Old 09-30-2010, 09:28 AM   #19441
Bubblehead's Avatar
Originally Posted by benh View Post
With a 74 spur, you need a minimum of a 26 Pinion just to get it to fit, without taking into consideration FDR's.
72 is 28 Pinion
Thanks, I'm trying to set my car for VTA 21.5 brushless seems as if the FDR will be around 3.75 - 5.1.
Bubblehead is offline   Reply With Quote
Old 10-08-2010, 06:34 PM   #19442
eceer's Avatar
Howdy,
I've recently developed a mid corner oversteer problem. Doesn't seem to matter if its a high speed or tight slow speed corners.
The track surface is painted bitumen with medium+ grip depending on weather and conditions.
I have recently changed from Sorex 32's to Muchmore 32's and was all right for a few meetings until in the last two outings welcomed me to oversteer city.
I generally run the HPI blues with AE30 weight oil with 2 hole pistons with no rebound rubbers. It was recommended by a club member to try going to Silvers which helped a little and when I tried the Pinks it was just as bad as the blues.
Any suggestions on things to try and change to eliminate the oversteer would be greatly appreciated.
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 10-08-2010, 06:48 PM   #19443
95lscoupe's Avatar
Run hpi white springs in the front and you blue springs in the back middle shock tower positions.
2 deg camber all around go from there should plant the rear nicely. if to much over steer drop the rear shocks down. under steer drop the front shocks down. lower traction all around drop all the shocks down. there should be a decent split front to rear in shock springs front harder than the rear. just play around in the spring range i gave you. its rare to get a car to handle great with same springs all around.
Matthew Abey
Awesomatix USA/Speedzone USA
LRP/Futaba/Middle River Russian Mafia
Awesomatixusa.com/Speedzoneusa.com
95lscoupe is offline   Reply With Quote
Old 10-09-2010, 12:24 AM   #19444
Originally Posted by eceer View Post
Howdy,
I think, Silver front, blue rear can help you, a litle more oil (35-40), is your rear diff in good conditions? , and see if the knukles move free up-down, the cvd are clean and smooth, and see if when you move up the knukles the blade does not touch with the diff force the movement.
Sorry for my english, i hope help you.
Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 10-12-2010, 06:29 AM   #19445
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Howdy,
I found on my Cyclone that the rear end was too soft and the inside tire was comming off the ground causing the rear end to snap around. I added stiffer springs and corrected the problem. I ran carpet indoors with low to medium grip. 18 or 19 lb. front springs and 45 wt oil. 14 or 15lb. springs in rear with 35-40 wt oil.
Jaz406 is offline   Reply With Quote
Old 10-12-2010, 07:01 AM   #19446
eceer's Avatar
Thanks all for the responses. There is a club meeting this weekend that I'll give the recommendations a go at. I'll let you know how I get on.
☞ Switchmedia ☜
Old 10-12-2010, 10:38 AM   #19447
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
VTA with a 21.5 novak motors is MAX FDR of 4.2 - so you'd be looking at 4.2 to 5.1 for a range
only with the 25.5 motor does the FDR limitation go away -- unless you're track doesn't follow the USVTA rules
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 10-17-2010, 11:11 PM   #19448
where do you guys order parts for cyclone? I usually go to amainhobbies and stormerhobbies but they dont have the carbon graphite c-hubs and pro spec diff cups that Im looking for. please let me know where can I get them asap.
thanks,
albert
bigspider3 is offline   Reply With Quote
Old 10-19-2010, 08:23 PM   #19449
marvinbeaverdip's Avatar
Trader Rating: 36 (100%+)
I just picked up a cyclone TC, and plan to run a 6.5T in it. What FDR would be reasonable for a medium sized tight track? 9? 10?
marvinbeaverdip is offline   Reply With Quote
Old 10-20-2010, 04:33 AM   #19450
Hi guys, I recently got myself a used HB Cyclone (as far as I know, it's just the Cyclone or is it the Cyclone TC?)
It has a 64p spur gear but Ive been told it's much more common to use a 48p gear. Does anybody know where I can get 48p gears for it? I live in Australia BTW, but I can get it from anywhere really. I do most of my RC Shopping from AMain anyway!
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 10-20-2010, 04:48 AM   #19451
cherry2blost's Avatar
thanks,
albert
For C-Hubs and steering knuckles look for 3 Racing Sakura parts, they are a direct fit and even the wishbones and Hingepins fit, although to use the 3Racing hinge pins on cyclone wishbones involves drilling out the OUTER ones to 3mm, not the end of the world as the parts are half the price of Hot Bodies / HPI parts.
Thought it may help those of us who are cash strapped.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 10-20-2010, 06:20 AM   #19452
san.'s Avatar
Trader Rating: 59 (100%+)
Cherry, will the Sakura front 46mm dogbones fit the Cyclone? Concerned about slop from the pins on both ends.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 10-20-2010, 08:01 AM   #19453
Don't need to the geometry is identical so can use proper Cyclone ones or just buy the 3Racing Hardened steel Cyclone ones they are the same price as the Sakura ones
Old 10-20-2010, 06:38 PM   #19454
san.'s Avatar
Thx, Cherry. Just ordered 3 sets.
Old 10-21-2010, 01:51 AM   #19455
Aim to please
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
