Old 03-31-2006, 02:54 PM   #3436
pucho's Avatar
Send a message via AIM to pucho
OK! I am totaly stumped
So In my 10years+ in RC I have built about 2.5 million diffs. Any and every kind.
I was doing some maintenance on my car yesterday and decided to freshen up the diff. So I bust out new rings, balls trust washers, and balls, I take it all appart clean the outdirves degrease all new stuff and get assenble the diff. WTF something is wrong, there's no diff action!! OK so I try several other times I eaven break out the manual just to double check and nothing the outdrives just turn together and the gear is just rotating on it's own. I eaven do my second diff and it's now acting the same way! I swapped in the old parts, nothing I can't figure it out. It looks like Ill be racing 1/12 this week end I just can't figure it out.
pucho is offline   Reply With Quote
Old 03-31-2006, 06:21 PM   #3437
What parts are needed to make a front diff?
thanks
pimpjuice_101 is offline   Reply With Quote
Old 03-31-2006, 06:45 PM   #3438
protc3's Avatar
hey buddy,i just answered your PM.i thought you meant the T2 from your sig.i will have a carpet chassis very soon and they sell a diff kit for the car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-31-2006, 08:32 PM   #3439
Trader Rating: 21 (100%+)
Default Quickie
Quick question.Hara's setup sheet for foam carpet lists Orion oil in the shocks.Does anyone know how their oil relates to say...AE and Trinity?Is their 40wt,say,lighter,the same,or heavier than Ae or Trinity?Thanks,Mario.
lotus1 is offline   Reply With Quote
Old 04-02-2006, 05:38 AM   #3440
dontfeelcold's Avatar
That sounds really bizzare
If you figure it out, please let us know what you did to fix it.
dontfeelcold is offline   Reply With Quote
Old 04-02-2006, 07:53 AM   #3441
Bryan Thng's Avatar
Hi guys
Appreciate it if anybody can tell me the range of 64dp spurs and pinions for the Cyclone?
Is there a suitable 64dp spur/pinion combination to get a final drive ratio of between 9.8 to 10.40?
Thanks in advance
Bryan Thng is offline   Reply With Quote
Old 04-02-2006, 07:55 AM   #3442
kewdawg's Avatar
Sounds like, the spring for the diff bolt, wasn't included in the rebuild? HEY! Maybe, its a spacer / shim issue?!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-02-2006, 08:06 AM   #3443
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
I prefer you keep spurs ranging from 98teeth to 108 teeth. This way you can play along the gearing on stock and mod. Pinions from 27 teeth to 44 will do as well. Use higher spurs for mod racing. Have a great race!
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 04-02-2006, 10:02 PM   #3444
Bryan Thng's Avatar
Thanks for the info Geetoo
So based on the range you have provided, the highest ratio is only 9.75... any idea if it is possible to get higher in the Surikarn or Hara edition Cyclone ?
Is there any 15T middle pulley available to raise the internal ratio?
I want to get a ratio of 10 or higher for the GTB 4.5R set that I am using, so just making sure that the Cyclone can get the ratio I need before getting it
Old 04-03-2006, 12:42 AM   #3445
Skill's Avatar
You may just about be able to fit a 25 or 26 tooth pinion on with the 108 spur but you have to use the 2 screw holes to the right on the motor and not the ones opposite each other. I can fit a 27 tooth pinion on mine with a 106 spur, but haven't tried anything lower than that so I could possibly get a 26 on.
Skill is offline   Reply With Quote
Old 04-03-2006, 03:38 AM   #3446
protc3's Avatar
i ran my 7x1 today with a 108 spur and i ran a 29 pinion.its when you get into the stock and 19 turn motors is when you need the 100 spur and so on.its tough to get the real big pinions on the car with the 108 spur.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2006, 03:40 AM   #3447
protc3's Avatar
i am also getting ready to go brushless so i am gonna start at a 108 27 and see how she goes.its tough to get anything smaller than that on the car.you can but its tight.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2006, 05:41 AM   #3448
JonboyGB's Avatar
Hello all,
Iím looking for a centre brace for the Cyclone (its goes from left rear bulkhead to right rear bulkhead near the motor - does that make sense?). I think its made by Shooters.
Does anyone know of a online shop that sells it?
Also, does Shooters have their own website? Got a link?
Cheers Ears
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 04-03-2006, 06:10 AM   #3449
pucho's Avatar
You could also try using Tamiya diff pulleys. They have a 35 and 36t pulleys that I'm sure would work. Problem is fugunig out what belt to use.
Old 04-03-2006, 06:31 AM   #3450
Suspended
whats up on those notches on the diffs? when i try to align everything up,its very tricky....
redneck15 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
