Old 01-09-2006, 11:56 AM   #2311
ngo8's Avatar
Send a message via ICQ to ngo8
Originally Posted by XrayFK
I guess I will have to piece together a diff then.
So then for the CVDs, should I go for the TiR ones or the HB Steel set? Or just stick with the stock ones? Thanks.
BTW, this is for carpet (stock and 19T).
yeah man you have to use a diff in the front for foam carpet racing its the only way youre car will thank you and youre pocket to
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-09-2006, 12:52 PM   #2312
rc-zombies's Avatar
Originally Posted by Smartypants
Does anyone have a link to a website which has blank setup sheets for the cyclone??
Can't seem to find any on the Hotbodies website??
Matt
I have a blank interactive pdf version that I made...1.3mb
pm me with your email.
Old 01-09-2006, 12:54 PM   #2313
rc-zombies's Avatar
Originally Posted by dontfeelcold
Late January, early February is the current release date.
where are you getting this info from...?
lhs says there is no info on the new kits..
Old 01-09-2006, 01:14 PM   #2314
XrayFK's Avatar
Alrighty, ball diff it is. Now, how different are the Pro4 outdrives? Has anyone compared the two side to side?
XrayFK is offline   Reply With Quote
Old 01-09-2006, 01:17 PM   #2315
rc-zombies's Avatar
It's been done early on when the car was released....
you'll need about 3 - 3.5mm of shimms on both sides...
cheaper to buy the stock Delrin outdrives.
Old 01-09-2006, 01:19 PM   #2316
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Im also considering making a ball diff instead of the spool. So the pro 4 diff halfs can be use is what you are saying but must be shim.
So if I can get a complete Pro 4 ball diff set and replace the stock pulley with
A495 39t Ball Diff Pulley and lots of shims it will work.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 01-09-2006, 05:59 PM   #2317
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
if you build it ....... it will work
S-T-R-l-K-E-R is offline   Reply With Quote
Old 01-09-2006, 06:23 PM   #2318
XrayFK's Avatar
Does anyone know is these will fit as thrust balls in the diff? http://shopping.rcmodel.hk/product_i...oducts_id=5689
Doesn't say what size they are, just thrust.
Old 01-09-2006, 06:39 PM   #2319
pucho's Avatar
Send a message via AIM to pucho
Just get Associated balls they work.
For the P4 outdrives to work you also need to use the CVD's the Cyclone bones are too short. It's really more of a hasel than anything. I did it because I had the parts available. But I ended up buying the Cyclone outdrives after all.
pucho is offline   Reply With Quote
Old 01-09-2006, 07:07 PM   #2320
XrayFK's Avatar
I thought you just need to shim the outdrives? Also, if you have to use the HPI bones, do you need the Pro4's universal axle as well, or will the HB ones fit fine with the HPI bone?
Old 01-09-2006, 08:14 PM   #2321
rc-zombies's Avatar
not just shimming... the Pro4 outdrives are also shorter. thus the need for longer bones..
pm me if you're interested in Pro4 steel bones that will fit the Cyclone axles with no mods. I have a NIB Pair available for sale...
Old 01-09-2006, 08:22 PM   #2322
XrayFK's Avatar
Okay, to recap here... for a ball diff I put together all the HPI internal parts with the pulley, and if I use the Pro4 outdrives then I have to use shims and also the HPI bones? (which will fit fine with the HB axles?)
Does that mean that the Pro4 axles (so an entire Pro4 CVD) will fit on the Cyclone if using the Pro4 diff outdrives.
Sheesh, what a hassle either way.
Old 01-09-2006, 08:52 PM   #2323
rc-zombies's Avatar
the Pro4 bones are MIPS and will not fit the Cyclone's Cv's
but if you take the entire MIP axle and Mips bones from the Pro4..they will fit the Cyclone.
the Pro4 bones that I'm selling are made for the cyclones axles...they are approx 2mm longer than stock.
make it easy on yourself and just get the cyclone outdrives.
Old 01-09-2006, 09:05 PM   #2324
XrayFK's Avatar
I will probably end up just getting the cyclone outdrives, now I just want to know for the sake of knowing
So there are also Pro4 bones that made for the cyclone axles? Are those the HPI Hard Steel Dogbones?(part # 75186)
Old 01-09-2006, 09:45 PM   #2325
ngo8's Avatar
its not a hassle just go to youre Manual and build the rear diff for the front part numbers are there simple dont bother with pro4 parts for diffs
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
