Old 06-14-2010, 10:29 PM   #19186
Korey Harbke's Avatar
Nothing should have to be modified on the differential. The main thing I ran into was the spacing on the layshaft. I got another layshaft bearing and used it as a spacer. You'll see what I mean when you actually try to do it. The layshaft is normally slightly offset in the car, so when you move the pulleys to their correct location, there is a ton of slack in the layshaft and bulkheads.
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 06-15-2010, 12:27 AM   #19187
Trader Rating: 14 (100%+)
I was just wondering if anyone drifts their cyclones? just picked up a special Ed and started drifting it and it's pretty damn sturdy
PROJECT 91 is offline   Reply With Quote
Old 06-15-2010, 11:00 AM   #19188
can someone pass me some email setup for the race CYCLONE S, only to take as a basis.
romulaoferraz @ hotmail.com
thx guys.
RomuloRJ is offline   Reply With Quote
Old 06-15-2010, 01:29 PM   #19189
My car serves a dual purpose, Drift / Touring. When drifting I move the spool to the back, use T-drift tires, and replace the gold/silver springs with the orange / yellow titanium drift springs. A few other adjustments and it drifts like a dream. Very stable, long sweeping drifts, quick switchbacks and tight donuts.
killer_tofu is offline   Reply With Quote
Old 06-15-2010, 03:24 PM   #19190
hi,
after searching through many setup pages and these threads i thought id ask direct as im getting quite confused.
im looking for a base asphalt setup for my cyclone TC , just a starting point for a medium grip medium sized track in the coldish british weather :P
im running the following if it helps
13.5t / lipo
sweep 30 exp's
the old style plastic suspension arms (pro 4?)
spool
cut top and rear deck
30wt oil all around
1mm spacers under all suspension blocks
silver roll bar front and copper back
2mm on ackerman
just looking for a good setup as a base point to improve on for a relative beginner that has lots of grip and handles well without being too twitchy as im not that smooth at driving yet
thanks for any help
madwestmo is offline   Reply With Quote
Old 06-15-2010, 04:38 PM   #19191
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Here is my setup that works well on medium grip asphalt tracks.
Front
Spring: HPI Pink
Oil: MM 550cst
Piston: 3 Hole
Susp. Block: 0 Deg
roll center shims: 1.5mm Fr and 1.5mm R
Camber: 2.5 deg (with 3mm shim under camber link)
3mm on Akerman
Shock Position: 3rd hole from bottom on shock tower
Rear
Spring: HPI Silver
Oil: MM 550cst
Piston: 3 Hole
Susp. Block: 3 Deg
Camber: 2.0 deg (with 2mm shim under camber link)
Shock Position: 2nd hole from bottom on shock tower
also i found using 1.4mm roll bar all round made the car more stable through fast corners. maybe something worth trying.
Wheelbases are as per kit setup.
hope that helps
mild seven is offline   Reply With Quote
Old 06-15-2010, 04:58 PM   #19192
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Questions?? Exotek Chassis
Hi
Anyone running a Exotek chassis ?
Did you have to change your setup with the new chassis or was it ok with the setup you had B4 you fitted the chassis ?
Did it offer more grip / corner speed ?
Cars Offroad : TLR 22B- TLR 22B 2.0- TLR 22-4B- TLR 22T- TLR 22SCT- TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 06-15-2010, 05:08 PM   #19193
TheCoolCanFanMan's Avatar
Originally Posted by madwestmo View Post
hi,
13.5t / lipo
sweep 30 exp's
spool
30wt oil all around
2mm on ackerman
thanks for any help
What track dude
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 06-15-2010, 05:32 PM   #19194
Front
Spring: HPI Pink
Oil: MM 550cst
Piston: 3 Hole
Susp. Block: 0 Deg
3mm on Akerman
Rear
Spring: HPI Silver
Oil: MM 550cst
Piston: 3 Hole
Susp. Block: 3 Deg
hope that helps
I run a similar setup at a fairly large outdoor track here in NZ. My changes from above are:
AE 40wt oil in front (close to 550cst I think though_
AE 30wt oil in back
Camber front 2
Camber rear 1
1.4 Roll bar in front
1.2 Roll bar in back
We have some big fast sweeping corners where the roll bars earn their money
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 06-15-2010, 10:16 PM   #19195
hi again,
thanks for the replys
the setups you have mentioned do seem close to mine at the moment , my setup is the same as hara's reedy 2008 setup , but with 1mm shims under suspension blocks and plastic pro 4 arms , cut top and rear deck.
ive been running 30wt schumacher oil all around but have some 35 , 40 and 45wt too , going to change it to 40wt all around
what would i notice different if i change the suspension block shims to 1.5mm all around from 1mm ? surely less grip ?
thanks again
Old 06-15-2010, 10:32 PM   #19196
hi again,
thanks again
Hi madwestmo
It really does depend on a whole lot of other factors,
Examples
Do you run full rebound in your shocks?
Do you have the black foams at the top of the shock bladders?
What droop you running?
I would suggest running 45 and 50 MM oils
Like I said, what rack do you need the setup for plz
Cheers Malc
Old 06-16-2010, 01:58 PM   #19197
always have run no rebound , no foam in shocks , 5mm droop front and 4.5mm at back
oh and the track is a little known outdoor track in lincolnshire
Old 06-17-2010, 02:00 AM   #19198
Auskenny's Avatar
Ive just picked up a TC cyclone to run 17.5t brushless with
im looking for a lipo battery tray and came across this one was wondering if anyone has used or is using it and what do you think of it?
http://www.radshaperc.com/batterytrays.html
cheers shane
Auskenny is offline   Reply With Quote
Old 06-17-2010, 05:14 AM   #19199
mild seven's Avatar
Originally Posted by BLUE 2 View Post
Hi
i didnt really change the setup at all. it just gave the car more traction all round. it gave me an extra lap at the track, best upgrade i have ever bought for sure.
Old 06-17-2010, 05:35 AM   #19200
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
cheers shane
never even seen that one mentioned before i'd say it might work, but you'd have to check fitment under the topdeck - since the cyclone and mi3/mi4 have different styled topdecks...plus you'd have to modify how it attaches to the chassis, since the cyclone don't have holes for battery strap
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
