Old 12-06-2005, 03:13 AM   #2056
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Originally Posted by Hollowman
Evildriver : i had the same problem with the set screw, i don't wich you mean but my screw driver was to wide and didn't go al the way in the black spur gear holder so just buy hudy or do with the allen wrench .
I already did that.. and I used the Allen Wrench that came from the Kit but the set screw keep on loosen out.. so now like My previous Post used the Blue locetite, to make sure it will not loosen out.. if this doesn't work I'll just have to use the green locetite. .
Tom :
4: the kit come with 3 sets of sway bars.. copper 1.2 mm silver 1.4mm and black 1.6mm, the fronts and the rear ones are diffrents.. the rear one is slightly longer.
6: 64 pitch and 100t Xenon spur, the biggest one I've seen been used is 108 64 pitch spur.. it said on Hara's Set up sheets. and a couple page behind someone said that for 48 pitch 80 spur is the biggest you can put on.
8: same as pro4
Hope this help..
I'm just emphasizing what the other guys have told you..and adding some details.
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 12-06-2005, 06:21 AM   #2057
Trader Rating: 24 (100%+)
I heard next year that the HB is coming out with an all purple ano kit with a spool included in the kit. Time to buy another!
JoeyE is offline   Reply With Quote
Old 12-06-2005, 08:46 AM   #2058
rc-zombies's Avatar
my purple version is coming before Christmas..
Old 12-06-2005, 05:00 PM   #2059
Tom
Tom's Avatar
Thx all for the help
Tom is offline   Reply With Quote
Old 12-06-2005, 06:22 PM   #2060
ngo8's Avatar
Send a message via ICQ to ngo8
good i just sold my pro4 and i want another car
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-07-2005, 12:02 AM   #2061
Hara used RP tire setup sheet
but Surikarn last final no chance , so use back sorex
Hot Bodies Cyclone-hara_-.jpg   Hot Bodies Cyclone-miura_-.jpg   Hot Bodies Cyclone-surikarn_-.jpg
HKRCMODEL is offline   Reply With Quote
Old 12-07-2005, 03:25 AM   #2062
Mitropoulos Jim's Avatar
Originally Posted by EvilDriver
Well I Raced my cyclone last weekend and I'm having a bit of trouble with the car.. first.. the set screw on the center pulley keep on backing out.. so I just put a blue locktide on the set screw hoping it wouldn't backed out next time I raced.. I noticed that the Center pulley is a little bit wobbley, is this normal? As there's a .5mm gap on each side, do I need to spread out the pulley so the gap will be in the middle or just leave it alone ?
another thing.. I notice the diff pulley for the from is diffrents from the back ones.. does it means if you accidentally switched the diff pulley you will get get an underdrive or overdrive effects ? lastly.. do anyone have a setup for a bumpy asphalt rubber tires ?
thanks in advance..
Hi EvilDriver!
With any kind of locktite the set screw will not back out again.Don't try to use green locktite,you will harm the set screw when you try to take it off.
I haven't faced that problem,and I didn't use very strong locktite.
You can use shims between the center pulleys and the bearings on each side,but allow the axle to have a little play.
It is impossible to switch the diff pulleys,because the difference is the hole in the middle.
For a bumpy track, just add some kick-up to the front,and a little softer shock oil,and you will be fine.
Jim
Mitropoulos Jim is offline   Reply With Quote
Old 12-07-2005, 06:54 AM   #2063
Just got word today from RCS, Thailand(where Surikarn practice). There is going to be two versions. One will come in all purple. Something like a HARA Limited Edition and the other in blue trim. You know, SURIKARN color. I think my next one will be blue!
Due out sometime in January.
Old 12-07-2005, 08:56 AM   #2064
rcmaniax's Avatar
we just made a new part for the cyclone..... USD11.35 - swiss quality
rcmaniax is offline   Reply With Quote
Old 12-07-2005, 09:02 AM   #2065
ChrisP's Avatar
Send a message via Yahoo to ChrisP
And when was the original Cyclone released???? Sounds like HB might be blowing away both Xray AND Tamiya's release schedules with that....
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 12-07-2005, 09:04 AM   #2066
Thumbs up
Hello guys, I've got this new part from rc Maniax, it looks very beautiful on the cyclone! Go for it!
B.Thomaes
benoitrdv is offline   Reply With Quote
Old 12-07-2005, 10:01 AM   #2067
tc3 racer sc's Avatar
cant read it need to be bigger
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 12-07-2005, 10:08 AM   #2068
rc-zombies's Avatar
Save the image and print as jull page jpeg.
Old 12-07-2005, 05:25 PM   #2069
pucho's Avatar
Send a message via AIM to pucho
I think I figured out the difference between the two HD driveshaft Part #s, I bought some Rears because the fronts weren’t available. Well I have been using a diff and there was no problem, yesterday I go to put in the one way and SOB the ball end won't fit into the one-way cup. I tried the aluminum ones and they effectively have a smaller end on them. I'm waiting on some fronts to confirm.
pucho is offline   Reply With Quote
Old 12-07-2005, 06:09 PM   #2070
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Thanks for the heads up. Lucky I order both front and rears. Hopefully I get them before Friday. By the way, Champ sells a pair for 1057 YEN
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
