Old 01-17-2006, 03:45 PM   #2476
protc3's Avatar
Originally Posted by HB
the cyclone diff is very bad
it allways get slipt
i rebuldit many many times
after a cupel run's it will slip again
after every 2 or 3 rebuilds on any of my diffs i always replace the locknut.once they have a screw run into them they will not hold as good anymore.i would replace the nut.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-17-2006, 03:53 PM   #2477
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by rc-zombies
Found what I was looking for. Man alot of reading on this thread. Been going thru old posts. I think I'm up to page 38.
Old 01-17-2006, 04:46 PM   #2478
nordheim's Avatar
hey zombies, have you found a post christmas avatar yet. kind of enjoyed your seasonal avatar updates
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 01-17-2006, 04:50 PM   #2479
lookinco's Avatar
Is there no rear stablizer bar in Hara carpet foam setup?
And where can I find a 2mm stablizer bar?
lookinco is offline   Reply With Quote
Old 01-17-2006, 05:47 PM   #2480
ngo8's Avatar
Send a message via ICQ to ngo8
make one
Xray|Kyosho|Exotek|Hobbywing|Sanwa|Trinity|Xpert|KoPropo
ngo8 is offline   Reply With Quote
Old 01-17-2006, 06:40 PM   #2481
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
someone really looking for a new car may i say Xray T2
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 01-17-2006, 07:01 PM   #2482
wyd
Tech Legend
wyd's Avatar
Gotta keep up my research. You might want one because a good amount of your Pro4 parts will fit this car.
Old 01-17-2006, 07:06 PM   #2483
blast's Avatar
true that true all so true
Patrick Connors
FTM Grip
Old 01-17-2006, 07:12 PM   #2484
wyd
Tech Legend
wyd's Avatar
Should be easy to get parts for because Horizon Distributors carry the parts and most hobby shops order from them. The fact that Pro4 suspension stuff fits is just making it that much easier to order parts.
Old 01-17-2006, 09:39 PM   #2485
raptor 700's Avatar
Does the cyclone tweak easy? If so what do you do to get the tweak out? thanks.
raptor 700 is offline   Reply With Quote
Old 01-17-2006, 10:04 PM   #2486
XrayFK's Avatar
Anyone have any suggestions for a setup: foam carpet, stock, with a front one-way. Thanks
XrayFK is offline   Reply With Quote
Old 01-17-2006, 10:33 PM   #2487
nordheim's Avatar
Take a look at these. These should be good bases to start with;
http://hotbodiesonline.net/set_ups.html or http://www.hpiracing.co.jp/contents/setup/hara.html
Old 01-17-2006, 11:16 PM   #2488
rc-zombies's Avatar
I do..but it might be too revealing...
have something new soon...
Old 01-18-2006, 04:20 AM   #2489
protc3's Avatar
i found that it does tweak pretty easy if you take a good smack to the walls.what i do is loosen the top deck screws and put it on my tweak station.i do not adjust the shock collars becuase its usually the chassis that has taken the twist.i will now just lightly twist the chassis with the car on my tweak station until it is right and then re tighten the top deck screws.they use component grade carbon fiber for the chassis and top deck so it does not have very much memory after it twists.it will need a little help getting back to straight again.it doesnt take long to do and this is not something to be alarmed about.most of the cars out there use the same material and need to be tweaked the same way.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-18-2006, 07:08 AM   #2490
Phil C's Avatar
Originally Posted by Atomix
Josh,I tried a Cyclone last weekend at IMCC (on rubber) and it was a pig. It certainly has excesses of understeer, but I was using the Pro4 2005 shocks on the car, im not sure that the shocks are the issue
Try adding 1mm spacers under the rear pivot blocks, As you say theres definately nothing wrong with the shocks.
Phil.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
