Old 02-09-2006, 05:38 PM   #2806
Regional Moderator
kumpol's Avatar
Originally Posted by Evicerator
Hey guys, just wanted to let you all know that I've been running this car for a few months now and would be glad to "help out" any if possible
I mostly run asphalt with rubber tires but I will be gearing up for the carpet nats over the next month or so so hopefully I can help out with those types of questions as well as soon as I get my feet with the car on foam tires
Hello Steve....
Do you use center one-way? Have you tried front spool on asphalt?
Is Charlie around? Say Hi to him
Thanks,
Kumpol
kumpol is offline   Reply With Quote
Old 02-09-2006, 09:40 PM   #2807
The Evicerator
danjoy-- This is pretty much what I have been running lately, hope this works for you:
front shock position #2
2.5 mm under inner camberlink
1.0 mm under front pivot
1.5 mm under rear pivot
2.5' pivot support
inner camberlink #1
1.5' camber
4' castor
5mm ride height
6 mm droop
one way diff (usually a spool outdoors)
1.4 mm sway bar (0 mm)
0.5 deg toe out
1.2 mm x 2 piston
40 wt
HPI white
black bladder
1 foam compensator
rear shock position #3
#1 outside camberlink position (0 mm)
1.5 mm under inner camberlink ballstud
1.5 mm under front pivot
3' pivot block
#1 camberlink
1.5' camber
5.3 mm ride height
6 mm droop
1.2 mm sway bar (0mm)
1.2 mm x 2 piston
30 wt oil
HPI pink spring
Black bladder
1 foam compensator
4mm ackerman spacing
at socal I usually run a yokomo E stratus, but outdoors most of the time I run the Ride Accord type B
Std hexes front and rear
Ft arm spacing 0.5 F/ 2mm R
Rr arm spacing 2mm F/05.R
Rr upright 2.75 F/0R
With a spool I oftentimes play with reducing rear toe in and with my sway bar stagger... maybe try a 1.2 mm sway bar in the front as well.
With stock motors you will probably be able to get away with less rear toe-in as well.. it's just going to depend on how much over-all bite you have
RC-Zombies -- Thanks, I'll be sure to look him up and pick his brain
Jag -- I'm interested in my take on it too I have a 3mm chassis for the car and installed an extra standoff directly under the front belt tensioner which made the car significantly stiffer... maybe not quite as stiff as it needs to be, but I have time to play with that...
Kumpol-- Most of the time I run I run the center one way...but outdoors most of the time I run a spool in the front with the locked center pulley
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-09-2006, 09:52 PM   #2808
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Thanks, will try it tomorrow and will let you know how it goes. I was also wanting to try front diffs with center one way. Would this be similar to running a spool?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-09-2006, 09:56 PM   #2809
The Evicerator
danjoy -- a front diff will drive easier off throttle than a one way provided that it is not too loose. However, you will more than likely suffer what's refered to as "diffing out" with a front diff which will result in less forward accelleration than either a front spool or a one way.
Steve Weiss
Old 02-10-2006, 12:19 AM   #2810
kfa
kfa's Avatar
Originally Posted by kfa
I ended up sanding down the red alu-mount from my Barracuda - drill a hole in the chassis, countersunk it and mounted the holder. Looks like a million! I'm not at alle worried about tweak and lost stability! After all it's carbonfiber
I'll post pictures when i get home.
//Kaare
Pictures! Ended up with the Alex Racing transponder mount.
//Kaare
Hot Bodies Cyclone-img_4442_resized.jpg   Hot Bodies Cyclone-img_4446_resized.jpg   Hot Bodies Cyclone-img_4447_resized.jpg
kfa is offline   Reply With Quote
Old 02-10-2006, 06:05 AM   #2811
Teddy's Avatar
Upper Bulkhead,last update.
http://www.precisionrc.com/shop/sh21/mmobj/HB70704.jpg
Teddy is offline   Reply With Quote
Old 02-10-2006, 09:14 AM   #2812
nordheim's Avatar
Originally Posted by Teddy
I have those already and they're much stronger than the kit ones. I had bent every one of the kit bulkheads and broken one so I changed them all.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 02-10-2006, 06:46 PM   #2813
Scott B's Avatar
Trader Rating: 43 (100%+)
Steve... I've got the car working well right now with some help from Mo and Aaron young. Still testing to see what works best with the stock chassis, Bmi's chassis won't be out for 3-4 weeks after the snowbirds and thats cutting it close to the nats.
Stocton has been doing some Sunday pratice's so you could come up Race Sat. and pratice sunday, here's the schedule.
http://www.rcracing.com/Race_Schedule_284.cfm
Here's my email if you want to hit me up with any questions..
scott_859@netzero.com
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 02-10-2006, 07:39 PM   #2814
Aurra Sing's Avatar
I will be working on a new Stockton setup as well starting tomorrow. I will post it right away.
Marc
Aurra Sing is offline   Reply With Quote
Old 02-10-2006, 07:40 PM   #2815
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
here is my Purple Cyclone with some of option parts
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 02-10-2006, 07:58 PM   #2816
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Sweet dude,where did you get the alloy roll bar holders from.Looking good!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 02-10-2006, 09:54 PM   #2817
The Evicerator
Thanks for the info scott!
I don't think I'll be making it up tomorrow... but I might go wild and drive up for sunday's practice session... depends on how fired up I am after racing tomorrow at socal and how much work I get done on the carpet car...
I'll be in touch with you about some ideas that maybe you can try out!!
Steve Weiss
Old 02-11-2006, 12:21 AM   #2818
Skill's Avatar
Nice car! Why do you have a screw partly screwed into the top of the steering knuckles?
Skill is offline   Reply With Quote
Old 02-11-2006, 12:41 AM   #2819
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Seems the screw has no use at all.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-11-2006, 03:18 AM   #2820
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
We asked hara the same thing when he was down here, he said its a good way to avoid loosing your motor screws
FUK_WRX is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
