Hot Bodies Cyclone
Its also interesting to note that Paul L has been running a wider front hinge pin spacing on his xray (started a couple of years ago).
http://www.rctech.net/forum/8278344-post649.html
http://www.rctech.net/forum/8299072-post671.html
Cheers
Cheers
Hey guys any low and medium bite track setups running the exotek chassis?
HB Cyclone TC owners, I have some parts for sale:
http://www.rctech.net/forum/r-c-item...0-shipped.html
Cheers
http://www.rctech.net/forum/6894343-post18335.html
http://www.rctech.net/forum/6896188-post18356.html
Cyclone s upgrades
Beings as this thread has over 19,000 replies, I'll ask here.
Is there any parts off the newer Cyclones that will work on the Cyclone S ?
Any recommended upgrades to the S version ?
thanks
thanks
Yeah the Exotek chassis have the holes pre drilled for the different front FR blocks...
Everything from the Cyclone WCE, Hara, TC will cross over to the Cyclone S... so the S can be fully upgraded to a TC but not a TCX.. I think the S works fine in standard form in the 17.5 and lower classes.. maybe change the front diff to a spool and upgrade the centre pulleys when they break to the Cyclone WCE 16T ones.. as the TC 18T ones will need a belt change.. get a full set of HPI spings.. thats it... until u want some purple on the car. Sway bar might help too..
Cheers
Does the exotek chassis have the holes for the adjustable front track width?
Cheers
But if you throw in a spool or one-way you will need to upgrade the center pulleys and lay shaft. The plastic pulleys will strip very easily.
LOOKING FOR SOME HELP
I RECENTLY BOUGHT TWO CYCLONE TC'S FROM A GUY AND THE FIRST DAY I WENT RACING I BROKE THE SERVO SAVE TUBE WHICH IS FINE SO I ORDERED ANOTHER ONE BUT WHEN I WENT TO SWITCH IT OUT THE GUY GLUED THE INNER TUBE INTO IT.. SO I AM HOPING THAT SOME ONE HAS JUST THE SMALL INNER TUBE THEY WILL PART WITH I REALLY JUST DONT HAVE THE EXTRA MONEY LATING TO SPEND ON EXTRA PARTS I REALLY DONT NEED.. I DONT NEED THE SERVO SAVER OR THE SPACERS ALL I NEED IS THAT SMALL INNER TUBE.. I ATTACHED A PIC BELOW SO EVERYONE KNOWS WHAT I AM TALKING ABOUT SINCE I PROBABLY DIDNT DESCRIBE EVERYTHING PROPERLY AND I AM SURE I DIDNT CALL THE PARTS BY THERE CORRECT NAME..
TURN OFF CAPS LOCK
Errr good luck getting free parts....
Not sure what you are talking about but if you had problems getting the shims and bearings off its more than likely because you bent the shaft as opposed to someone gluing them to it.
Trader Rating: 102 (100%+)
steering
try getting the Cyclone S verion of the part...
the bar is silver in color and is about a third of the price.
go to Hot Bodies web site and pull manual for Cyclone S...for part number....then find who has it in stock.
im not looking for free parts. i have no problem paying for it. i was just looking to buy just that tube instead of how you have to buy it off line with all the other stuff that i dont need..
olhipster- i will try to give your way a shot..
gear diff
I am looking to replace the spool in my Cyclone with a spec R gear diff. Which option is best. Yokomo style or Tamiya? Belts and rear diff pullies need replaced but anything else. front axels?
I have an Original cyclone with 18t center pullies now.
