Old 01-11-2006, 03:49 AM   #2356
Stew Noble's Avatar
Originally Posted by Hugo
Which brand is the 8. Shock slime from???
Number 8, is X-Gear Shock Slime
Number 9 is definatly a much more product, either:
CHE-SS - Shock Slime (5g)
CHE-TG - Thrust Grease (5g)
CHE-JG - Joint Grease (5g)
CHE-DG - Diff Grease (5g)
my guess is its the joint grease....
Stew
// S N F //
Stew Noble is offline   Reply With Quote
Old 01-11-2006, 05:15 AM   #2357
XrayFK's Avatar
Stew
It didn't get translated, but #9 only says "Low Friction Grease." Doesn't specify much.
XrayFK is offline   Reply With Quote
Old 01-11-2006, 05:25 AM   #2358
Frank McKinney's Avatar
Originally Posted by JonboyGB
...just thinking. With regards the ackerman. If I go less than 4mm would I get more or less steering?
http://www.rccartalk.com/ackerman.html
Just a basic description of what more/less Ackerman will get you. For the most part very few people mess with Ackerman angles, at most you might see top-level racers changing the steering knuckle link locations.
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 01-11-2006, 05:59 AM   #2359
JonboyGB's Avatar
Thanks for that Frank. Most helpful.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 01-11-2006, 02:33 PM   #2360
ngo8's Avatar
Send a message via ICQ to ngo8
Took the Cyclone out onto carpet last night for the first time - OMFG!
What a car. Only problem I had was the steering, there is tonnes of it! I turned the little knob down all the way on my controller to reduced the steering but there was still too much.
I think the main problem is me. Iím so used to the Pro4 and know when the right time to start turning in is, but it is about a metre to soon compared with the Cyclone. A bit more practice and this should be addressed.
I remember reading on this thread a while back, that some of you have moved the top of the front shocks in to reduce the steering sharpness, would that be correct? I currently have the top of my shocks in hole three (outside in) What do you guys do?
Cheers Ears.
Oh yeh, first impression of the Cyclone on carpet, Fan-bloody-tastic!! Roll on next Tuesday.
you can put a 1.5 degree or 2 degree or even 0 front block to make the steering less agressive if you want and i agree with you What a car on carpet with foams you might run with rubber ?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-11-2006, 03:43 PM   #2361
JonboyGB's Avatar
Thanks ngo8
Will try changing the front pivot as suggested next week.
BTW that run was on rubber! Iíve never raced with foams.
Cheers dude
Old 01-11-2006, 07:49 PM   #2362
RayWarner's Avatar
Send a message via AIM to RayWarner
Can anyone give me a link to some good rubber tire setups? Thanks!
RayWarner is offline   Reply With Quote
Old 01-11-2006, 08:47 PM   #2363
tandman's Avatar
Send a message via Yahoo to tandman
The HotBodies site has Hars setups on it....a good place to start.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 01-11-2006, 09:16 PM   #2364
RayWarner's Avatar
Where can I find the TiR worlds cvd set?
Old 01-11-2006, 09:26 PM   #2365
nordheim's Avatar
http://shopping.rcmodel.hk/product_i...oducts_id=6867
I have them. They're nice although I have snapped one of the axles after a hard hit.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 01-11-2006, 09:29 PM   #2366
nordheim's Avatar
http://hotbodiesonline.net/set_ups.html
I run the Reedy Race setup. Works well.
Old 01-11-2006, 09:35 PM   #2367
ngo8's Avatar
i just ran rubber on carpet for like the first time we only run foam here but i am practiseing for an upcoming race so i copyed haras set up from vegas race with some exceptions and the car is awesome its pretty hooked up do you guys run oneways on carpet with rubber tires or a diff i tryed oneway and it was pretty cool .
Old 01-11-2006, 09:51 PM   #2368
ngo8's Avatar
this is what i ran today and that on a technical tight track
Front
Shocks:
HPI gold springs
45wt Shock oil
3rd hole at the top
Outer hole at the bottom
Droop 5 mm
Silver roll bar
1.5 pivot block Front
1mm spacers ff- 1.5fr (under blocks)
2mm spacer under the camber link
Oneway
REAR
Shocks:
HPI silver springs
45wt
3rd hole at the top
Middle hole at the bottom
Droop 4mm
silver roll bar
3.0 pivot block
1.5mm spacers f+r (under blocks)
1mm spacer under the camber link
Standard diff and center oneway
Old 01-11-2006, 11:47 PM   #2369
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Front
45wt Shock oil
Oneway
REAR
45wt
3.0 pivot block
so you ran: Front One-way, Center One-way, Rear Diff?
what pistons? kit 3x1.1?
what class? if its not mod you can probably run 2.5 rear toe block.
Also given the spacing under the pivot blocks, you may be able to run more shims under your camber links. I am guessing that Hara ran very low spacing because of the massive traction at IIC. So you probably can run more spacers to increase cornering.
But yes one-way is recommended for rubber tires (asphalt and carpet). You should only need diff on carpet with foams.
floodo1 is offline   Reply With Quote
Old 01-12-2006, 01:14 AM   #2370
JonboyGB's Avatar
a lot of the guys I know use a diff up front as the tracks are generally quite small and technical. Outdoors on asphalt, its mainly spools with the top guys using one-ways.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
