Old 05-24-2011, 03:38 AM   #19591
Auskenny's Avatar
Originally Posted by warnos View Post
I used a wider bearing on one side to take up the slop.. another guy at the track put two bearings in one side and that seems to do the trick too.. also I only put the gear diff in the rear.. not the front.. I like to have the brakes a spool gives.. if ur running a gear in the front.. I would put some really thick oil in there.. like 100K-300K
A couple of pages back u put a pick of ur gear diff in the car.. there is not that much slop.. only a couple of mm's..some shimms would work ok.. just not wide ones.. thin like the hot bodies diff shims..
warnos have u got a pic of the gear diff in your tc?
also what size was the wider bearing you used?
cheers shane
Hot bodies cyclone TCX, Tamiya F104 pro,FF03 pro ,M05 mini ,Futaba 4pks
***PENRITH ELECTRIC MONDAY NIGHT RACING***
Auskenny is offline   Reply With Quote
Old 06-11-2011, 11:40 AM   #19592
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Default blue cyclone parts
Anybody need a brushless motor mount set - #61360 blue and pivot block set - 61394 blue. pm me.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 06-12-2011, 05:38 PM   #19593
Default parts
i am looking for cyclone tc parts does anyone know a shop that carries them? part # 61333 bone blade 61717 arm and 71712 hinge pin
capt waffles
sobiski racer is offline   Reply With Quote
Old 06-12-2011, 09:45 PM   #19594
SpeedySST's Avatar
I found some non Hot Bodies drive pin clips that work pretty well
http://cgi.ebay.com/NEW-CNC-Derlin-d...item4a9b9ff26b
SpeedySST is offline   Reply With Quote
Old 06-20-2011, 02:56 AM   #19595
idbdoug's Avatar
Trader Rating: 33 (100%+)
Just picked up a Cyclone TC for VTA Class. Looking for a FDR around 4.0. Does anybody have recommended gearing to reach this ratio with a spur/pinion that will fit onto the Cyclone TC???
thanks
idbdoug
idbdoug is offline   Reply With Quote
Old 06-20-2011, 03:07 AM   #19596
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
thanks
idbdoug
Try gearchart.com and you can print a whole list for you.
But in the meantime, a 90t spur with a 48t pinion (4.06ish) or a 90/49 (3.98) is as close as you get
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-20-2011, 03:55 AM   #19597
Trader Rating: 48 (93%+)
what springs is every one using on this car? i know tamiya springs fit does AE springs also fit?
tcb22185 is online now   Reply With Quote
Old 06-20-2011, 06:39 AM   #19598
flat4's Avatar
Send a message via Yahoo to flat4
AE springs will fit, I have my HB cyclone roller with plenty of NIB for sale, $115 or first reasonable offer. PM me if any one is entrested
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 07-07-2011, 07:32 PM   #19599
RICO's Avatar
I just picked up a used Cyclone (S I think) and the one thing I noticed it that the spur gear was only 81 teeth. I tried to put an 84 teeth that came with it and the gears are rubbing on the bottom cassis. Can anyone help me. This is my first on road car. oh yeah the cassis is plastic so pretty sure it is some form of Cyclone S.
Marc - GPMRA Vice President
HB D8T
HB D8E
HB Cyclone S
RICO is offline   Reply With Quote
Old 07-07-2011, 08:59 PM   #19600
Sounds like 48 pitch gears. Run 64 pitch. I've got mine geared 58/82 and the spur is pretty far from the bottom of the chassis.
markw is offline   Reply With Quote
Old 07-08-2011, 07:24 AM   #19601
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Sorry to hijack (?) the thread, but I sold my cyclone, and I have a shell: LTC-R that is brand new and custom painted, It was mounted as a display body and never run. May be of use to someone here. PM if interested, thanks.
Custom Painted shell for HB Cyclone,LTC-R
nf_ekt is offline   Reply With Quote
Old 07-08-2011, 07:36 AM   #19602
RICO's Avatar
Thanks. I will give that a try.
HB D8T
HB D8E
HB Cyclone S
Old 07-08-2011, 08:02 AM   #19603
idbdoug's Avatar
Is this Pro4 part:HPI MIP CVD Alum Purple RS4 Pro 4 (2) HPI80827
the same as #61088 MIP CVDS CYCLONE WORLD CHAMP EDITION PURPLE???
thanks
idbdoug
Old 07-08-2011, 08:14 AM   #19604
Korey Harbke's Avatar
The MIP CVDs that came with the pro 4 are 46mm. They might bottom out in the front diff or spool since the car was designed to be used with 44mm. I don't know for sure because I have never tried this.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-08-2011, 09:03 AM   #19605
if u need axle parts shoot me a PM i got LOADS OF THEM!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
