Old 03-08-2013, 09:39 AM   #19711
Carlos's Avatar
Default Exotek HBX
Originally Posted by Bikerbob View Post
What I liked about the Exotek chassis is that it turns the car into a modern TC.
One of the biggest drawbacks of buying a used car is you get something 4-5 years old, that was not DESIGNED for lipo and Brushless.. It my have been upgraded, or modded, etc. Weight put on.. things adjusted to work.
The HBX makes it a lipo car -with all the TC bits on it. Many people I talk to about getting something that I can still be competitive with the pack of drivers (I am not elite by any shake) is that getting something old you have to MAKE WORK puts you behind the eightball right away.
HB being a HPI company now.. I am more confident that I will be able to get parts.
I run TC3 for VTA - if I get a good a setup / favorable layout track, I am middle pack with the car.. but because of the lack of adjustment that car has - hard to beat really well setup cars even if I might be a bit better driver.
thats my thinking anyway.
I am actually in the process of converting a Cyclone S to the HBX chassis. I purchased the roller from another member on here and the chassis is on its way. My next step is to buy all of the Aluminum and Carbon Fiber pieces ( bulkheads, shock towers, etc..).
I do have some questions regarding the drive train however, the S has dogbones that I would like to upgrade to dcjs/cvds. Also, I would like to swap out the ball diffs for spool/one-way and gear diffs. Are the TCX/TCXX drive train parts compatible?
Thanks in advance!
Carlos Marcano a.k.a Sponge Bob
R.M.I. Racing
Xray NT-1
Spec-R R1
Carlos is offline   Reply With Quote
Old 09-28-2013, 10:12 PM   #19712
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default Cyclone parts for sale.
I have a box of cyclone parts for sale. pm me for any needs. This is still a great car for vta and usgt.
Jaz406 is offline   Reply With Quote
Old 10-02-2013, 06:19 AM   #19713
jgGonzo's Avatar
Trader Rating: 27 (100%+)
Default Brushless Motor Mount 61329
Does anyone have an extra or know where I can get a brushless motor mount for my TC?? Part number 61329. Any help would be great, even if the part is across the pond.............Thanks...............jim
RS4 MT/RS4/Pro2/Pro4/Pro5/D413/RS4 Nitro MT/RS4 Micro/RS4 3 18ss/RS4 Rally/Blitz
Blitz ESE/E.Firestorm/Super E.RS4/MT2 Slash Killer/Mini Recon/HB Cyclone/Midnight Pumpkin
Blitzer Beetle/Revo3.3/Slash/Slash 4x4 Platinum/Mini E.Revo/EXO Terra/SCX10/Twin Hammers
Pro2SC/DEX210/DEST210R/DESC210R/Tekno 410.3/Yeti XL/Kyosho Beetle/Team C TS4
Scorpion XXL/RC8T3e
jgGonzo is offline   Reply With Quote
Old 10-02-2013, 07:40 AM   #19714
Airwave's Avatar
Just to be clear, you don't need the Brushless support to mount a brushless motor. This item only raises the central axle by 2mm so you can use bigger spur gears. You will need that if you are running a 4.5T because you will need a 1:9.5 ratio and a huge spur gear.
If you are running 21.5, 17.5, 13.5 or 10.5 the standard support is fine.
Airwave is offline   Reply With Quote
Old 10-02-2013, 07:04 PM   #19715
jgGonzo's Avatar
I was running 17.5 and I needed to grind out the inside of the mount where the can fits so I could slide the motor back far enough to get the pinion I needed to work......along with making the elongated motor bolt holes longer to get them in.
Scorpion XXL/RC8T3e
Old 10-03-2013, 02:19 PM   #19716
Airwave's Avatar
I mean, as fine as it could be... lol
You would have the same problem with BL motor support... It only raises the axle by 2mm... that's all...
Old 10-03-2013, 04:02 PM   #19717
Trader Rating: 77 (100%+)
You're using far too large of a spur gear.
edit: my mistake, if you are grinding to move the motor CLOSER to the spur, then you need a LARGER spur gear (and a larger pinion too, to get back to the same FDR you had before)
I race at:
SpeedWorld Raceway
Roseville / Sacramento, California
VTA, 1/10 nitro, touring, USGT, F1, and more!
www.speedworldraceway.com
slashdriver is offline   Reply With Quote
Old 10-03-2013, 04:03 PM   #19718
CL
CL's Avatar
Trader Rating: 32 (100%+)
You just need bigger spur and pinion gears.
More racing and less typing!
CL is offline   Reply With Quote
Old 11-18-2013, 01:16 PM   #19719
jgGonzo's Avatar
Default Ball Diff Needed
Anyone know where I can get a 67720 ball diff for a decent price??
Thanks.........
Scorpion XXL/RC8T3e
Old 11-19-2013, 05:40 PM   #19720
Thanks.........
I have one New in package. 40 bucks shipped. I paid 45 not including tax and shipping
DOTMAN is offline   Reply With Quote
Old 11-20-2013, 06:02 AM   #19721
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thanks.........
shoot me a PM - more of a reminder then anything else - and I can look tonight. I might have one (or 2) of them I can give you a deal on
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-13-2014, 11:13 PM   #19722
CraigMBA's Avatar
Trader Rating: 22 (100%+)
This is probably my last post here. I had a great time with my Cyclones, but since I seem to be Mr. All Things Tamiya these days, it's time to turn the page. I'm posting because I haven't built a new VTA car yet, and I wanted to post that I'd had success putting TCX gear diffs in with only two part numbers necessary to complete the task. Here they are installed:
I used the 2mm shims (one on each side). Here are the PNs you need to convert over. ICRC, total cost was like $32.
Good luck guys!
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-13-2014, 11:13 PM   #19723
CraigMBA's Avatar
Good luck guys!
Old 01-14-2014, 07:35 AM   #19724
Good luck guys!
I put one in my car as well and so far so good! I used a bunch of small shims since I didn't have the 2mm shims. Where did you get the shims from? Good luck with the new ride (even if it is not HB) LOL
HD Racer is offline   Reply With Quote
Old 01-14-2014, 07:49 AM   #19725
CraigMBA's Avatar
I either got them from A main, or from TQ Racing in Chino.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
