Old 01-02-2006, 06:24 AM   #2221
Originally Posted by pucho
Jason, I took a little closer inspection and some scres don't exactly sit flush with the chassis. Im going to start there. Can you tell me what degree countersink bit works good for a standat FH 3mm screw.
BTW. anything coming from you for the Cyclone? I be willing to lend you my car for prototyping
I believe he is not talking about them not sitting flush with the chassis but more them not running square to the shank of the screw? The head if offset slightly to the thread?
Rick Draper is offline   Reply With Quote
Old 01-02-2006, 07:07 AM   #2222
pucho's Avatar
Send a message via AIM to pucho
Yes I understand that, but a reason it's not sitting flush on the board it's because the heads anrn't sitting flush with the chassis as some one mentioned earlier. The only way to solve that is to hit it with a countersink bit.
pucho is offline   Reply With Quote
Old 01-02-2006, 10:21 AM   #2223
protc3's Avatar
90 degree countersink will be the one you want.i have ordered a cyclone and i think we will see a kit for this car very soon.i really like the cyclone.after i drove it i wanted it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-02-2006, 11:52 AM   #2224
did i read on here somewhere that hotbodies are releasing slimmer pulleys? if so does anyone have any part numers for them.
Cheers
Smartypants is offline   Reply With Quote
Old 01-03-2006, 06:03 AM   #2225
JonboyGB's Avatar
Hello Smartypants!
I understand there are slim pulleys coming sometime this year, as well as thicker shock towers. Iíve spoken to Mirage here in the UK about release dates, but they are yet to hear anything.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 01-03-2006, 07:31 AM   #2226
pucho's Avatar
Jason:
Let me know if I can help you in any way.
Luis
Old 01-03-2006, 11:09 AM   #2227
many thanks for the reply Jon
Old 01-03-2006, 12:26 PM   #2228
lookinco's Avatar
I just recently got my cyclone and am very happy with it.
What kind of hop ups is avaliable and is worth upgrading?
Where can I find titanium screws? Is it a good idea to change to aluminum suspension parts?
Are there any tips and tricks to make the car even better?
I am new so any help is greatly apprecaited.
lookinco is offline   Reply With Quote
Old 01-03-2006, 12:49 PM   #2229
pucho's Avatar
Hop ups, not really thath I can think of. The track where I race ir small and you use tons of brakes so I built a second diff and got a spool, also got the fixed 16 tooth pully for the laylshaft. You need to machine some material off the chassis where the front belt exits, the belt to chassis clerance it tight. Aluminum is just going to make your car heavier in the wrong place, you always want to keep the suspension as light as posible. build it and go have fun!
Old 01-03-2006, 12:59 PM   #2230
Skill's Avatar
Not too sure I agree with you there. By having more weight on the hubs you put more force on the tyres, but don't really raise the centre of gravity as the weight is on the suspension.
Skill is offline   Reply With Quote
Old 01-03-2006, 01:01 PM   #2231
ChrisP's Avatar
Send a message via Yahoo to ChrisP
weight anywhere on the car increases weight on the tires...unspring weight (at the tires) makes the suspension react slower...
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-03-2006, 06:14 PM   #2232
lookinco's Avatar
I guess it's in a way a good thing that the cyclone doesn't need much hop ups to run good.
What parts get broken easily? I want to stock up on those.
Old 01-03-2006, 06:59 PM   #2233
XrayFK's Avatar
Here are a few pics of my Cyclone. This car sits very low compared to some other cars.
Hot Bodies Cyclone-dsc00323.jpg   Hot Bodies Cyclone-dsc00324.jpg   Hot Bodies Cyclone-dsc00325.jpg
XrayFK is offline   Reply With Quote
Old 01-03-2006, 07:06 PM   #2234
ChrisP's Avatar
You may have troulbe passing thru tech with that ride height
TeamXray.com
Team Tekin
Old 01-03-2006, 07:09 PM   #2235
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
CofG is calculated INCLUDING the suspension.
also aluminum suspension components are heavier and therefor increase unsprung weight, which is bad.
as i've posted over in the pro4 thread, aluminum suspension pieces should only be used in 2 situations:
1) plastic parts have excessive slop which cant be remedied
2) plastic parts break too frequently.
basically only run aluminum if you have to.
floodo1 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
