Hot Bodies Cyclone
#2103
Isn't that a similar design to the original? There must have been a reason for changing to the curved piece, I wonder why they've gone back to the straight bit?
#2104
#2105
Buyer Beware
Originally Posted by rc-zombies
my Purple Version arrived last week...
#2106
Originally Posted by Hollowman
New Version My Ass (one really pissed out dude over here)
come on people the version isn't that exciting, just look at the hop - ups only Nr. 6 & 12 are interesting and i think that 6 is the shooters motor mount brace but i don't know.
and we don't race spools in Holland so waste of money and come on alu servo mounts that's 15 euro's about 20 dollars, and thicker shock towers Why ?? but i am curious about the blue version it will be one hell of a MSX wannabee. i want to see a battery bar and the multi-flex system i want it to compete against the new x-ray .
But if i don't like the black any more i am gonna make my one Florian Spec cyclone that will be all green with a hint al purple titanium (just my dream )
Greetings Florian
Greetings Florian
#2107
Originally Posted by John Doucakis
Some pics of my Cyclone.
I think they fit nicely as a wallpaper too in case you like them.
#2108
Need some help??? I just put my Cyclone on order through my LHS and I need to find out what parts I need to get to build a front diff. I know you guys have figured it out and have probably posted it but if you could tell me again this would be a big help.... Thanks!!!
#2109
Originally Posted by ngo8
heheeheh you should make a dutch orange like the soccer team hehhehe i dont think these are new version just what people are asking for purple versions.
That updated middle block looks very familiar to the MSX .
And Rc - Zombies i am not really feeling the color it is not the hpi violet purple, i personally don't like it.
Greetings Florian
#2111
Tech Legend
Trader Rating: 51 (100%+)
#2112
#2113
Can someone be kind enough to post the part # needed to make another rear diff?
#2114
HPI Parts
A150 Thrust Balls 2mm
A157 Carbide Diff Balls (3/32) 2.4mm
A165 Diff Spring 6x7x1.5mm Black
A166 Diff Thrust Washer 2.2x6mm
A495 39t Ball Diff Pulley
B020 Ball Bearing 5x8x2.5mm
Z203 Washer M3x6
Z857 Aluminum Washer 5x8x1mm
72105 Diff Ring D Cut Type
73522 Diff Screw And Heavy Duty Nut
Hot Bodies Parts
HB70715 Diff Cup Joint Set
#2115
73522-----diff nut m2x6mm
70725-----center pulley(16t)this pulley is for replacing the center one way
72105------diff ring d-cut type
A-495------39t ball differential pulley
Z857--------alluminum spacer 5x81.0mm you dont have to use this use 2 bearings instead
70715a-70715b dif cup joint set
A-165-diff spring
A-162diff screw
hpi/hotbodies b021 5x8x2.5mm bearing use 2
A-150 diff ball 2.0mm for thrust bearing
A-157 diff ball 2.4mm
A-166 diff thrust washer
i think this is it let me know how it goes .
