Old 07-07-2010, 04:16 PM   #19231
Danny-b23's Avatar
Originally Posted by BLUE 2 View Post
Hi
Thanks for that
Do you get any front tyre grooving on the inside with this setup ?
It seems to depend a lot on the tire, doesn't matter what car. Maybe something to do with the insert/tire combos.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-07-2010, 04:55 PM   #19232
Korey Harbke's Avatar
Originally Posted by warnos View Post
On the settings that Korey has used.. what does it do to the rear of the car when you swap the shims in the rear hub / rear arm joint. Does it increase the wheel base and make it less prone to spin from the rear as there is less weight behind the wheel?? or does it do something else.. I usually have the standard settings here which is 2mm at the rear and .7 at the front on the hub joint (don't know what else to call tha area)..
I will give it a go next meet but just want to see what affects on handling I should be looking out for..
When I lengthen the wheel base in the rear at the inner hinge pins, the car is usually a little smoother on entry into the corner, and has a little bit more mid-exit steering. Shortening it does the exact opposite. A little bit better entry steering, and less mid-exit on tighter corners.
When I change wheelbase at the hub, it seems to do act a little bit different. I don't notice much change in how much steering the car has, but I notice more about the forward grip the car has. Shorter... more forward grip. Longer... less forward grip. I think it has something to do with the driveshaft angle more than anything, but honestly I almost never play with these adjustments. I leave it all stock pretty much.
In the front I slam the arms all the way back (all shims in front of the arm) to give the shortest wheelbase from the front. Seems like it gives it a little bit more of an edgy feeling (which I like). If you just want to give the car that nice Caddilac feel... lengthen the front.
You might feel something different. Just give it a shot and see what you think. That is what I have found to work for me.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-07-2010, 04:58 PM   #19233
Originally Posted by RaceAce701 View Post
anyone ???
Usually it effects how stiff the bladder is and how much rebound will result. Foam is obviously softer than the orings, so it shoul dhave a less aggressive effect. When I run the foam, I usually get a little more rebound than if I didnt use it. I feel it also makes the shock pack up a little quicker since the bladder won't be deflecting as much. This forces the oil through the piston, rather than just moving up the shock body if the bladder were to deflect.
Right now, I usually run zero rebound. I drill a small 1mm hole in the shock cap and dont run any foam. Usually when I build shocks they get a tiny bit of rebound, then it goes away after the first run. Seems to work pretty good for me!
-Korey
Old 07-07-2010, 05:04 PM   #19234
RaceAce701's Avatar
Trader Rating: 83 (99%+)
thanks abunch that was exactly was i was looking for
ur the best
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 07-08-2010, 07:12 PM   #19235
stitchy's Avatar
50% off 3racing Cyclone part closeout at Speedtech!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-08-2010, 08:31 PM   #19236
jag88's Avatar
-Korey
Hi Korey, I'm assuming this is for asphault. Would you drill the cap for carpet of average grip ?
Thanks.
jag88 is offline   Reply With Quote
Old 07-11-2010, 07:56 AM   #19237
duggyload's Avatar
Default First time on rubber
Hi could somebody please help me
this is my first time racing on rubber tyres
the tyres we use are spec tyres the problem is the car is very loose at the back on and off power after the first 2 min
here is my setup
thanks
duggyload is offline   Reply With Quote
Old 07-11-2010, 09:41 AM   #19238
AGNO's Avatar
here is my setup
thanks
Unfortunately, the tires Top mediums are not the best for keeping the rear, as they tend to lose grip suddenly, however this is the best setup I found for these tires (Weather temp. 30 C, track small, medium grip)
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-11-2010, 09:59 AM   #19239
duggyload's Avatar
Default Thanks
Thanks agno will give it a try
are the springs hpi
how many pounds are they
i use ae shock oil will the 500 be the same as 50 associated oil
Old 07-11-2010, 10:50 AM   #19240
AGNO's Avatar
are the springs hpi
The springs are HPI, Silver 16.9, 15.3 blue.
50 WT oil is denser than 500 cps, attaching a conversion table
Old 07-11-2010, 11:01 AM   #19241
duggyload's Avatar
Thumbs up Thanks
Thanks for the help agno will try it out and let you know
Old 07-11-2010, 10:28 PM   #19242
RevMaxx's Avatar
Send a message via MSN to RevMaxx
Originally Posted by RevMaxx View Post
my front wheels chatters when steered left or right. i'm using MIP CVD now.
is there a way to correct this other than the DCJ part?
anyone?
RevMaxx is offline   Reply With Quote
Old 07-11-2010, 11:50 PM   #19243
That's something you can't get rid of entirely on any touring car. Especially when the wheels aren't even loaded, it will be much worse when testing on the bench. DCJs even still do it to a certain extent, its just a lot less.
Hope that helps!
-Korey
Old 07-11-2010, 11:50 PM   #19244
CL
CL's Avatar
Trader Rating: 32 (100%+)
anyone?
Run DCJ drive shafts.
http://www.speedtechrc.com/store/ebp...id=472&id=8509
Believe in yourself!
CL is offline   Reply With Quote
Old 07-12-2010, 06:20 AM   #19245
jag88's Avatar
Thanks.
Hi Korey, whats your opinion ? Would you use foam also.
Thanks.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
