Old 02-17-2006, 12:42 AM   #2896
SA
With the rear end stepping out, you might want to make sure that the centre one-way bearing is not slipping. We run foam tires, and what we found is that when everything heats up, the bearing slips in the housing. The easiest way to check is to hold down the rear tyres, and if you can turn the front tyres, it is the centre one-way, after a run. A small drop of CA in the housing resolves this problem.
SA is offline   Reply With Quote
Old 02-17-2006, 02:04 AM   #2897
nordheim's Avatar
I know there were posts back in time talking about front belts from other cars which fits the Cyclone. I heard x-ray I think? Any other ones?
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 02-17-2006, 02:53 AM   #2898
John Doucakis's Avatar
http://www.hotbodiesonline.net/06_titc.html
John Doucakis is offline   Reply With Quote
Old 02-17-2006, 04:41 AM   #2899
pucho's Avatar
Send a message via AIM to pucho
Originally Posted by nordheim
Guys, I'm in a loss for ideas. I'm having constant issues with the tailend on my car being loose. I am currently running the stock setup posted by Evicerator a couple of pages back. I am running on a very high traction track which is very technical but keep dropping time due to this problem. I am running the oneway with no brakes at all. Other than this the car is extremely fast and has lots of steering. Mostly using Sorex 36's as this is what others are using with success.
Any suggestions???
Like Steve said add droop to the rear or reduce in the front. also check to make sure that your bearings are not binding up. This car has probably the best mechanical grip of any car in the market.
pucho is offline   Reply With Quote
Old 02-17-2006, 05:49 AM   #2900
Originally Posted by rudster
Will the HPI Pro4 axles fit in the TIR dogbones
no, for me they did not fit. But I had lots of problems wit TIR products, maybe they should fit and it was bad luck for me The TIR bones have smaller inner diameter IIRC.
omoser is offline   Reply With Quote
Old 02-17-2006, 06:37 AM   #2901
bretthitman's Avatar
servo
hi has any one had the ears on the servo brake a lot i have had 2 brake in 2 meatings
bretthitman is offline   Reply With Quote
Old 02-17-2006, 08:07 AM   #2902
you can use rubber pads between the servo ears and the servo posts. That should reduce the force during a side impact; but then you have to shim the ballstud on the servo horn to be aligned properly again.
Old 02-17-2006, 08:58 AM   #2903
rc-zombies's Avatar
Originally Posted by floodo1
yeah but the speedo in that pic isnt a twister
what gives?
it may be the Surikarn edition...but from the pics I've seen the car may not belong to Surikarn himself...
Old 02-17-2006, 09:06 AM   #2904
Trader Rating: 16 (94%+)
I've had one break, but I put it down to the case/ear being weakened by trimming the top half off for my pro4, not a design fault with the cyclone
domo is offline   Reply With Quote
Old 02-17-2006, 09:10 AM   #2905
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Mine was slipping but I checked the shaft out and I could see the slip makes on it. I will have to check the bearing and maybe add a drop of CA.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-17-2006, 09:12 AM   #2906
wyd
Tech Legend
wyd's Avatar
Originally Posted by danjoy25
I too have the same problem, but only on the 2nd heat. The car handles faultless in the 1st heat but after that the rear end just breaks.
Im pretty sure its got something to do with the nitro cars running as we race with them on our local track.
More than likely after the nitro cars runs the track picks up some traction and then you cars front end hooks up better and makes you car steer better and loosens up the back end because of that. I added the copper front swaybar to my car at are track and that pretty much stopped that problem.
Old 02-17-2006, 09:42 AM   #2907
nordheim's Avatar
Does the Tamiya trf 415 low friction belt fit on the Cyclone?
Old 02-17-2006, 09:51 AM   #2908
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
the pic show is surikarn car becasue during FEMCA ISTC in malaysia he using nosram ESC heat sink on hara twister 2.1
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-17-2006, 04:03 PM   #2909
Phil C's Avatar
Dont know if anyone has seen this, but its fairly interesting.....
http://bbs.rcfans.com/viewthread.php...age%3D1&page=1
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 02-17-2006, 04:15 PM   #2910
Lots of good pictures!
trf_racer is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
