Old 11-19-2005, 10:05 AM   #1906
Aurra Sing's Avatar
Originally Posted by Geetoo
How did the Pro4 diff possibly fit? Did you place shims along with it?
Used all the parts that make a Pro4 diff, except replace the bevel gear with the Cyclone's one-way gear obviously.
Total, I put about 6-7mm worth of shims. Space it evenly so the outdrives stick out evenly out of both bulkheads. You WILL need Pro4 CVD's/dogbones because the kit ones are too short.
Here is a pic from Nexus Racing as an example
Aurra Sing is offline   Reply With Quote
Old 11-19-2005, 12:51 PM   #1907
rcmaniax's Avatar
Default Spool
We just got our first prototype spool which fits perfect on a HB Cyclone!
The main advantage to other spools is the possibility to use tamiya 42mm steel dogbones OR the original HB aluminium dogbones!
The cup joints are made out of hardened steel the rest will be out of BLACK anodized aluminium.
We just released it for our friends and some team drivers in very small quantities.
If there is big interest maybe we'll produce another batch.... what do you think??
rcmaniax is offline   Reply With Quote
Old 11-19-2005, 02:03 PM   #1908
looks pretty solid, good job!
omoser is offline   Reply With Quote
Old 11-20-2005, 05:11 AM   #1909
more stuff from shooters, motor mount brace
Old 11-20-2005, 10:35 AM   #1910
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
how is this possible? i was under the impression that the drive pin on the tamiya and HB dog bones are different sizes.
looks good tho! make one for the pro4 now!
floodo1 is offline   Reply With Quote
Old 11-20-2005, 10:47 AM   #1911
rcmaniax's Avatar
correct! that's why we made two different types for the cyclone - but the "tamiya dogbone vers." is our favourite!
Old 11-20-2005, 11:54 AM   #1912
tc3 racer sc's Avatar
what ur web site and also i need a front diff so i can run carpet
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 11-20-2005, 11:55 AM   #1913
Default any one got pic where to mount spectrum reciver on cyclone
hey i liker to see some pic where to mount my spectrum and gt7 very tight and speed controller hitting motor mount
Old 11-20-2005, 01:19 PM   #1914
Mitropoulos Jim's Avatar
The spool looks cool,but I would prefere it PURPLE...
Mitropoulos Jim is offline   Reply With Quote
Old 11-20-2005, 05:54 PM   #1915
floodo1's Avatar
ahhhhhh so you just change the outdrives! sometimes the genius is in the simplicity
Old 11-20-2005, 05:55 PM   #1916
floodo1's Avatar
i say they should offer both cuz black is where its at imo
Old 11-20-2005, 06:21 PM   #1917
Trader Rating: 16 (94%+)
has anyone else had a problem with the t1r spool outdrive cups shearing off at the bearing?
domo is offline   Reply With Quote
Old 11-20-2005, 07:38 PM   #1918
Aurra Sing's Avatar
heres a pic of my newly built Cyclone, as set up for carpet/foam racing:
i haven't actually raced it yet, but here are things i've done so far
- pro4 diff/cvd's
- corally RDX springs (perfect fit)
- Jwerks 102t spur
- custom 1.8mm front sway bar
- dremelled suspension block to accommodate higher roll centers
things I want:
- locked center pulley
- thicker chassis if a reputable company makes one (i got word that BMI will not be making one)
- Jwerks ti. screw set
- APS ceramic berings
Old 11-20-2005, 08:00 PM   #1919
ngo8's Avatar
Send a message via ICQ to ngo8
I Run my cyclone today on carpet stock and it was unbeilevable it handles really great lots of turn in steering something the pro4 lacked after every run i put it on the tweek station and the bubble was always in the middle never tweaked or nothing car ran flawless i did run a diff in the front .i dont think the car needs a thicker chassis unless you are running like mod but for stock and 19t the stock chassis works great .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-20-2005, 08:12 PM   #1920
where u got ur diff cause i need one
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
