Old 02-27-2006, 10:16 AM   #3016
Those two versions have not been released yet.
Here's a link to the new Cyclones:
http://hpiracing.co.jp/contents/hotb...surikarn2.html
trf_racer is offline   Reply With Quote
Old 02-27-2006, 10:27 AM   #3017
rc-zombies's Avatar
Originally Posted by or8ital
$620 USD?
that's what they said too when the original cyclone was released...
the street price came to as low as $400.
Cyclone original price: 65000yen, = $559usd.+/- US street price: $400+
Hara/Surikarn edition: 72000yn = $620usd +/- US street price: ?
Just hope the Hara & Surikarn Editions will be around $450 range
still a better Deal than buying the T2...
Old 02-27-2006, 10:45 AM   #3018
jag88's Avatar
Shock shaft with adjustable piston positions .......... now that sounds interesting !
jag88 is offline   Reply With Quote
Old 02-27-2006, 10:47 AM   #3019
I don't understand what they mean by adjustable piston position????
The shocks looks the same....
Hugo is offline   Reply With Quote
Old 02-27-2006, 10:51 AM   #3020
jag88's Avatar
I wonder if they redesigned the internals so that it works the same as Xrays ?
That would be NICE !
Old 02-27-2006, 10:53 AM   #3021
rc-zombies's Avatar
hopefully it doesn't leak like the Xray's...
Old 02-27-2006, 11:20 AM   #3022
XrayFK's Avatar
I wish they made a closer internal ratio, smaller diff pulley and larger center pulley; then I wouldn't have to use such a huge pinion.
XrayFK is offline   Reply With Quote
Old 02-27-2006, 12:59 PM   #3023
You are free to use any other tamiya center pulleys, am I wrong?
benoitrdv is offline   Reply With Quote
Old 02-27-2006, 01:00 PM   #3024
funny ;-)))
Old 02-27-2006, 01:38 PM   #3025
RaceAce701's Avatar
Trader Rating: 84 (99%+)
Gearing help
i am running on carpet i have 59mm tires a 108t spur and am running the monster stock pro motor. our track is usually technical with one large straightaway. does any one have an idea for a starting ratio??
I took my first laps in the cay yesterday. It blew me away without evin being set up properly it ran just a good of times as my perfectly set up tc4.
RaceAce701 is offline   Reply With Quote
Old 02-27-2006, 04:34 PM   #3026
jag88's Avatar
After running the car this weekend, I have a few setup changes as a used a diff instead of the kit front one-way. I was running Hara's Vegas carpet setup but was losing too much speed in the corners. The car didn't have good off-power to on-power transitions. Changing the ackerman setting alone made the car nearly perfect in the corners. I usually never mess around with ackerman setting but decided to this time. It made a huge difference. The last thing I did was add a little bit more castor to compensate for the abundance of the car's turn-in.
Just curious, what exactly did you change on the ackerman ? Was it on the spindle (which hole did you end up in ?) or the inner pivot (how many spacers ?) ?
Thanks.
Old 02-27-2006, 06:26 PM   #3027
Dreamcatcher's Avatar
Originally Posted by lotus1
Am very interested in a Hara or Surkarn edition.Are these available Anywhere yet?Domestic or foreign,doesn't matter.Dealer suggestions?Thanks,Mario.
A CYCLONE???
Dreamcatcher is offline   Reply With Quote
Old 02-27-2006, 07:47 PM   #3028
XrayFK's Avatar
Start with a rollout of .98-1.00. If the car tops out before 3/4 of the straightaway, gear up. Also, check to see how hot the motor gets after a run.
Old 02-27-2006, 07:49 PM   #3029
XrayFK's Avatar
Thanks.
I kept the 4mm of spacers on the inner steering column, but moved the ball studs to the inner holes on the knuckles.
Old 02-27-2006, 09:10 PM   #3030
Im wondering if you will be able to buy all the goodies to upgrade the current cyclone to a hara edition without haveing to buy the new car
bear27 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
