Old 12-31-2005, 07:59 PM   #2206
Trader Rating: 26 (100%+)
Has anyone used the graphite side body peices from Shooters? I just ordered a set and wondering if it would be better to use or just stay withe mounts on the shock towers.
JoeyE is offline   Reply With Quote
Old 12-31-2005, 08:41 PM   #2207
FRP
Default cyclone
does the kit comes with a center one way? when i move the front wheel forward the center pully is not pulling the rear belt.
FRP is offline   Reply With Quote
Old 12-31-2005, 09:42 PM   #2208
tandman's Avatar
Send a message via Yahoo to tandman
Yeah it has a centre one way pulley.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-Rcamerica
tandman is offline   Reply With Quote
Old 01-01-2006, 06:20 AM   #2209
try pulling the front belt forwards by itself..
agower is offline   Reply With Quote
Old 01-01-2006, 06:43 AM   #2210
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
You might have installed it incorrectly, HB made a mistake in the manual. Just pull out the spur gear/pulleys assembley and spin it 180 degrees.
dontfeelcold is offline   Reply With Quote
Old 01-01-2006, 07:26 AM   #2211
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
you might out the one way pulley on the wrong side.. did you looked at the supplement that came with the manual ?
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 01-01-2006, 08:59 AM   #2212
John Doucakis's Avatar
Also posted on the "Your Custom Paintjobs" forum, my new Protoform Stratus 3.0 AP body.
It's simple design. Hope you like it.
Hot Bodies Cyclone-img_2998b.jpg   Hot Bodies Cyclone-img_2995b.jpg   Hot Bodies Cyclone-img_2997b.jpg   Hot Bodies Cyclone-img_2996b.jpg
John Doucakis is offline   Reply With Quote
Old 01-01-2006, 09:31 AM   #2213
Phil C's Avatar
Yes the car does come with a 1way centre pulley. If you pull the front belt forwards the rest of the layshaft should stay still like you described.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 01-01-2006, 10:16 AM   #2214
FRP
Default tech question
would a center one way work with spool in the front?
Old 01-01-2006, 11:08 AM   #2215
XrayFK's Avatar
Technically it would work fine, as the center one way will function perfectly. However from a tuning standpoint, no, it doesn't make much sense. The center one way doesn't give you any brakes up front, which is one of the main advantages of a spool.
XrayFK is offline   Reply With Quote
Old 01-01-2006, 03:57 PM   #2216
nordheim's Avatar
As dontfeelcold said, the manual was incorrect from HB. You need to spin the center diff 180, which puts the carbon plate on your spur gear on the motor side.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 01-01-2006, 03:58 PM   #2217
nordheim's Avatar
Looks nice. I like the colors.
Old 01-01-2006, 04:38 PM   #2218
FRP
yes i got it working now, no wonder it feels weird when I built it.
thanks guys!!
Old 01-01-2006, 09:41 PM   #2219
EvilDriver's Avatar
looks nice john.. very nice..
Old 01-02-2006, 04:23 AM   #2220
pucho's Avatar
Send a message via AIM to pucho
Originally Posted by protc3
luis,
another thing i would check is all the screws that mount to the chassis.i have had screws that the heads ran eccentric to the threads.i usually replace the screws on the car when i have tweak issues that wont go away.9 out of 10 times it does it.
Jason, I took a little closer inspection and some scres don't exactly sit flush with the chassis. Im going to start there. Can you tell me what degree countersink bit works good for a standat FH 3mm screw.
BTW. anything coming from you for the Cyclone? I be willing to lend you my car for prototyping
pucho is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
