Old 12-28-2005, 02:07 PM   #2191
Antonio Sabato's Avatar
Originally Posted by Victor A
There is no HB Cyclone surikarn edition . That picture from rczone.net was a fake one.
oN tihS!
I would say more like 99.9%
Antonio Sabato is offline   Reply With Quote
Old 12-29-2005, 02:12 AM   #2192
pucho's Avatar
Send a message via AIM to pucho
Angry
I am having what I consider a serious problem. My chassis seem to be tweaked and I canít figure out the cause. Even with all the components loosened up on the car it is still tweaked. I checked the chassis and bulkheads individually and they all checked out ok Itís when itís all together that itís a problem. Where talking enough to rock the chassis from side to side. Believe me Iím not crazy here and where not talking about a rookie here I know my mechanics just to give you a little info on myself, Iím the guy who builds Alex Lopezís, of Team Xray, Cars. This is really pissing me off that a $400+ car is not perfect from the factory.
Please let me know if anyone else is having this problem.
pucho is offline   Reply With Quote
Old 12-29-2005, 03:02 AM   #2193
are the screws on the bottom of the chassis level with the chassis or do the heads stick out abit from the countersinking? i no that on most cyclones the countersinking isnt deep enough so the screw heads stick out causing the chassis to not seem flat.
agower is offline   Reply With Quote
Old 12-29-2005, 04:14 AM   #2194
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Whenever I untweak my cyclone (once or twice in the 5 times Ive run it, its very resiliant to tweaking) I put it on droop blocks and position the droop blocks where there are no screws.
My friend bent the motor mount on his cyclone and the chassis still pulls down flat.
dontfeelcold is offline   Reply With Quote
Old 12-29-2005, 06:35 AM   #2195
AdrianM's Avatar
No one can solve this but you. Start with the lower chassis and start putting on one thing on at a time and checking tweak after each component goes on until you find the one part that causes the tweak.
It could be as simple as one screw hole on one alloy part that is crooked due to a part shifting in a CNC machine. There is no way a quality control person could spot a screw hole being off a few thousandths.
Once you find the problem I am sure HB will take care of it.
This happened to my Mi2's two years ago and it it ended up being a rear diff housing that had a top deck mounting pad that was a few thousandths low. It could have been some momentary tool chatter or an interruption in cooling oil flow that caused it. I had never seen it before and have never seen it happen since.
I asked myself to warranty the part for myself and I did...lol!
Adrian Martinez
Old 12-29-2005, 07:02 PM   #2196
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
it pays to know the right people!
floodo1 is offline   Reply With Quote
Old 12-30-2005, 09:09 AM   #2197
pucho's Avatar
Adrian: I am really stumped on this one! Im just goign to take the whole thing apart again.
Old 12-30-2005, 03:36 PM   #2198
tc3 racer sc's Avatar
louis i never had a tweak justt tke ur time brotha im going to run mines tomorrow with the spool ran good on carpet cpls weeks ago cya reggie
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 12-30-2005, 04:05 PM   #2199
Default gearing 19 turn
what a good gear ratio for the cyclone 1oo spur for 19 turn thxs
Old 12-30-2005, 04:47 PM   #2200
ngo8's Avatar
Send a message via ICQ to ngo8
why dont you take the top deck off and then see if its tweaked also is the chassi completly flat? on a board i run on carpet with foams and the car never gets tweaked and i always check after each run there must be something there youre missing .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-30-2005, 07:38 PM   #2201
anyone knows whether the bodypost position is the same as the Pro4?
formosa008 is offline   Reply With Quote
Old 12-30-2005, 08:33 PM   #2202
ngo8's Avatar
yeah its the same maybe off by a hair but very close
Old 12-30-2005, 11:06 PM   #2203
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
On a high speed track you can go as far as 5.8-6.2 FDR using 42T to 39T.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 12-31-2005, 10:14 AM   #2204
tandman's Avatar
Send a message via Yahoo to tandman
Anyone know where I can get a 3mm chassis for the Cyclone that does not have the battery slots milled all the way through??
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 12-31-2005, 11:09 AM   #2205
protc3's Avatar
luis,
another thing i would check is all the screws that mount to the chassis.i have had screws that the heads ran eccentric to the threads.i usually replace the screws on the car when i have tweak issues that wont go away.9 out of 10 times it does it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
