Old 01-14-2014, 07:54 AM   #19726
Originally Posted by CraigMBA View Post
I either got them from A main, or from TQ Racing in Chino.
Thanks, Ill have to go and check the sites out. You selling your Cyclone?
HD Racer is offline   Reply With Quote
Old 01-14-2014, 12:30 PM   #19727
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Naw. I have three! My VTA car, my Surikan edition, and a Andy Moore edition that was actually signed by Andy that has never been out of the box.
I'm going to Shelf Queen the Surikan car, and use the VTA car as a "Rent A Ride" if somebody wants to check out the class.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-14-2014, 12:41 PM   #19728
Awesome! Couldn't hurt to ask. Keep on Racing!
Old 01-25-2014, 05:12 PM   #19729
SpidarX's Avatar
Default Need Help
I need some help figuring out a problem with my Cyclone TC. Under power the car pulls to one side, however, once I let off the power, it pulls to the other side. Any ideas what might be causing such odd behavior?
I've swapped the tires to the other side to see what effect this would have, but the problem still persists.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 01-28-2014, 07:55 PM   #19730
This is probably my last post here. I had a great time with my Cyclones, but since I seem to be Mr. All Things Tamiya these days, it's time to turn the page. I'm posting because I haven't built a new VTA car yet, and I wanted to post that I'd had success putting TCX gear diffs in with only two part numbers necessary to complete the task. Here they are installed:
I used the 2mm shims (one on each side). Here are the PNs you need to convert over. ICRC, total cost was like $32.
Good luck guys!
Did you put a gear diff in the rear too? BTW what weight diff oils did you use? I found both PNs on A Main
John Wallace2 is offline   Reply With Quote
Old 01-28-2014, 10:00 PM   #19731
CraigMBA's Avatar
I put putty in mine for the front, so when I wack something or someone, it won't break the uber fragile c hubs or the POM outdrive lie when I had a spool.
I have a ball diff in the rear.
Old 01-29-2014, 02:31 PM   #19732
Never had too much problem with the 2N1 spool ( 1 way without the pins a spool with the pins) that came with my TC. I'm going to put the gear diff in the rear of my second TC and keep the spool in the front just because the two spare ball diffs I have are crap even after rebuilding, and besides I want to try something new. Let you know how it turns out.
Old 09-04-2014, 04:48 AM   #19733
cheerwhiner's Avatar
So looking for advice. Put the car back together to run some USGT. I still have a lot of spare parts so why not
Anyway, see attached photo. What I am experiencing I need to check is 'normal.' The 2 bearings pictured are 'sliding' and this is causing about 3mm of play left/right on the spur gear shaft. The mesh of the gears stays OK but not sure if this is going to be an issue.
Is this because the bearings are worn out? Or is this normal? It has been a while since I've run the car.
Thanks.......
cheerwhiner is offline   Reply With Quote
Old 09-04-2014, 04:48 AM   #19734
delete double post
Old 09-04-2014, 09:15 AM   #19735
CraigMBA's Avatar
I shimmed mine.
Old 09-04-2014, 10:34 AM   #19736
Shim in the 'open' areas I have the arrows pointing to, correct? That is what I am thinking
Old 09-06-2014, 05:46 AM   #19737
next question- will these work on the cyclone without issue?
Hot Bodies Front Spindle V2 Set
http://www3.towerhobbies.com/cgi-bin...?&I=LXDMPD&P=7
I've found the original part for our car is discontinued
Old 09-06-2014, 10:46 AM   #19738
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
yea, they should since the TCX and TCXX all use the same suspension arms, knuckles, hubs
might have to space/shim your steering rods so they are still fairly parallel like on the original arms - but shouldn't be too bad
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 09-06-2014, 11:02 AM   #19739
Trader Rating: 21 (100%+)
I have a BMI conversion for the cyclone. Any use or value to this kit?
Sir Loin is offline   Reply With Quote
Old 09-06-2014, 12:30 PM   #19740
k_bojar's Avatar
i'm sure there is somewhere - especially for places that still run foam TC... for rubber TC, don't think there's much of a need for it anymore
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
