Hot Bodies Cyclone
Hara won TITC 2010 and Andy was 4th at this year's EFRA Championships in France.
Does anyone kno where i can get those front axles made just for spools? What part number is it? Thanks yall
Yes those are the ones. Are they worth the money ?
Can anyone tell me where I can get the sway bar set for the TC? Everyone is sold out, is there an alternative as manufacturers go?
I know some people run the Tamiya 416 rear swaybar. It's wider... so slightly more reactive. You just put a ballstud in one of the un-used shock mounting positions on the rear arm.
-Korey
-Korey
Are these the ones you are looking for? Hot Bodies DCJ Drive Shaft Set
Anyone looking for a Cyclone TC with an Exotec chassis and spare parts should pm me or hit the classifieds after Saturday. That will be my last race with mine.
TCX to TC/Exotek
Anyone with a TCX that had a TC Exotek care to tell us the difference in handling..
Some of the guys came to the track with a TCX and it seemed allot stiffer then my Exotek Chassis..
Cheers
Cheers
I did some comparison tests and the result was that the TCX is much more stable, very neutral steering and cornering very consistent, has a very "easy guide" unlike TC which is very much "nervous" when cornering.
TCX chassis is more flexible of Exotek
Is that the Gen 1 or Gen 2 Exotek Chassis?????
I have the 1st gen chassis and wanted the 2nd gen chassis to do the belt flip mod just curious if you thing moving the electronics more inboard on the TC would help it.
agno - how do you like the savox servo??
from the looks of it, its a gen1 exotek chassis...the gen2 has an extra cut-out under the front spool/diff so you can swap the belts
