Old 06-09-2010, 06:07 AM   #19156
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
On the std motor mount, 108 is the absolute max and that's flush if not slightly out the bottom deck.
On the brushless motor mount, I you can get about 116 fitted, I run 115 and that's got enough clearance to be safe
hth
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 06-09-2010, 06:15 AM   #19157
WOW I've been using Xray and the purple HPI 116-64p spur gears for more the 3 years with the optional HB BL motor mount. I'm now using the lipo mount with the 2mm spacer that comes with it.
Yes I had to take a little off the RTP but the 116 will NOT stick out past the bottom of my 2 HB V1,V2 & 1 BMI chassis AT ALL.
Lazer Guy is offline   Reply With Quote
Old 06-09-2010, 06:34 AM   #19158
2xs
I just picked up a Cyclone TC that I plan on running in my clubs 17.5 TC class. I have a Ballistic 17.5/Havoc Pro ESC and a SMC 4200 for power. The track is aprox. 60x36.
What would be a good starting point for FDR? The Ballistic specs call out a FDR of 4. But I think that will be too high for the size of our track.
2xs is offline   Reply With Quote
Old 06-09-2010, 11:58 AM   #19159
Luppi Stefano's Avatar
wow! the 116T?
perfect!
I will put 114 for the maximum safe!
thanks a lot!
Luppi Stefano is offline   Reply With Quote
Old 06-09-2010, 01:48 PM   #19160
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by STLNLST View Post
Just used a header card and no movement. Did you use something with a straight edge?
What is the stock chassis thickness VS the exotek? My exotek chassis might be thinner.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 06-09-2010, 02:00 PM   #19161
RC MARKET's Avatar
116T is five wheel ?
RC MARKET is offline   Reply With Quote
Old 06-09-2010, 02:22 PM   #19162
STLNLST's Avatar
Trader Rating: 19 (100%+)
Exotec is 2mm and stock chassis is 2.5 I'll be getting my Exotek chassis real soon
STLNLST is offline   Reply With Quote
Old 06-09-2010, 02:39 PM   #19163
I am using the (os.3racing.hk/products.php?products_key=2064) 3racing aluminum motor mount
Is that comparable to the (hotbodiesonline.com/products/en/61298.html) Brushless motor mount
or the (hotbodiesonline.com/products/en/61314.html) aluminum motor mount?
I am using the lipo conversion, so I am trying to figure out if I need to use the spacer under the deck mount.
killer_tofu is offline   Reply With Quote
Old 06-10-2010, 05:10 AM   #19164
Trader Rating: 18 (100%+)
I have the 3R motor mount and use an ORCA lipo with no shims needed.
thejo3 is offline   Reply With Quote
Old 06-10-2010, 05:43 AM   #19165
Thats very funny I like using large spur gears because I can use a slightly larger pinion and still get the FDR needed for my mod (3cell 5700KV) @ 24/116.
I was using the 16 tooth lay shaft pulleys, now using the 18's.
I see there will be 20 tooth so for MOD racing the larger spurs will help. The bigger lay shaft pulleys seems to help the life of the belts.
Old 06-10-2010, 12:07 PM   #19166
TheCoolCanFanMan's Avatar
Hi Guys
I notice on the new car TCX, that they didn't take the oppotunity to re-design how to change the way you alter the roll centre, like it can be on the X-Ray 09 for instance, instead of those pesky 1mm 1.5mm etc washers, also the way the ackerman could be altered to, I personally think HB missed a great oppotunity to have a 100% perfect car imo
Cheers Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 06-10-2010, 12:23 PM   #19167
Originally Posted by TheCoolCanFanMan View Post
Hi Guys
Cheers Malc TCCFM
I'll agree on the ackerman... Xray is super easy.
Not so much on the camber link adjustment. With the TCX it's only limited by the thickness of the shim(s) you put in. On the Xray you're at the mercy of the QRC things. If you're using the L1/L2 QRC adjusters the change between the 4 positions is huge. No fine adjustments there unless you want to pay for the original and H1/H2 adjusters (not cheap for what they are, then again nothing Xray is cheap ) Even then the adjustment range is too coarse.
Don't get me wrong I like my T3, but I'm really looking forward to seeing the TCX perform
g26er is offline   Reply With Quote
Old 06-10-2010, 12:45 PM   #19168
Fair enough about the roll centres adjustments like the 09, but maybe they could of made the idea with finner increments, or maybe they could produce shim plates like they did with the Pro 4, which is far easier than single shim replacement.
Cheers Malc TCCFM
Old 06-10-2010, 10:32 PM   #19169
Korey Harbke's Avatar
Bah.. You're just lazy Malc
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-11-2010, 10:35 PM   #19170
hey guys i was wondering do pro 4 swaybars fit the cyclone?
zenkikid is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
