Old 09-06-2014, 03:49 PM   #19741
cheerwhiner's Avatar
thanks for the help all, I actually found another box of spares that I had forgotten. So with the spares I had already, and electronics, I was able to build a second Cyclone today
the assembled car is 'run wherever I want to' car with a Mamba Max 5700kv; the bottom car still needs the shocks rebuilt and will be raced in carpet USGT
*shimmed both spur layshafts to reduce play as suggested by CraigMBA
cheerwhiner is offline   Reply With Quote
Old 09-08-2014, 07:07 PM   #19742
Originally Posted by cheerwhiner View Post
So looking for advice. Put the car back together to run some USGT. I still have a lot of spare parts so why not
Anyway, see attached photo. What I am experiencing I need to check is 'normal.' The 2 bearings pictured are 'sliding' and this is causing about 3mm of play left/right on the spur gear shaft. The mesh of the gears stays OK but not sure if this is going to be an issue.
Is this because the bearings are worn out? Or is this normal? It has been a while since I've run the car.
Thanks.......
Part of the problem is that you have the C shaped middle deck upside down in your car. The side with the wider notch that is over the bearing by the motor in your picture should be on the other side of the car. If you have the instruction manual refer to page 10, top left of the page shows the correct orientation of the upper and middle decks (narrow notch of the middle deck should be on the motor side of the car). Keep the drive gears as close together as possible so the belts line up then put just one shim between the motor side drive gear and the bearing, which will now fit nicely under the narrow notch of the middle deck. When done correctly, you end up with a little side to side play and both bearings securely held down by the middle deck.
If you have questions I'll take a picture of my Cyclone TC and send it to you.
John Wallace2 is offline   Reply With Quote
Old 09-23-2014, 06:51 AM   #19743
ospower's Avatar
Default hi
need a plastic chassis urgent!!!!
anyone for sale????
HB racing team driver,Team Orion, cyclone tc,D817,Triton rc,byrons Fuel,LFR,Dialedrc,Boca bearings,HRP, "I Always Say The Truth Even When I Lie".love my Puerto Rico, Island of Enchantment
ospower is offline   Reply With Quote
Old 09-24-2014, 12:58 AM   #19744
hanzo3's Avatar
Trader Rating: 55 (100%+)
I have a bunch of cyclone aluminum suspension mounts for sale. PM for more info.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 09-24-2014, 07:40 PM   #19745
ospower's Avatar
Default hi
I can't pm you, send pics and price to [email protected] please thanks.
Old 09-25-2014, 10:06 AM   #19746
ospower's Avatar
Default hi
im looking for cyclone s parts to buy or parts car and the standard setup for the car thanks.
Old 09-26-2014, 02:43 AM   #19747
Trader Rating: 20 (100%+)
petit RC has many setup sheets. Just look for one that has characteristics of your track. As for parts, many of the suspension parts carry over to the Cyclone TC, TCX, TCXX. Amain and Stormer still carry parts for the car
goots is offline   Reply With Quote
Old 09-26-2014, 01:21 PM   #19748
ospower's Avatar
thanks a lot!!!!
Old 10-22-2014, 08:54 PM   #19749
ospower's Avatar
still looking for a parts lot for a cyclone s at a good price!!!
Old 11-08-2014, 09:55 PM   #19750
ospower's Avatar
Old 07-01-2015, 05:30 PM   #19751
I have a bunch of cyclone s parts and possibly a car. Pm me what you need.
EditOne is offline   Reply With Quote
Old 07-26-2015, 06:00 PM   #19752
SpidarX's Avatar
What are good replacement drive shafts for a cyclone tc that are stronger than the stock aluminum ones?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 07-27-2015, 10:58 AM   #19753
RC MARKET's Avatar
some spare parts instock
http://rcmarket.com.hk/index.php?cPath=51_98_118_349
RC MARKET is offline   Reply With Quote
Old 07-27-2015, 12:59 PM   #19754
If you want the stock parts I have plenty but for hot bodies parts I use wheelspin.com in the UK. I'm using the HOT BODIES DCJ V2 units for the TCXX in my Cyclone TC. The SPEC R DCJ units for Tamiya cars also work.
Old 09-23-2015, 02:17 PM   #19755
I got out of racing back in 07, looking at getting back in now. I went through quite a few cars and by far the cyclone was my favorite. Looks like cyclone parts are too hard to find now to race. Due to budget I need a used car that isn't too pricey. Any newer hot bodies cars I might like that are still parts supported? Any other cars I might look at?
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
