Old 04-04-2006, 03:07 PM   #3481
robk's Avatar
Trader Rating: 22 (100%+)
Someone posted a while back about running the rear shocks on the front of the arms ala RDX. I just did a test fitting, and this is easily done, with little hacking.
Basically, you can flip the upper bulkhead/shock tower mount 180*. A small amount of the bulkhead must be removed to fit. You are removing approximately 4mm/.158 " from the bottom of the bulkhead, from the side that the shock tower mounts to. The bulkead should look bisymetrical from the side. That is it for the bulkhead.
Just reverse mount everything. The rear arm will need a new droop screw hole.
There is a small circle molded into the top of the arm across from the droop screw hole. That circle would be nearly perfect for drilling a hole to fit a 3mm screw. Maybe shift it slightly to get more meat.
The sway bar can mount on the transmission bulkhead, on the 2 rear screws of the four 3mm screws holding the layshaft and spur down. The bar runs thru the belt.
So all you need to do is a little dremeling, ans drill 2 holes. Super easy.
I will try this out as soon as I can, but here is what Keith Billanti said when he did the same thing to his JRXS:
Team Losi JRXS
It also adds about 2-3mm to the wheelbase (ends up approx. 260mm), which could be helpful for foam tire racing. This is easily counteracted by shimming if needed.
I'll try to post pics when I can.
Old 04-04-2006, 03:30 PM   #3482
kewdawg's Avatar
Yes, please post your pics.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-05-2006, 08:21 PM   #3483
jag88's Avatar
If your tired of breaking steering knuckles I found that the Xray T2 knuckles are an exact fit. You will have to add a .025" shim to fit in the C hub so maybe it's not an 'exact' fit after all ...... anyway they're alot stronger.
jag88 is offline   Reply With Quote
Old 04-05-2006, 08:37 PM   #3484
Nexus Racing's Avatar
Are the wheel axles the same length; i.e. did you need to add shims to the axle?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-05-2006, 08:38 PM   #3485
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
My car is now up forsale.
http://rctech.net/forum/showthread.php?t=108982
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-05-2006, 09:33 PM   #3486
Suspended
Originally Posted by danjoy25
why is everyone selling there cars?
redneck15 is offline   Reply With Quote
Old 04-05-2006, 09:51 PM   #3487
drew85's Avatar
I got a msx to play with now. It was hard to get rid of but there track is close to my house, and its a nice track at that.
drew85 is offline   Reply With Quote
Old 04-05-2006, 09:58 PM   #3488
danjoy25's Avatar
I can't justify keeping the car as Im concentrating on the TA-05 for TCS. I really think my version is better than the Karn and Hara Editions. However buys it won't be dissappointed with all the options and parts included its a steal.
The 2nd reason is I can't drive as good as Hara
Old 04-05-2006, 11:10 PM   #3489
rc-zombies's Avatar
xray parts in a pro4 will make the car slower...
what are you hitting that you're breaking steering knuckles...
I'm no expert driver...but I've yet to break one.
Old 04-06-2006, 12:21 AM   #3490
Aurra Sing's Avatar
Haha, to get the new Hara version!
I'm selling mine as well. $300
F/S: Hot Bodies Cyclone (used)
Aurra Sing is offline   Reply With Quote
Old 04-06-2006, 12:22 AM   #3491
Trader Rating: 24 (100%+)
I sold my Cyclone before I broke it
JoeyE is offline   Reply With Quote
Old 04-06-2006, 12:24 AM   #3492
I sold mine to buy a digital camera
Old 04-06-2006, 02:50 AM   #3493
MadBrushRacing's Avatar
Has anyone got Russ Williams 19t setup from the BRCA national @ Wrexham last weekend?
MadBrushRacing is offline   Reply With Quote
Old 04-06-2006, 04:30 AM   #3494
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
In an attempt to solve my handling issues Im putting a Pro4 diff in. Seeing as I didn't have enough shims to take up the gaps I used an old bearing + lots of shims. Fits just right now.
See the pic
dontfeelcold is offline   Reply With Quote
Old 04-06-2006, 06:39 AM   #3495
Default hmmmm
Might seem a dumb question but...On the setup sheet from IIC,it shows in the squares under the pics on the left 1.5mm and or 1mm.Are these shims under the suspension mounts?Just want to be positive about this.Thanks,Mario.
lotus1 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
