Old 05-13-2011, 09:59 PM   #19576
waggaclint's Avatar
Originally Posted by RaceAce701 View Post
futaba 9951 works great and wont hang off the chassis
http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML
Thanks i thought i might need a low profile one, Ive got a Hitec HS-5645MG spare but when mounted its very close to the belt..
I was looking at a Savox SC-1251MG..
waggaclint is offline   Reply With Quote
Old 05-14-2011, 06:06 AM   #19577
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
the savox is also a good choice - the same size of the futaba, but 2/3 the price
I just replaced both of my 9551's with the savox servos
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-14-2011, 06:18 AM   #19578
GasGod's Avatar
Anyone know if any other diffs fit the cyclone?kinda tire'd of tryin ta find HB parts.I hear the tc5 diffs fit--true? thanx in advance.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 05-14-2011, 11:26 AM   #19579
Trader Rating: 42 (98%+)
Send a message via Yahoo to dirt_oval
the 1251s are great. I love low pros, Especially with my exotek chassis!
Damon English
Team Tree Top--Associated--LRP--Trinity/Revtech--Spektrum
Help the environment, and support your local hobby shop!
http://mikeshobbyshop.com
freshRC.blogspot.com
dirt_oval is offline   Reply With Quote
Old 05-15-2011, 06:29 AM   #19580
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by RC MARKET View Post
My Cyclone TC Gear Diff
What gear diff is it please
Craig W is offline   Reply With Quote
Old 05-15-2011, 06:32 AM   #19581
Craig W's Avatar
will top racing gear diff fit or a yok 1
Old 05-15-2011, 05:15 PM   #19582
warnos's Avatar
Default Spec R
Hi mate just get a Spec R gear diff for the TCX.. have one in the rear of my Cyclone and its works fine.. use it with 2000 oil and its perfect.. just get some automotive silicone sealant to use with it to make sure it doesn't leak.. also u will need to use a couple of shims on the diff to make sure there is not too much movement..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 05-15-2011, 07:23 PM   #19583
k_bojar's Avatar
Cheers
did you end up changing the bulkhead bearings?? I ran my TC with dual TCX diffs, and didn't like how slow the car felt...i threw around the idea of change out the bearings since the diff doesn't run on the bearings once everything is all shimed out
Old 05-16-2011, 04:11 PM   #19584
warnos's Avatar
I used a wider bearing on one side to take up the slop.. another guy at the track put two bearings in one side and that seems to do the trick too.. also I only put the gear diff in the rear.. not the front.. I like to have the brakes a spool gives.. if ur running a gear in the front.. I would put some really thick oil in there.. like 100K-300K
A couple of pages back u put a pick of ur gear diff in the car.. there is not that much slop.. only a couple of mm's..some shimms would work ok.. just not wide ones.. thin like the hot bodies diff shims..
Old 05-16-2011, 04:25 PM   #19585
k_bojar's Avatar
yes i did, but after looking at the car and running it...the outdrives were not actually supported by the bearings - so the car had a ton of drag
I need to measue the diameter of the outdrives then try to hunt down some bearings..
it will work and has great potiential - but you need to replace the bulkhead bearings with smaller inner diameter bearings to REALLY make it work
Old 05-17-2011, 12:30 PM   #19586
nf_ekt's Avatar
Trader Rating: 113 (100%+)
If you have the dimensions and/or part # for ordering the bearings, please post them. Would like to do this without having to use a bunch of shims.
nf_ekt is offline   Reply With Quote
Old 05-17-2011, 12:55 PM   #19587
What can I do to discontinue my on power push?
Damon English
Old 05-17-2011, 01:01 PM   #19588
nf_ekt's Avatar
Sounds like too much power to the rear wheels, front lifting too high, maybe adjust your front droop.
XXX main chassis set up book is a good reference.
Old 05-20-2011, 10:45 AM   #19589
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi All,
New titanium quick change shock posts for the Cyclone are here!
Get info here;
http://www41.instantestore.net/merch...hock-posts.cfm
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-20-2011, 12:08 PM   #19590
Flanged bearing + plastic bearing holders from tc with few shims will do the trick. You have to rearange centar pulleys.
tomislav is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
