyclone last night and I noticed I have a 2.5 deg block for the front suspention. This would give the front 2.5 deg of toe out which should make the car more aggressive. Correct? Do most of you run this setup? Also does HB make the toe blocks in blue?
Thanks!
the 2.5 block gives you toe out on the arms or inboard toe.you straighten the wheels out with the tie rods.im not 100% on this but it seems to give the car the similar effect as the reactive castor 1/12th front end.this seemed to make the car turn in real good and hold it through the corner.it doesnt necesarily make it more aggressive.i could be wrong but it seems to reduce the castor angle during suspension compression(which happens entering the corner)and increase the castor angle under acceleration.again,i could be wrong so feel free to correct me.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-18-2006, 08:18 PM   #3632
Trader Rating: 237 (99%+)
Thanks man!
One other stupid question. When you mount the body (mazda 6) The rear wheels arn't in the wheel well indents on the body. I lined up the front so there in the wheel wells but the back isn't. I have allways just cut the wheel wells to the wheel base of the car but, an I doing this wrong? Should I lengthen the wheel base of the car to match the body I am running?
P.S. The bumper is right up against the inside of the body and the wheel wells line right up.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-18-2006, 08:18 PM   #3633
Kenneth Tan's Avatar
Hi,
Has anyone used the new aluminium diff outdrives with the black aluminum bones of the standard kit? I did fit on the plastic clips on the bones, but he bones seemed a tad loose inside the outdrives. Will the bones bend? Thanks.
Kenneth Tan is offline   Reply With Quote
Old 04-18-2006, 08:39 PM   #3634
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Fred,
I would leave the wheelbase alone compaired to my Yokomo BD the Cyclones wheelbase is just a tick shorter dont worry you built the car right LOL...
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-18-2006, 09:02 PM   #3635
Aurra Sing's Avatar
Thanks man!
Nope, the rear wheel wells are meant to be cut according to your car's wheelbase (thats why the crease isn't that thick.) Cut the front wheel wells and use the excess lexan to trace a circle for the rear. Or better yet, use a circle cutter...
Aurra Sing is offline   Reply With Quote
Old 04-19-2006, 05:22 AM   #3636
Thanks guys! I was just checking. I thought I was doing it right just second guessing myself.
I can't wait to run this car! Excllent build!
Old 04-19-2006, 07:54 AM   #3637
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Fred I want to be the first to whack it at the end of the straight when your broad side!!!!!!!!!!!:lol Hope you bring that car to the ORL2 race as I want to look at the newest version and all the blue stuff. If you kick my ass with it I might have to sell the car I run now and buy another Cyclone.:lol
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-19-2006, 09:21 AM   #3638
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Originally Posted by Kenneth Tan
Hi,
the Alumimum bones will twisted and bend. I used the standart bones for one mod race meets it twisted.. and bend .. So Now I just used the 48mm Steel ones from Hotbodies..
FYI theres 2 diffrents part# I believe one for the fronts and the other one is for the rear..
you could also use Tamiya 48mm Steel Bones too..
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 04-19-2006, 09:39 AM   #3639
rc-zombies's Avatar
here's something I came across on RcMart:
Spool adapter that fits the one-way unit.
Old 04-19-2006, 09:45 AM   #3640
Skill's Avatar
Surely this would just create a "locked one-way" where both wheels can free-wheel but have to spin together, and not a proper spool?
Skill is offline   Reply With Quote
Old 04-19-2006, 02:19 PM   #3641
XrayFK's Avatar
Yes, the way that they look in the picture, they will lock with each other, not with the one-way.
XrayFK is offline   Reply With Quote
Old 04-19-2006, 02:26 PM   #3642
Nathan Parker's Avatar
aka xray type locked one way
Nathan Parker is offline   Reply With Quote
Old 04-19-2006, 05:43 PM   #3643
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
I ordered a set of those, but I was sent Mini Z bearings instead. All you would have to do is drill a hole in the middle of the oneway and a hole in the middle of the out drive conector thingy, thats what I was going to do.
dontfeelcold is offline   Reply With Quote
Old 04-20-2006, 03:27 PM   #3644
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Surley just easier to buy a TIR spool if you want a spool?!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 04-20-2006, 05:46 PM   #3645
Buying is easy, making/modifying it yourself is satisfying especially when you have the machines to do it properly
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
