Old 01-18-2006, 01:37 PM   #2506
The Teacher's Avatar
Trader Rating: 47 (100%+)
I haven't had a problem with my shock caps.....
The Teacher is offline   Reply With Quote
Old 01-18-2006, 01:56 PM   #2507
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Guess I will have to pay extra attention to them and see what happens.
Old 01-18-2006, 04:37 PM   #2508
protc3's Avatar
my shock leaked a slight bit around where the plastic eyelet comes through the cap.it turned out that i had a slight bit too much oil in the shock.you need to make sure that you put the bladder in seperately.make sure when you lay the bladder in the shock that it is properly seated and does not push up.if it pushes up, lightlypush it down around the top edge and you should see some oil leak out.let the bladder displace the oil.once it sits flat then you can install the cap.leaking should be gone.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-18-2006, 04:49 PM   #2509
wyd
Tech Legend
wyd's Avatar
protc3 did you use 2 bearings in the diff like many did or build the cars diff in the stock configuration? Can't wait to hear your report after this weekends race.
Teach how did you build your diff?
Old 01-18-2006, 04:51 PM   #2510
rc-zombies's Avatar
if you want a smoother diff build it with 2 bearings...
Old 01-18-2006, 04:52 PM   #2511
protc3's Avatar
i built it like the instructions said.i was wondering why i had an extra bearing.
my diff works real nice though.smoothe as ever
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-18-2006, 04:53 PM   #2512
wyd
Tech Legend
wyd's Avatar
rc-zombie I will go for the two bearing setup. Is it Friday yet!!!!!!!!!
protc3 thanks. Good luck this weekend.
Old 01-18-2006, 05:06 PM   #2513
tc3 racer sc's Avatar
yeah it wrk better with the 2 bearings that spacer u dont need
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 01-18-2006, 06:51 PM   #2514
protc3's Avatar
i just put the 2nd bearing in the diff.it seems to be a little more free.thanks for the heads up zombies.
i cant wait until this weekend.1st outing with the cyclone in mod.i just finished strapping in my checkpoint 7x1.i just realized that you need to change to a bigger spur to run mod.i went with a 104 tooth RW and i am ready to go again.i went with haras asphalt setup from the nats.i got a good feeling about this.the car had so much steering in 19 turn.i hope it has that steering in mod.if so i think im gonna do real well.we got some serious competition down here in mod so i dont want to get too optimistic.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-18-2006, 08:50 PM   #2515
nordheim's Avatar
that's the Avatar I was looking for zombies, although your model for the previous one wasn't bad at all!
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 01-18-2006, 09:38 PM   #2516
rc-zombies's Avatar
max spur you can install is 108T that you may want to try.
Old 01-18-2006, 09:39 PM   #2517
rc-zombies's Avatar
Old 01-19-2006, 12:27 AM   #2518
Teddy's Avatar
Originally Posted by JoeyE
My Cyclone shocks keep on leaking from the top. Is there something I could do to fix that or.....
Hi
You should put one or more washers 10x12x0.2mm above the 73510-2 (i don't know the name, check in the manual).
This will push down the bladder little bit more, and avoid the leak.
Teddy is offline   Reply With Quote
Old 01-19-2006, 04:17 AM   #2519
Have any of you noticed the flex in the shock towers?? My car seems to run fine but I have a boat load of flex in the shock towers.....
wyd, I used 2 bearings in the diff...
Old 01-19-2006, 06:21 AM   #2520
Doug D's Avatar
Trader Rating: 54 (100%+)
Damn Teach, running a Cyclone now?! Have you tried doubling up the shock tower? would probably take care of the flex issue...
Doug D is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
