Old 03-27-2006, 06:03 PM   #3376
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by protc3
sent you my set up buddy.it has worked incredible at every track i have run it.
I would also like to have it. Thanks.
RayWarner is offline   Reply With Quote
Old 03-27-2006, 06:31 PM   #3377
protc3's Avatar
here is my spool setup that has been working awesome in stock,19 and mod
front:
1.5 deg camber
4 deg castor
6mm droop
.5deg toe out per side
2.5 block
1.5mm shims under hinge pin blocks
shock position on arm is 1(from set up sheet)
3mm shim under ball stud on bulkhead
tower shock position 2(3rd in from outside)
ballstud position 4 on bulkhead for camber link
1.4mm sway bar
2mm shims under ballstuds on steering rack
width of front end is - .5mm from stock(i took a light cut on the hexes)
gold HPI springs w/ 45 wt. oil in front shocks
rear:
1.5deg. camber
6mm droop
5mm rideheight
3 degree toe block
2mm shim under each side of front hinge pin block(rear of car but in front of arm)
1.5mm shim under each side of the 3.0 block
shock position 2 on arm and 2 on tower
inner ball stud hole on rear hub for camber link
1.5mm shims under ballstud on bulkhead
standard wheelbase
-.5mm on width
pink HPI srings w/35 wt. oil in rear shocks
take off 27 tires and a mazda 6 body.this setup has been excellent at ell 3 tracks i race at.hope it works for you too.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-27-2006, 07:01 PM   #3378
protc3, those with locked center pulley or one-way pulley ?
thanks.
Faiz is offline   Reply With Quote
Old 03-27-2006, 07:26 PM   #3379
Aurra Sing's Avatar
front:
1.5 deg camber
4 deg castor
6mm droop
2.5 block
1.4mm sway bar
rear:
1.5deg. camber
6mm droop
5mm rideheight
3 degree toe block
standard wheelbase
-.5mm on width
That looks similar to one of Hara's setups, the one I will start off with when I finally unleash the Cyclone on asphalt for the first time! It will be so awesome.
Aurra Sing is offline   Reply With Quote
Old 03-27-2006, 08:21 PM   #3380
drew85's Avatar
anywhere that sells cyclone parts online? I can't remember the site rainbow something??? Or any other good shops for partrs/hop up stuff.
drew85 is offline   Reply With Quote
Old 03-27-2006, 09:17 PM   #3381
try precisionrc.com
dway100 is offline   Reply With Quote
Old 03-27-2006, 09:30 PM   #3382
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
hey guys,
i am almost finished with my prototype bulletproof spool for the cyclone.i just need to crosspin the outdrives and put in the pulley mounting holes.i am gonna try it out this weekend and try to beat it up and make it surrender.i will let you know how it holds up.if it doesnt i will make it stronger.let me know what you think so far
Hey Jason when will the spool release?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 03-27-2006, 09:40 PM   #3383
rc-zombies's Avatar
RainbowTen.. unfortunately they don't sell cyclone parts...
Overseas Try Precision RC or RcModel.
in the US.. Speedtech or Stormer Hobbies.
Old 03-27-2006, 09:42 PM   #3384
rc-zombies's Avatar
Originally Posted by Faiz
For medium to High grip asphalt, which is more better Spool+center One-way or Spool+center locked pulley?
Racers typically run a spool with a locked center pulley.
Old 03-27-2006, 09:48 PM   #3385
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
hey guys,
What are the outdrives made from?
dontfeelcold is offline   Reply With Quote
Old 03-28-2006, 03:17 AM   #3386
protc3's Avatar
thanks.
sorry,that is locked layshaft pulleys and a spool
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-28-2006, 03:18 AM   #3387
protc3's Avatar
i am testing the spool with stainless steel outdrives.if need be i will go to hardened steel.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-28-2006, 06:05 AM   #3388
Trader Rating: 37 (100%+)
I see you are developing a thicker carpet/foam chassis but what is the advantage or your asphault chassis?
Just wondering since I thought the stock chassis was designed with asphault/rubber tire racing in mind.
Either way I'm sure yours will be top quality I'm just asking since I'm considering purchasing the Cyclone SE.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-28-2006, 07:02 AM   #3389
Hi,
Im looking for the ratings of the 7 pairs of springs in the pro4 spring set, it says on a piece of paper that came with the set but i have lost it and cant find them online anywhere, so if anyone can list the ratings for each of the springs then i would be very gratefull.
this is what i think the ratings are:
blue 15
silver 16
pink 17
gold 19
white 20
yellow 22
red?
Anyone that knows the rating of red and a more accurate rating of the rest please post them,
thanks
agower is offline   Reply With Quote
Old 03-28-2006, 07:34 AM   #3390
drew85's Avatar
I saw awhile back someone posted a link to Hara's build tips or something like that, and it had alot of good stuff on it but I can't find it anywhere. Anyone?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
