Old 04-06-2006, 07:56 AM   #3496
jag88's Avatar
Originally Posted by rc-zombies
xray parts in a pro4 will make the car slower...
what are you hitting that you're breaking steering knuckles...
I'm no expert driver...but I've yet to break one.
I run carpet/foam 19t and stock. The design of the knuckle leaves alot to be desired (imo). I found that with the slightest touch of a board the knuckle cracked. They don't break into pieces, although I've had that happen once, they develope a hair line crack that doesn't show unless you put some pressure on it by hand ..... anyway this goes a long way to solving my problem.
Nexus Racing -- I found that an extra axle shim (.008") next to the crush sleeve helps when tightening the wheel nut.
jag88 is offline   Reply With Quote
Old 04-06-2006, 10:07 AM   #3497
Aurra Sing's Avatar
Originally Posted by dontfeelcold
In an attempt to solve my handling issues Im putting a Pro4 diff in. Seeing as I didn't have enough shims to take up the gaps I used an old bearing + lots of shims. Fits just right now.
See the pic
What kind of handling issues are you having? You shouldn't have to resort to a diff unless you are running foams on carpet..
Good idea using a broken bearing as a shim instead of using hundreds of the little ones
Aurra Sing is offline   Reply With Quote
Old 04-06-2006, 10:51 AM   #3498
Suspended
See the pic
is there anything wrong with the kit supplied diffs?i just bulit these and i was wondering.....
redneck15 is offline   Reply With Quote
Old 04-06-2006, 12:08 PM   #3499
RaceAce701's Avatar
Trader Rating: 83 (99%+)
Originally Posted by lotus1
Might seem a dumb question but...On the setup sheet from IIC,it shows in the squares under the pics on the left 1.5mm and or 1mm.Are these shims under the suspension mounts?Just want to be positive about this.Thanks,Mario.
yes under the suspention blocks makesure you file down the front rear mount to clear the tie rods
Remind me i have a setup sheet 2 give u sunday
RaceAce701 is offline   Reply With Quote
Old 04-06-2006, 01:29 PM   #3500
Suspended
i hope the kit diffs are ok....something wrong with them?
Old 04-06-2006, 01:45 PM   #3501
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i didnt really think there was anything wrong with the kit diffs... most use the HPI because they already have some, and the HB outdrives are $$!
i could be wrong, but thats what i have seen.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-06-2006, 02:13 PM   #3502
Suspended
i hope the diifs are ok....
Old 04-06-2006, 05:40 PM   #3503
dontfeelcold's Avatar
Trader Rating: 20 (100%+)
HPI diffs are fine, and the one in the photo is replacing the rear diff.
All I get out of my cyclone is massive understeer, I have tried alot of things and have had alot of help and Im running out of things to try. I have never had this much trouble getting steering out of any other rc car.
dontfeelcold is offline   Reply With Quote
Old 04-06-2006, 05:43 PM   #3504
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Come on Josh, Have you tried different wheelbase and using wheel spacers to increase width of the car. That should give you all the steering you want.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-06-2006, 08:17 PM   #3505
protc3's Avatar
are you running asphalt or carpet?both of my cyclones have a ton of steering.one has the one way and one has a spool and i run on asphalt rubber tires.if i can help you in any way let me know
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-06-2006, 11:57 PM   #3506
The only changes I haven't made are ackermann changes. After that I have tried all the settings on the car.
Dan, I have shortened the wheelbase as much as possible and only then the steering is improved slightly. I have also tried the wheel track spacers. I even moved the front arms further back to get the weight over the front wheels some more.
protc3, I run on aspahlt, sometimes rubbers, sometimes foams.
I wonder what the chaces are of it lifting a wheel off the ground?
Old 04-07-2006, 12:24 AM   #3507
Aurra Sing's Avatar
Firstly what tires are you using and are they fresh? IMO, tires are ~90% of the cars setup. Not just having the right ones, but having fresh ones (no more than 8-10 runs at most)
Old 04-07-2006, 12:30 AM   #3508
John Doucakis's Avatar
To my experience so far the Cyclone has the most steering out of any other car in the market.
I am surprised you are having troubles with steering.
It is very hard to know what the problem with your car is from the forum.
Maybe if you post some pics without wheels and a set up sheet with your current set up we could help you
John Doucakis is offline   Reply With Quote
Old 04-07-2006, 01:45 AM   #3509
Skill's Avatar
Yea I agree, my Cyclone has tons of steering, I don't think I've ever had any even slight understeer in it before. What is your steering EPA like on your transmitter?
Skill is offline   Reply With Quote
Old 04-07-2006, 04:34 AM   #3510
protc3's Avatar
please post your set up so we can help you.it doesnt get better than the cyclone.im sure you will agree once things get sorted out.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
