Old 02-12-2006, 10:27 AM   #2836
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Anyone got a link to som epics from the TITC then??
L8s
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-12-2006, 04:22 PM   #2837
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Well today I finished making my own custom fan mount and bulkhead brace that I seen in alum. I made a graphite one today. Very easy mod and cost basically nothing but time as I had an old graphite chassis from another car that is junk. The fan mount is pretty much like the COol Can version but made from Lexan plastic that I can just lift up and solder my motor in so it works great and to me is better than graphite because I would have to undo it ever time to solder my motor in so now I don't have to. I will get some pics tonight.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-12-2006, 07:54 PM   #2838
wyd
Tech Legend
wyd's Avatar
Ok a pic of the Cyclone.
Old 02-12-2006, 08:53 PM   #2839
nordheim's Avatar
Looks nice. Great job with the fans!
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 02-12-2006, 10:53 PM   #2840
nordheim's Avatar
Purple transponder holder for the ones who like the bling:
http://shopping.rcmodel.hk/product_i...oducts_id=3873
Old 02-12-2006, 10:58 PM   #2841
nordheim's Avatar
Where did you guys find the upper front bumper graphite support?
Old 02-13-2006, 12:15 AM   #2842
XrayFK's Avatar
Seems like it's out of stock from HPI...
http://www2.towerhobbies.com/cgi-bin...?&I=LXKHH0&P=7
http://www.speedtechrc.com/store/ebp...id=475&id=5491
https://www.ssl-stormerhobbies.com/c...ns&pn=HPI73086
Unless you go overseas:
http://www.precisionrc.com/nv/car/pr...oduct_id=12473
XrayFK is offline   Reply With Quote
Old 02-13-2006, 07:45 AM   #2843
XrayFK's Avatar
Another good weekend of racing, only finished one out of three qualifiers, but got 1st in the B-main.
Here's my setup, only still waiting for my ball diff to arrive.
Front
One-way
Camber: 2 degrees
Castor: 4 degrees block (3.2 total)
Toe: 0 degrees
Droop: 5mm
Ride Height: 4mm
Shock tower upper hole 2
Shock arm hole 2 (inside)
33lbs spring
Camber link position 4, 2mm spacer under
0.5mm spacer under FF block, 1.0mm spacer under FR block (-0.8 degrees)
1.4mm stabilizer
Rear
Diff
Camber: 2 degrees
Toe: 1.5 in
Droop: 5mm
Ride Height: 4.3mm
Shock tower upper hole 3
Shock arm hole 3 (inside)
28lbs spring
Camber link position on rear hub 2 (outside)
0.6mm spacer under RF block, 0.5mm spacer under RR block (0.2 degrees)
Tires
Jaco Dbl Pink/Orange front (paragon on inside)
Jaco Dbl Pink rear
Misc
Ackerman: 4.0mm
Steering knuckle hole 2
F Sus.arm spacer rear 2.0mm
R Sus.arm spacer front 2.0mm
R Upright spacer front 2.0mm
Note: I don't use the two middle screws for the rear graphite top plate that holds in the layshaft. Somehow I worked out that without those two, my car doesn't tweak as much.
Old 02-13-2006, 08:01 AM   #2844
rc-zombies's Avatar
that will only fit the Pro4.
Old 02-13-2006, 08:38 AM   #2845
wyd
Tech Legend
wyd's Avatar
Thanks. Pretty easy to make from Lexan plus like I said alot easier to get the motor soldered in and out since I can lift it up out of my way.
Old 02-13-2006, 09:36 AM   #2846
rc-zombies's Avatar
nice...
on mine and my pro4 as well..
I use the 3-racing clipon heatsink with fan.
less than $10 shipped from ebay.
http://cgi.ebay.com/3RACING-ALUM-540...QQcmdZViewItem
Old 02-13-2006, 09:43 AM   #2847
wyd
Tech Legend
wyd's Avatar
Originally Posted by rc-zombies
nice...
Thanks. I had the double fans from use on another car so I thought I would reuse them with a new mount. Just couldn't justify 50 bucks for the graphite setup with fans. Mainly because of having the fans. The lexan setup was a bonus the first time I soldered in the my first motor.
Old 02-13-2006, 09:45 AM   #2848
jland's Avatar
Trader Rating: 74 (100%+)
Default Update?
I am looking to grab a cyclone but have a few ?
Has there been updates to the car, or an updated kit? (not the hara, just standard)
If so what parts have been upgraded or changed?
It seems alot of on-line shops have been out of stock for awhile, (in military over-seas, no local shop.)
so if the kit has been updated will the next batch that gets to the shops be the one? Any-one know when?
Parts suppy looks to be alittle thin, any good shops that have an good selection of parts?
Just don't want to fork over $400 to see an updated kit out next week.
jland is offline   Reply With Quote
Old 02-13-2006, 12:18 PM   #2849
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
No update as yet. Last I heard straight from the top was only Hara/Karn version will be out on May/April.. Online shops like Speedtech, Rcmodel & Precisionrc has parts galore if your after.
Try to get the front steel CVDs and the top deck brace to strengthen the car.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-13-2006, 12:26 PM   #2850
Originally Posted by JoeyE
Just looked at Hara's car here at RCS. It's not the new version or anything. He is using the box stock one(only that it's all purple). There is no new rear diff, support mount, etc that I see on his Cyclone. He's using Excel parts for the spool and the aluminum rear peice(were the graphite holds the mid gears). Other than that, everything is stock out of the box.
Hara said that there is a Hara and Surikarn Edition Cyclone. Out at the end of april(he is not sure though because he said that he did not work on this project).
MUCH MORE Racing is also here. Lots of MMR goodies!
Kyosho is here with thier new ride-lots of red bling. Looks really nice. TEAM MMR are all here practicing.
Race: Thailand International Touring car Championship 2006 February 16-18.
Where can I see these parts???
Hugo is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
