Old 11-01-2010, 11:37 AM   #19486
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by cherry2blost View Post
Don't need to the geometry is identical so can use proper Cyclone ones or just buy the 3Racing Hardened steel Cyclone ones they are the same price as the Sakura ones
Cherry, just an update. Unless I miss read your post, the Sakura 46mm drive shafts are not a direct fit. The pins are too narrow and the bone ends are smaller in diameter. Guess I will keep them around just in case others might need them at our tracks.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 11-01-2010, 12:02 PM   #19487
san.'s Avatar
Cherry or anyone else, I need a direct fit 46mm shaft. Please link part#.
Thx.
Old 11-04-2010, 09:38 AM   #19488
lightfoot's Avatar
Not sure which forum to ask this , but does anyone know a good place to order a large assortment of metric hex screws ? I ordered from "Fast Eddie" years ago but they don't seem to carry screws anymore... sizes that would mostly fit a Cyclone TC... pretty generic... Thanks for any help on this
Love and Peace...
lightfoot is offline   Reply With Quote
Old 11-04-2010, 11:22 AM   #19489
Trader Rating: 65 (100%+)
Send a message via AIM to joey
http://www.mcmaster.com/#screws/=9kow42
has everything you need..
=Joe Wright=
joey is offline   Reply With Quote
Old 11-05-2010, 01:38 PM   #19490
2xs
Default Low grip VTA setup wanted
I need a low grip setup for VTA. Anyone have a setup that they can share?
2xs is offline   Reply With Quote
Old 11-06-2010, 01:06 AM   #19491
cherry2blost's Avatar
Thx.
Sakura are 46mm parts......... haven't tried to fit them coz the kit ones were chocolate, but the hardened ones are still 46mm and are very good
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 11-08-2010, 07:49 PM   #19492
Thumbs up
Hi peeps, Ive been reading some post from earlier on this thread regarding gear diffs in our Cyclone TC cars...
Have anybody been successful as far as what parts/configurations work?
Reason im asking... i am looking at getting a gear diff to try out but unsure what to buy! I dont want to end up spending more than what i should... just want to buy parts once since i would have to order them.
Part number(s) would be ever so helpful if you can provide these for a complete swap over to a gear diff... thanks
RoadRunnerGTO is offline   Reply With Quote
Old 11-18-2010, 02:45 AM   #19493
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Arrow
Hi,
I was just checking Hara's RROC setup from 25 May 2008 and noticed that the rear hub spacers are F=1.0 and R=0.7. Is this a typo ??
Normally, 2.0 & 0.5, 2.0 & 0.7, or 2.0 and 1.0 (depending on slop).
Maybe Hara was using a different hub ??
Cheers
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 11-18-2010, 06:56 AM   #19494
san.'s Avatar
But they are not a direct fit, as I stated before.
Old 11-24-2010, 04:56 PM   #19495
Friends, may I please pass a basic setup for a track with medium grip and slightly irregular?
My car is a CYCLONE S with all the ups possible.
Thx.
RomuloRJ is offline   Reply With Quote
Old 11-26-2010, 06:09 AM   #19496
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Thx.
I would go with the "famed" 1.5mm setup.
1.5mm spacers on all inner camber links in their longest positions.
1.5mm spacer under all roll center blocks.
gold springs in front w/ 40wt oil
silver springs in rear w/ 40wt oil
shocks in middle holes rear
shocks in outer lower holes and middle holes in upper position.
Droop 3mm front and rear
5mm ride height.
It will have a good neutral feeling, If it pushes and will not turn lower the roll center spacers to 1mm and test again.
Good luck!
Jaz406 is offline   Reply With Quote
Old 11-27-2010, 05:32 AM   #19497
HI,
Can any one tell me if the Pro4/Cyclone wishbones have the same geometry as the TC ones?
And what's likely to happen if I change to the TC arms in terms of handling?
cheers,
michael.branth is offline   Reply With Quote
Old 11-27-2010, 10:22 AM   #19498
Originally Posted by michael.branth View Post
HI,
cheers,
hpi 67717 cyclone tc and tcx arms
5 lower shock mounting positions rear -flipable arms
4 lower shock mounting positions front- flipable arms
hpi 73506 cyclone/ cyclone tc. cyclone s arms
2 lower shock mounting locations front-non flipable
3 lower shock mounting positions rear- non flipable
this is just from observation through pictures on A-main hobbies website.
The newer arms give you more choices of lower dampening rates since the holes are offset from one side to another.
Old 11-27-2010, 01:26 PM   #19499
warnos's Avatar
I actually use the Pro 4 high traction arms which are the same as the cyclone s I think.. they dont have the mounting points of the newer ones but I nearly use the same holes all the time anyway. They are also stronger in my opinion especially the graphit ones.. I used the break the TC ones all the time.. Also the h/traction arms seem to flex a little which helps with traction..
Cheers
HI,
cheers,
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 11-28-2010, 03:30 AM   #19500
cheers for the info, for some reason I thought the older arms had a bit of sweep- so shortened the wheel base.
ta
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
