Old 03-25-2006, 06:40 AM   #3316
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by protc3
i am finishing up the carpet kit this week hopefully.i made a few changes to the first prototype that steve tested and i think it is going to be killer.
hey Jason It will be a week or so before I can get my Cyclone
RACE OPT USA
Bartolo Racing R/C
Old 03-25-2006, 06:41 AM   #3317
Super Moderator
Marcos.J's Avatar
Originally Posted by pucho
Jason:
Sign me up for one! Asphalt chassis that is.
Pucho your Cyclone looked very fast at Fasttracks
RACE OPT USA
Bartolo Racing R/C
Old 03-25-2006, 10:20 AM   #3318
tc3 racer sc's Avatar
Jason:
what up pucho it reggie when nxt race i can come dwn to run also any one got pic of a tir spool i can see
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 03-25-2006, 11:18 AM   #3319
protc3's Avatar
no problem pucho.wait until you see the spool i am working on.my god,this thing is sick.i will post some pics as soon as i finish it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-25-2006, 01:13 PM   #3320
cyclone's Avatar
i would really like to use a battery strapping bar, when i get my cyclone, is there no possible way that you can make a pro4 1 fit?
cyclone is offline   Reply With Quote
Old 03-25-2006, 01:38 PM   #3321
rc-zombies's Avatar
pro4 battery strap should fit..you have to drill and countersink the screw hole.
Old 03-25-2006, 01:41 PM   #3322
cyclone's Avatar
cheers, so the battery tape holes in the cyclone are exactly the same distanse apart as the pro4 ones are they? (for the little post pin to go in)
other than that its just about drilling.countersinking the wholes..... cant be to hard...
Old 03-25-2006, 03:30 PM   #3323
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Im 90% sure the Xray FK05 batt strap fits the car without any effort.But you have to ask urself ''do i really want a 3rd world part on my car''
Ill let you decide!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 03-25-2006, 05:03 PM   #3324
cyclone's Avatar
well if a hpi 1 will be made to fit i no which ill rather use
Old 03-25-2006, 08:19 PM   #3325
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
The latest cyclone. Its a kit made by both hara and surikarn specifications.
Here is also a hara edition cyclone coming. #66400 , Surikarn #66401
Heres some more info:
Since its debut, Hot Bodies Cyclone has won a number of races including the total victory in the 2005 JMRCA Touring Car Japan Nationals Expert Class (TQ and domination of the places between 1st and 4th in A main). We are now releasing the Surikarn and Atsushi Hara editions created by the two world champions for limited production. The beautiful aluminum parts and sophisticated special parts are all nice features you can be proud of.
Special features selected by two world champions:
Aluminum parts in champions' distinctive colors
Aluminum ball diff cup joint
3.5mm hard graphite shock tower (front & rear)
One-piece spool
Lightweight precision aluminum servo mount
Narrow 39T pulley (one-way for front and ball diff for rear)
Strengthened aluminum CVD bones.
Strengthened upper bulkhead
Shock shaft with adjustable piston positions
Scheduled to be released in mid March!
#66401CYCLONE SURIKARN EDITION
Scheduled to be released in mid April!
#66400 CYCLONE ATSUSHI HARA EDITION
Chassis length: 365mm Width: 190mm Wheelbase: 256-259mm (changeable) Weight fully equipped: about 1430g Drive system: 2 belt drive 4WD
-- Enjoy, AI
Artificial-I is offline   Reply With Quote
Old 03-25-2006, 08:48 PM   #3326
Trader Rating: 37 (100%+)
Few questions about the Surikarn Version.
How thick is the chassis?
Does the rear diff work up front?
Do foams fit no problem like the Pro4?
So it comes with a rear diff, front oneway and a spool?
Outside of maybe Thad Garner.......are there any full FT HPI/Hotbodies drivers in the U.S? Or do they even have 50% guys?
RobK....another HNDS might be back!!
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-26-2006, 06:31 AM   #3327
pucho's Avatar
Send a message via AIM to pucho
Thanks, Just let me know if you need any help geting it up and runnig. Really I would wait and get yourself a kan or hara edition with the new pullies. Thaks for the help with the motor I appreciate that.
Reggie Let me see what I can find.
Mine is has the purple center section with the aluminum outdrives, Very durable so far. Next race, we have the State series April 22 and 23 at Superior click on the FSEARA link for more info. If you come down Friday I can help you with the set up.
Hey jason maybe you can have some ready by the State race Ill deff want to check it out. Hurry My chassis is looking all beat up.
Car is running well I added the the Square right side middle block and it seams to have stiffen up the car some. I was also using the stiffner pice but didn't like it, it seemed like the car was more sensitive to tweek.
Also if you find your self with out part, namely Casted block and steering knucles the T2 parts are an aceptable repalcement. The steering knucles will fit on HPI caster blocks buth the HPI steering knucles will not fit with the T2 Caster blocks. This week end I ended up havign to use such parts because my LHS refuses to cary HPI parts, They will order them for me but will not stock them. Maybe If I can get more people to run the car they will be forced to.
NEXUS: That I know of... there is nothing, Thad is only sponsored because he works there. Foams should be no problem it's the same suspension, chassis is the same 2.5mm, as I understand it it only comes with the spool. Some guys have purchased them maybe they can shed some more light.
pucho is offline   Reply With Quote
Old 03-26-2006, 07:41 AM   #3328
pucho's Avatar
BTW here is My Xray camber link set up.
My Square Right side Block
My BMI shock bushings/mounting thingamajigy
Old 03-26-2006, 08:01 AM   #3329
Pucho: I as well am moveing to the x-ray linkage, glad to know im not the onlyone who mixes brands. Can you help me with proper part#'s and do you shim the links at the ends to make the same hight as the ball and cups. Any help would be great
bear27 is offline   Reply With Quote
Old 03-26-2006, 09:00 AM   #3330
If anyone is looking for a Titanium Racing Spool I have one for sale. It is the Purple one with the aluminum outdrives. It is in excellent shape. I bought my car used and it came with it, but I only run rubber tires on carpet and will never use it. $30 shipped. Send me a PM if you are interested. I can get pics later today.
dway100 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
