Old 02-24-2006, 08:50 AM   #2986
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
if you see clearly that is purple color and he only nosram heat sink not nosram esc
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-25-2006, 02:37 AM   #2987
Atomix's Avatar
Hi All,
Just wondering if anyone has noticed any excessive wear on the layshaft where the centre 1-way rides? Mine seems to have worn to the point where the centre 1-way doesnt "lock" on power occasionaly which makes for some entertaining random 2WD action .
Anyone else had a failure of this type?
Atomix is offline   Reply With Quote
Old 02-25-2006, 04:24 AM   #2988
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
My one-way layshaft was doing the same thing, but the bearings in the centre pulley were starting to come loose so I went to double locked pulleys.
I reckon the layshafts aren't hardened enough :-(
dontfeelcold is offline   Reply With Quote
Old 02-25-2006, 04:29 AM   #2989
Have a look at the endbell on the V2 in Surikarn's car. Its had further machining for better airflow.
Old 02-25-2006, 06:39 AM   #2990
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Atomix
Hi All,
Mne did this but it was actually the one way bearing spinning inside the pulley. I used a drop or two of CA and let it dry. Put it all back together and it worked great and no more slipping. I think someone else here had this problem. I thought maybe mine was doing the same. Come to find out it was and I fixed it. Truthfully though I didn't see any differeance in my lap times with front way vs. double one ways.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-25-2006, 07:33 AM   #2991
tim fry's Avatar
Hi all
I need a bit of advise please.
I'm just building my Cyclone and I'm not using the front one way I'm fitting a spool and I'm using the solid centre shaft pulley.
I have fitted it all up but there seems to be a lot of side to side movement on the centre shaft is this normal? Also the front belt isn't running directly under the tensioner its just to the left.
Any help would be appreciated.
Tim
tim fry is offline   Reply With Quote
Old 02-25-2006, 09:22 AM   #2992
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Woundering what usually breaks on this car?
Roberto Falcon is offline   Reply With Quote
Old 02-25-2006, 09:26 AM   #2993
lookinco's Avatar
Usually the steering knuckle and the C-hub breaks first. I also find that the ball stud that came with the car to be very brittle and break quite easily, especailly if you have aluminum knuckle. The front Aluminum dogbone bend VERY easily, an upgrade to the steel or even the TiR titanium would be a good choice.
Other then that, every seems fine. At least I haven't broke any of mine yet.
lookinco is offline   Reply With Quote
Old 02-25-2006, 12:14 PM   #2994
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Originally Posted by tim fry
Hi all
Tim
Adjust the play with the rear layshaft pulley,jst undo the grub screw and slide it across,should do the trick!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-25-2006, 01:28 PM   #2995
Atomix's Avatar
The layshaft in mine has actually worn in diametre, so i'd have to agree, with your layshaft comment.
I'll get hold of a fixed centre pulley. Thanks to those who replied.
Cheers
Old 02-25-2006, 02:41 PM   #2996
protc3's Avatar
do they have haras setup that he had on his car in those pics yet?i would like to get it if you guys know where to find it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-26-2006, 08:23 AM   #2997
Hello what are those white springs used by hara and moore on their front shocks at TITC 2006?
Thank you
benoitrdv is offline   Reply With Quote
Old 02-26-2006, 11:05 AM   #2998
Which brand make the "special" black shottky used by the HB team drivers???????
Hugo is offline   Reply With Quote
Old 02-26-2006, 11:09 AM   #2999
Thank you
Tamiya whites maybe? as Xray whites are only 17.5,maybe even rayspeed whites lol who nows.
@hugo -Novak
l8rs
Old 02-26-2006, 12:53 PM   #3000
Phil C's Avatar
Pretty sure they are Novak diodes.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJJF4&P=0
Ive definately seen Hara using one of these.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
