Old 02-07-2006, 05:18 PM   #2791
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by nordheim
Like the other people said, I used leftover lexan from a new body I cut out and put some carbon fiber decal sheet on top. Apply some servo tape on one of the sides, stick it down on top of your servo and you have a transponder mount. If you use personals, apply it on the underside of the holder. If you use a house transponder, use your body reamer to make a hole and clip it on the underside.
Works great!
Here's mine.
I did the same exact setup and it works and looks great. Takes about 5 minutes and your done.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-07-2006, 07:09 PM   #2792
Xray also uses a plastic transponder mount that may work ....
duckman996 is offline   Reply With Quote
Old 02-08-2006, 12:17 AM   #2793
kfa
kfa's Avatar
Originally Posted by rc-zombies
this might fit the cyclone...unfortunately it's only
available in Asia and it blue...
I ended up sanding down the red alu-mount from my Barracuda - drill a hole in the chassis, countersunk it and mounted the holder. Looks like a million! I'm not at alle worried about tweak and lost stability! After all it's carbonfiber
I'll post pictures when i get home.
//Kaare
kfa is offline   Reply With Quote
Old 02-08-2006, 08:35 AM   #2794
nordheim's Avatar
kfa, where are you located?
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 02-09-2006, 01:56 AM   #2795
kfa
kfa's Avatar
Denmark, why?
//Kaare
Old 02-09-2006, 05:46 AM   #2796
tc3 racer sc's Avatar
Default cyclone at the birds
well i had to lay down my cyclone at the birds, dont get me wrong it a good car and i love it, but i dont hve the thicker chasis such as 3.0 the car had way to much flex i can twist it by hand from the front tower to the rear, i made the switch over to hpi pro4 for carpet so any one know when a stiffer chasis coming tried the hara set up to twitchy any body has a good set up the traction is very high at the snowbirds
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 02-09-2006, 07:54 AM   #2797
jag88's Avatar
I'm very interested to see what Jason (BMI) will come up with for this car.
jag88 is offline   Reply With Quote
Old 02-09-2006, 08:15 AM   #2798
nordheim's Avatar
Originally Posted by kfa
Denmark, why?
//Kaare
I noticed your name. I was born and raised in Norway. Moved to the US in 97.
Old 02-09-2006, 10:57 AM   #2799
kfa
kfa's Avatar
Ahh.. Hence your boardname.. My first as well as my surname is norwegian - my great great grandparants emigrated from Norway to Denmark.
Folk fra skandinavien må vist stå sammen for tiden og holde lav profil, med tanke på det der sker nede syd på :-)
//Kaare
Old 02-09-2006, 11:30 AM   #2800
nordheim's Avatar
//Kaare
Kåre, you have a pm.
Old 02-09-2006, 12:24 PM   #2801
robk's Avatar
Trader Rating: 22 (100%+)
I'm pretty sure Jason from BMI said the chassis would be out in 3-4 wks after snowbirds. Isn't he racing at the Snowbirds as well? Try to find him and ask...
ps try stacking 2 topdecks together, or dremel a top deck if you can find some graphite. It doesn't have to be pretty as long as the screw hole line up correctly.
Old 02-09-2006, 03:51 PM   #2802
The Evicerator
Hey guys, just wanted to let you all know that I've been running this car for a few months now and would be glad to "help out" any if possible
I mostly run asphalt with rubber tires but I will be gearing up for the carpet nats over the next month or so so hopefully I can help out with those types of questions as well as soon as I get my feet with the car on foam tires
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-09-2006, 04:00 PM   #2803
rc-zombies's Avatar
Contact Scott B
He's been running the cyclone at Stockton.. he can help you with set-up.
Old 02-09-2006, 04:18 PM   #2804
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Got any setup on asphalt using Sorex 36 with C-Med insert? I prefer not using traction compounds and track has long a long straight and highspeed corners. Motor will be stock 27 turn.
Also track is untreated (no VHT) and is semi rough asphalt, not smooth.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-09-2006, 04:24 PM   #2805
jag88's Avatar
Sounds like the chassis is a bit soft for carpet. Interested in your take on this car with foams.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
