Old 03-26-2006, 03:17 PM   #3331
Ballsie's Avatar
I'm still building my Surikarn kit and the shocks are easily the worst I've ever built
Trying to get the ball joint to the end of the shock shaft is nearing on the impossible. Out of the 4 I have 2 that are barely on, 1 a little more so, and one nearly fully on.
I just can't get the shaft to stop rotating when I try to tighten the ball joint - anyone got any ideas?
Ballsie is offline   Reply With Quote
Old 03-26-2006, 03:57 PM   #3332
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Pics would be good buddy, Cyclone shocks are very similar to Tamiya TRF and should be very easy to build and rebuild.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-26-2006, 04:01 PM   #3333
pucho's Avatar
Send a message via AIM to pucho
Ballsie: I have a tool for that I think duratrax made it it looks like a brass coin with a slot cut out you slip it onto the shaft and grab it with a pair of vicegrips. You could also just use a towel wrapped around the shaft and grab with the vicegrips.
bear27: You need 302650 5mm ball ens with thread
303222 ball Joint5mm unidirectiona open
302664 can also be used these are the ones for the T2
307455 if the double sholder ball you need these for the king pin and the steering links (to attached it to the steering knucle) As far as heith it is soo close that no extra shims are needed. I do use a 1mm shim under the link on the steering block for more clerance.
Hope this helps otherd that like me are unable to find the Square Ti ends and are having problems breaking studs.
pucho is offline   Reply With Quote
Old 03-26-2006, 04:32 PM   #3334
protc3's Avatar
hey guys,i had a hectic day of racing today.i ran 3 classes.i ran stock touring with my 1 way cyclone,mod touring with my spool cyclone and 1/12th with my buddies BMI DB12.i tq'ed and won stock touring,i qualified 2nd in mod by less than a second and won the main,and i tq'ed 1/12th and won the main.it was alot of fun racing today but man i am wiped out.3 classes is alot for one day. both of my cyclones were unreal.what an awesome car.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-26-2006, 04:51 PM   #3335
ngo8's Avatar
Send a message via ICQ to ngo8
dude use pliers the cutter part of the pliers and grab the shaft there is like a little rough part grab it from there abd twist it should go on easy and cyclone shocks are the best in the market just need some patience
Xray|Kyosho|Exotek|Hobbywing|Sanwa|Trinity|Xpert|KoPropo
ngo8 is offline   Reply With Quote
Old 03-26-2006, 05:19 PM   #3336
Trader Rating: 21 (100%+)
Default Standard Kit
Getting a standard kit instead of the surikarn.My buddy is trying to get me the parts for a front diff.he's found most of the parts......outdrives from hotbodies
diff screw and nut
diff rings............We have the part numbers for these but,we can't find the part numbers for the gear itself. Also,The thrust washer and rings for that.Anyone out there have an idea on these numbers?Would be very appreciated to get this info.Thanks,Mario.
lotus1 is offline   Reply With Quote
Old 03-26-2006, 06:02 PM   #3337
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
yes Jason both of your cyclones were dialed today both of them were very fast!! Cant wait to race against you again!!
Old 03-26-2006, 06:14 PM   #3338
i agree jason. had a blast today. the cyclone with a spool is awesome. thanks for the help today.
chrisw is offline   Reply With Quote
Old 03-26-2006, 06:38 PM   #3339
jag88's Avatar
Does anyone have any experience with the Jet Racing alum. strg. knuckle ?
How are the tolerances on the bearing holes ? I've been breaking alot of plastic knuckles lately and was thinking the aluminum might be the way to go.
jag88 is offline   Reply With Quote
Old 03-26-2006, 06:56 PM   #3340
danjoy25's Avatar
I have both front and rear hubs and they are pretty good. never have any problems with them. I would get extra 5mm shims
Old 03-26-2006, 07:00 PM   #3341
jag88's Avatar
Why do I need extra 5mm shims ?
Thanks.
Old 03-26-2006, 07:53 PM   #3342
danjoy25's Avatar
You need to put them on between the wheel bearing and the wheel hex hubs to eliminate play. On stock hubs per manual, you have to put on atleast 1-2 shims, but on the alloy hub I think I have to added another 2.
Old 03-27-2006, 12:10 AM   #3343
jason
will you pm your spool set up
thanks jimmy
jimmy..maddison is offline   Reply With Quote
Old 03-27-2006, 01:00 AM   #3344
The part # for the pully is a495 not easy to find tower hobbies has it in stock just search under hpi a495 you can use losi diff rings same thickness and I use asc thrust ball diff screw tnut and thrust washers
no1uno is offline   Reply With Quote
Old 03-27-2006, 03:27 AM   #3345
Default FDR
Hi all,
I'm having trouble figuring FDR out for a stock motor (19T single) on a asphalt track with a back straight of 600ft. Any help would be greatly appreciated. With 12T my FDR is between 5,6-5,8.
Thanks.
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
