Old 01-12-2006, 06:24 PM   #2386
XrayFK's Avatar
Originally Posted by danjoy25
Can someone also clarify the following:
Raising the lower pivot blocks = less roll
Raising the camber link = more roll
Raising the camber links or lengthening them will keep the camber more constant during suspension travel, giving you more traction, but less stability.
XrayFK is offline   Reply With Quote
Old 01-12-2006, 07:22 PM   #2387
RayWarner's Avatar
Send a message via AIM to RayWarner
Originally Posted by Evicerator
*pokes his head in the door and looks around*
hmmm....
You know you want one!!! Just make a few calls!
RayWarner is offline   Reply With Quote
Old 01-12-2006, 08:27 PM   #2388
nordheim's Avatar
What size spurs and pinions are you guys using for stock racing?
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 01-12-2006, 08:49 PM   #2389
tandman's Avatar
Send a message via Yahoo to tandman
27 pinion, 81 spur for a monster stock on a tight carpet track with 58.5mm tires.....oh yeah...with f-brush
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-Rcamerica
tandman is offline   Reply With Quote
Old 01-12-2006, 08:53 PM   #2390
nordheim's Avatar
you running 48 pitch?
Old 01-12-2006, 10:10 PM   #2391
ngo8's Avatar
Send a message via ICQ to ngo8
64 pitch here dependeing on tire size always run like 58mm so like 33/107 on medium size track depending on how tecknical the layout is .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-12-2006, 11:38 PM   #2392
How do you get the chatter out of the spool put it in ran on bench could bearly turn wheels chattered so bad took it back out afraid to run it already bending outdrives bad enough that I am having a hard time getting bearings off?
no1uno is offline   Reply With Quote
Old 01-13-2006, 05:54 AM   #2393
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
my kit came with 2 holes pistons allround, not sure if its 1.1 or 1.2 mm.
Whats the main difference in cornering with running a front diff with a center oneway?
Has anyone notice hara set up sheets only showing 4 holes for the rear shock towers but the kit actually comes with 5?
if the pistons that come with the original kit are 1.2 2holes.
the setup sheet actually they have make an error and they have correct it already.
raising the lower pivot blocks = more roll especially it work on the asphalt with low traction.
raising the camber link = less roll will get more off power steering but will have a little bit less of on power steering
correct me if i given wrong explaination
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 01-13-2006, 07:22 AM   #2394
Trader Rating: 26 (100%+)
Anyone know if these Square parts for the Cyclone is for sale now or when it will be released?
JoeyE is offline   Reply With Quote
Old 01-13-2006, 07:26 AM   #2395
Trader Rating: 16 (94%+)
yes, I already have the bulkhead and the middle plate fitted to my car
you can order them from champ rc
domo is offline   Reply With Quote
Old 01-13-2006, 11:28 AM   #2396
Guo Chean's Avatar
i already release to Japan market since dec 2005
Old 01-13-2006, 11:32 AM   #2397
rc-zombies's Avatar
got pics...
Old 01-13-2006, 04:47 PM   #2398
XrayFK's Avatar
Originally Posted by rc-zombies
you can also replace the stock aluminum front bones to the new steel ones.
the Tamiya Tb-02 42mm steel bones will fit as well and cheaper too.
What part of the bone is measured to get the 42mm? The total length of the stock front bone is almost 50mm.
Old 01-13-2006, 07:04 PM   #2399
jag88's Avatar
Sorry if this has already been asked....... but do 3800's fit in this chassis ?
Thanks !
jag88 is offline   Reply With Quote
Old 01-13-2006, 07:15 PM   #2400
Guo Chean's Avatar
Thanks !
sure fit
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
