Old 11-28-2005, 07:29 AM   #1981
Originally Posted by omoser
from PrecisionRC:
Shooters Bulkheads
they're also cheaper than the standard ones
regards
Ok thanks for the info.
Hugo is offline   Reply With Quote
Old 11-28-2005, 07:40 AM   #1982
Buyer Beware
why are replacement parts are hard to find?
HELLOkitty is offline   Reply With Quote
Old 11-28-2005, 08:00 AM   #1983
Hi all :
long time no see !
i'm b4 said new bulkhead today arrive ,
stronger than Shxxxxx
& cheaper price
http://shopping.rcmodel.hk/product_i...9f51c30076e9e3
HKRCMODEL is offline   Reply With Quote
Old 11-28-2005, 12:13 PM   #1984
maybe, I'll report if the Shooters bend as easily as the stock ones.
regards
omoser is offline   Reply With Quote
Old 11-28-2005, 01:15 PM   #1985
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Ran the car twice in our local indoor track and all I can say is WOW Just wish there's a big meet soon as I will definitely be in the running.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-28-2005, 01:50 PM   #1986
ngo8's Avatar
Send a message via ICQ to ngo8
the car is definitly fast on carpet its ureal i love mine
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-28-2005, 03:21 PM   #1987
Are you running rubbers on carpet? If so can you post your setup please.
Rick Draper is offline   Reply With Quote
Old 11-28-2005, 06:15 PM   #1988
danjoy25's Avatar
Does anyone have the part # of the steel driveshaft for the front and which shop sells them?
Old 11-28-2005, 10:48 PM   #1989
nordheim's Avatar
Can anyone post a good setup for high traction asphalt with a stock motor? I have been running the box setup the last few days and the tailend seems very loose. I also have the spool in it.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 11-28-2005, 11:05 PM   #1990
ngo8's Avatar
no foams if you a carpet rubber there is haras setup from vegas i used his foam set up but i tweaked it to my likeing but there a good start .
Old 11-29-2005, 02:05 AM   #1991
Tried that the car was terrible. That one is for a urba high grip track which the track i use aint.
Old 11-29-2005, 03:49 AM   #1992
pucho's Avatar
Send a message via AIM to pucho
I started with the stock set up and made somw changes, I am using ASS gold spring on the front, ASS silvers in the rear, added 1/2deg of camger in the rear, added droop to the front (from 7 to 5 on the gauge) added 1mm under rear upper ball end, and used the 1.2 mm swaybar. that seamed to do it for me. I am running with diffs and a looked center pully. The next thing I and going to try is rasing the front pivot blocks and playing around with the roll center maybe eaven some anti dive. Hope this helps.
Luis
pucho is offline   Reply With Quote
Old 11-29-2005, 05:35 AM   #1993
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
The car is pretty much there or there abouts on rubbers indoors Rick,i ran kit setup all but the front shock mounting and shock setup,3 hole pistons,60w oil.Lean front shocks in 1 hole to give abit more mid corner and that was it,Im running Ride TSX Acord with a Yoke GW 3.1 wing. Car feals pretty good.
Your best bet is starting with kit anmd finding somthing YOU can drive,whats fast for the likes of Moore and Hara mite be shocking for you.
L8rs!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 11-29-2005, 02:56 PM   #1994
pro4_chris's Avatar
i ran the car on carpet with foams and used hara's set up apart from 1 spring rate less front and back and the car is awsome
pro4_chris is offline   Reply With Quote
Old 11-29-2005, 03:36 PM   #1995
danjoy25's Avatar
Any setup tips using foams on asphalt track (high traction) using front & centre oneways?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
