Hot Bodies Cyclone
#2342
Originally Posted by John Doucakis
1. Preparation item, carbon material edge processing
2. Diff. assembly, center shaft assembly
3. The belt it turns and attaches, the foot turns and attaches 1
4. The foot it turns and attaches 2, adjustment
5. Shock assembly
6
6 is 'mechanic loading' ??
#2343
Well,
This was post 1 out of 6 as can be seen at the last paragraph of my previous post.
So we should expect more building tips coming up soon..
Which brand is the 8. Shock slime from???
#2344
much more
#2345
I think N°9 is Much more, but N°8 must be an other brand???
Which brand make DIP tyre additive???
#2346
Hugo > nice name
#2347
hybrid make dip tyre additive aswel as lots of other things like greses etc.
Gower
#2348
Thanks a lot Agower, you've answer my question.
Hugovdb
Hugovdb
#2349
New to the Cyclone, anyone have a pdf of the manual? Thanks.
#2350
Took the Cyclone out onto carpet last night for the first time - OMFG!
What a car. Only problem I had was the steering, there is tonnes of it! I turned the little knob down all the way on my controller to reduced the steering but there was still too much.
I think the main problem is me. I’m so used to the Pro4 and know when the right time to start turning in is, but it is about a metre to soon compared with the Cyclone. A bit more practice and this should be addressed.
I remember reading on this thread a while back, that some of you have moved the top of the front shocks in to reduce the steering sharpness, would that be correct? I currently have the top of my shocks in hole three (outside in) What do you guys do?
Cheers Ears.
Oh yeh, first impression of the Cyclone on carpet, Fan-bloody-tastic!! Roll on next Tuesday.
Cheers Ears.
#2351
As far as I am aware, there is nothing available on the net. Only set-ups sheets.
#2352
What setup are you using? At the moment I am using the standard springs and just the front roll bar, and maybe a couple of slight differences on the shock positions to the stock setup and it works well. Just wondering whether it needs stiffening up a bit though...
#2353
Hello, set-up is ...
FRONT
Shocks:
HPI White springs (20.3)
40wt
3rd hole at the top
Outer hole at the bottom
Silver roll bar
2.5 pivot block
1mm spacers f+r (under blocks)
2.5mm spacer under the camber link
Standard diff
REAR
Shocks:
HPI Pink springs (18)
30wt
3rd hole at the top
Middle hole at the bottom
Copper roll bar
3.0 pivot block
2mm spacer under the camber link
Standard diff
Centre pulley is all locked.
Ackerman is as kit setting.
Ride height is 5mm (not allowed to go lower - club rules)
#2354
...just thinking. With regards the ackerman. If I go less than 4mm would I get more or less steering?
#2355
pretty sure you will get more.
