Old 08-20-2012, 10:11 AM   #19666
Wow just picked up a used cyclone on here and after reading 75% of this thread, I'm worried it was a mistake. Seems parts are hard to find now days..
I plan to drift it and feel drifting is alot easier on the drivetrain but still, if i need something it's going to be a tough find for lots of the parts.. Thank god it cam with spare parts and is already set of for drifting.. Still lookforward to adding my .02 to this thread and maybe helping figure out parts that work..
RcJunky76 is offline   Reply With Quote
Old 08-20-2012, 10:24 AM   #19667
ozvena's Avatar
I have tons of parts for sale if you need some.
ozvena is offline   Reply With Quote
Old 08-20-2012, 03:02 PM   #19668
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
no, you'll be fine for parts...most of the suspension parts are the same on the TC, TCX and TCXX...they just go on runs, where parts go a little dry for a couple of months...belts are still available - just might have to go to ebay vs the LHS
as long as you don't crack a chassis, you'll be fine...
you're right, drifting is easier on the chassis - so you'll be fine
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-20-2012, 04:28 PM   #19669
After looking around more I'm not as worried about it but think I will pick up a few extras for those dry times just in case. But will wait till I get it on friday to check it all out and decide on things that look worn to me..
Old 08-21-2012, 08:22 AM   #19670
k_bojar's Avatar
actually, if you're looking for 2 spare chassis (and even some aluminum front knuckles and rear hubs), shoot me a PM...I found 2 chassis from my cyclones that I replaced with a exotek chassis...one even has a weighted plate for lipo/electronics balancing
Old 09-12-2012, 06:32 AM   #19671
Hey guys, I'm looking for some new spur gears and wondering if anyone knows where I can get some. Right now I'm running 109/29 gearing and my FDR is high so would like to get it down so I dont over rev my motor. Whats the biggest pinion you can go with a high count spur? All I find is 96+ spurs but not sure what pinion whould fit to get my FDR down. Thanks for any help..
Old 09-12-2012, 11:29 AM   #19672
k_bojar's Avatar
are you running 17.5 or mod? if you're running 17.5, you'll want a smaller spur and larger pinion to get a FDR is the mid-4's
if you drop to, for example, 88-95t spurs, you'll get a much better range of gearings..
I know on mine, I've had 88/55 - and i still think i had room for another tooth or too
Old 09-12-2012, 04:11 PM   #19673
I'm running or soon to be running a 3200Kv/SV2 for drifting. Been collecting everything for a few weeks now and am now needing to get my FDR down. I'm hearing a FDR of 6 is a good spot to be but having trouble finding Spurs other then the 100+ range. If you have ran a 88/55 do you think I will be able to fit a 95/34? Even at that I still need to find some spurs.. Know of any that work or where I can find some?
Old 09-13-2012, 07:19 AM   #19674
k_bojar's Avatar
probably would fit. don't really now - never ran anything with that high of a FDR in the car
where are you looking for spurs? I know kimborough will work, as well as many others...I've use kimborough, xenon, 3racing in mine without any issues
you can find them at towerhobbies, speedtechrc, tq rc racing - pretty much all over
Old 09-13-2012, 11:33 AM   #19675
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I have a non brushless mount on mine. Using a 96 spur, the smallest pinion I could make mesh is a 39. I have 83/54 on the other car, but it has the brushless mount.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 09-13-2012, 04:04 PM   #19676
That what I was looking for, spurs from other companies that worked. I didn't know what ones did or didn't and couldn't find any smaller once made by hotbodies.
I ended up ordering an 88T spur (Kmborough) and a 50T-55T pinion. I hope these will give me a good mesh to atleast get started.. FDR will end up at 3.5-3.8 depending what pinion I run, that is if they fit..
Old 10-17-2012, 08:12 PM   #19677
Can any one tell me what 64p spur and pinion would fit the Cyclone TC to achieve a FDR of 5.7, and provide some adjustment either way?
rfree02 is offline   Reply With Quote
Old 10-26-2012, 06:31 PM   #19678
hotbodies's Avatar
Trader Rating: 4 (83%+)
i am running a cyclone and thinking of changing the ball diff to gear diff. does anyone know if the newer tcxx is compatible with it. or other brand cars gear diff would be able to fit into the cyclone.
hotbodies is offline   Reply With Quote
Old 10-27-2012, 07:41 AM   #19679
CraigMBA's Avatar
The TCX unit will fit, but it is too narrow. You must shim it out to the bulkheads, but it will work.
Old 10-27-2012, 08:51 AM   #19680
hotbodies's Avatar
Hi craig. Thanks. This is the info i needed.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
