Old 03-14-2006, 02:07 PM   #3181
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
pack it with washers then locking in the grub screw then take 1 or 2 washers off
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-14-2006, 02:26 PM   #3182
rc-zombies's Avatar
From the TITC race..
If you look closely.. looks like Hara is running the Blue Chassis...
Old 03-14-2006, 02:44 PM   #3183
Ballsie's Avatar
I'm not so sure - is it not just a blue motor heatsink?
There is some purple just at the bottom left of the number 1 on the front window.
Ballsie is offline   Reply With Quote
Old 03-14-2006, 02:45 PM   #3184
bottom right mate
agower is offline   Reply With Quote
Old 03-14-2006, 02:46 PM   #3185
Stew Noble's Avatar
its just blue window tint
// S N F //
Stew Noble is offline   Reply With Quote
Old 03-14-2006, 03:02 PM   #3186
Ballsie's Avatar
Originally Posted by agower
bottom right mate
it's been a long day
Old 03-14-2006, 03:17 PM   #3187
rc-zombies's Avatar
yup you're right.. blue window tint.
Old 03-14-2006, 03:20 PM   #3188
Ballsie's Avatar
that's seriously trick!
Anyone know what kind of paint to use - Tamiya translucent perhaps?
Old 03-14-2006, 11:18 PM   #3189
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally Posted by chr15tophe
regards the centre layshaft how much side to side movement is everyone factoring in ? do you guys give it no movement and pack it out with washers or do u leave a little movement and let it find its own postion whilst running ???
No movement seems better, but i put a very slight movement on it to avoid that little bind. In fact I did not follow the instruction manual, if using center oneway pulley I tried to put the spur gear hub the other way around. I noticed the HB70726 one way pulley somehow scrubs the spur screws. Washers wont even help, inverting it didnt make anything different at all. Works just fine.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 03-15-2006, 03:34 AM   #3190
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Follow the Hara buling guide,2 crub screws either side in the spur gear hub and no silly CF plate.
Keeps the spur awesomelly straight to.CF fingy is just crappy and gets in the way!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 03-15-2006, 02:12 PM   #3191
Is there any advantage to running the center oneway along with the front oneway, or will the car handle the same with the locked center pully and a front oneway? I have the locked pully and thought it might be easier to try different setups by just switching the front oneway out for a diff or a spool without having to touch the center one.
dway100 is offline   Reply With Quote
Old 03-15-2006, 02:18 PM   #3192
A Ilievski's Avatar
Trader Rating: 39 (100%+)
how much is the hara edition cyclone?????. im just curious
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 03-15-2006, 08:37 PM   #3193
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
with a center one-way the front belt (and front pulley, and front one-way housing) can move faster than the center shaft (but not faster than the wheels, because this would cause the front one-way to lockup and transfer).
conversely with a locked center pulley the front belt (and front pulley and front one-way housing) have to move at the same speed as the center shaft.
so when you get off power without center one-way the front half of the drivetrain has to slow down, so that when you get back on power all of that mass has to be accelerated.
with center one-way that mass can continue spinning at some speed that is faster than the center shaft. so that when you accelerate again only the center shaft (and rear drivetrain) have to accelerate for awhile to catch up to (and then accelerate) the front drivetrain parts.
basically it gives you better acceleration to run double one-way vs locked pully front one-way.
floodo1 is offline   Reply With Quote
Old 03-15-2006, 09:33 PM   #3194
rc-zombies's Avatar
72000 yen
Old 03-15-2006, 11:21 PM   #3195
XrayFK's Avatar
Originally Posted by rc-zombies
72000 yen
611 USD at the current rate.
XrayFK is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
