Old 01-03-2011, 01:07 AM   #19516
mangoman's Avatar
Originally Posted by Firefox View Post
Beings as this thread has over 19,000 replies, I'll ask here.
Is there any parts off the newer Cyclones that will work on the Cyclone S ?
Any recommended upgrades to the S version ?
thanks
Depending on the class, a spool upfront.
But if you throw in a spool or one-way you will need to upgrade the center pulleys and lay shaft. The plastic pulleys will strip very easily.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-16-2011, 09:33 PM   #19517
DOUGHBOY's Avatar
Send a message via AIM to DOUGHBOY Send a message via Yahoo to DOUGHBOY
Talking LOOKING FOR SOME HELP
I RECENTLY BOUGHT TWO CYCLONE TC'S FROM A GUY AND THE FIRST DAY I WENT RACING I BROKE THE SERVO SAVE TUBE WHICH IS FINE SO I ORDERED ANOTHER ONE BUT WHEN I WENT TO SWITCH IT OUT THE GUY GLUED THE INNER TUBE INTO IT.. SO I AM HOPING THAT SOME ONE HAS JUST THE SMALL INNER TUBE THEY WILL PART WITH I REALLY JUST DONT HAVE THE EXTRA MONEY LATING TO SPEND ON EXTRA PARTS I REALLY DONT NEED.. I DONT NEED THE SERVO SAVER OR THE SPACERS ALL I NEED IS THAT SMALL INNER TUBE.. I ATTACHED A PIC BELOW SO EVERYONE KNOWS WHAT I AM TALKING ABOUT SINCE I PROBABLY DIDNT DESCRIBE EVERYTHING PROPERLY AND I AM SURE I DIDNT CALL THE PARTS BY THERE CORRECT NAME..
$$$$$$$$$$$$$$$$$$$$$$$....DOUGHS GRAFIX....$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
custom vinyl paint mask, sign work and r/c body painting..
RC4LESS, FUTABA FASST, THUNDER POWER LIPO'S, R.I.P. MOTORSPORTS WGT
DOUGHBOY is offline   Reply With Quote
Old 01-17-2011, 12:42 AM   #19518
TURN OFF CAPS LOCK
markrobinson is offline   Reply With Quote
Old 01-17-2011, 07:31 AM   #19519
mangoman's Avatar
Errr good luck getting free parts....
Not sure what you are talking about but if you had problems getting the shims and bearings off its more than likely because you bent the shaft as opposed to someone gluing them to it.
www.smaracing.org
Old 01-17-2011, 11:08 AM   #19520
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Default steering
try getting the Cyclone S verion of the part...
the bar is silver in color and is about a third of the price.
go to Hot Bodies web site and pull manual for Cyclone S...for part number....then find who has it in stock.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 01-18-2011, 07:56 PM   #19521
DOUGHBOY's Avatar
im not looking for free parts. i have no problem paying for it. i was just looking to buy just that tube instead of how you have to buy it off line with all the other stuff that i dont need..
olhipster- i will try to give your way a shot..
Old 01-20-2011, 01:57 PM   #19522
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default gear diff
I am looking to replace the spool in my Cyclone with a spec R gear diff. Which option is best. Yokomo style or Tamiya? Belts and rear diff pullies need replaced but anything else. front axels?
I have an Original cyclone with 18t center pullies now.
Jaz406 is offline   Reply With Quote
Old 01-24-2011, 06:24 PM   #19523
Slash4x4mike's Avatar
Hello I have a Cyclone s for sale if anybody is interested!
#66403 - CYCLONE S KIT DRIFT! RTR!! A LOT OF EXTRAS
Slash4x4mike is offline   Reply With Quote
Old 02-15-2011, 12:06 PM   #19524
gear diff solutions?
Old 02-17-2011, 05:30 AM   #19525
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
funny, i was going to post the same thing...well kinda
was going to ask if there's a gear diff made for these cyclone chassis
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-19-2011, 04:21 PM   #19526
Trader Rating: 75 (100%+)
Default widen a cyclone?
what would be the best way to widen a cyclone to around 200mm? I'm going to use it in VTA and the body I chose needs the wheels to be further pushed out to fit properly in the wheel wells.
slashdriver is offline   Reply With Quote
Old 02-19-2011, 05:13 PM   #19527
On my cyclone with '69 camaro body i'm actually too wide by using some modified hex adapters from some old hpi 2.2 rims I had kicking around. The width is spot on for the older camaro body.
cwazyduck is offline   Reply With Quote
Old 02-24-2011, 07:39 AM   #19528
HPI makes a hex adapter set including aluminium spacers in .5 and 1mm.
Old 02-24-2011, 11:04 AM   #19529
k_bojar's Avatar
what body are you trying to run? most, if not all, of the HPI bodies are made to run with the 31mm +6mm offset rears...with the 26mm +0mm offset fronts...
i know the pegasus bodies are wider then the HPI's...but nothing that should require extensive widening
Old 03-03-2011, 02:41 PM   #19530
k_bojar's Avatar
hey cyclone guys - guess what???
the tcx gear diff will fit the cyclone chassis you do need some spacers/shims to move everything in the appropriate spot (ie, bearings), but the gear diff fits
Hot Bodies Cyclone-tcx_geardiff_cyclonetc-001.jpg   Hot Bodies Cyclone-tcx_geardiff_cyclonetc-002.jpg
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
