Old 06-04-2010, 04:50 PM   #19141
Originally Posted by cyclone speed View Post
Camper and map pack , hmmm what you guys talking about ?
I think Modern Warfare 2. lol
Kiznasty is offline   Reply With Quote
Old 06-04-2010, 04:53 PM   #19142
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Tony Vega View Post
I played last night. It's cool.
HB all the way!
TCX looks interesting
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-08-2010, 10:07 AM   #19143
Hooligan_'s Avatar
Trader Rating: 17 (100%+)
Default Gearing questions
Hey guys, I have a question about gearing my car. I just picked it up and I'm about ready to run it for the first time. But I have no 64 pitch gears, so I'm about to order some. I just wanna make sure I buy the correct size pinion gears (and maybe a spur gear) so I'm not wasting money. I headed over to HB's site and seen that Barry Baker used a 64p 108 spur and a 37t pinion for a FDR of 6.33 with a 13.5 brushless motor for the KO Grand Prix 2009.
I will be running 13.5 as well so I am guessing I can just buy this spur and pinion and be good to go? I want to be able to play around with a few different size pinion gears incase my motor gets hot while racing. I don't know if 37t is on the high end or low end or in the middle tooth wise.
Would any of you Cyclone TC regulars help me out? What FDR should I be shooting for and what size gears can I get away with in the stock motor mount?
I'm not sure if this info will help or is needed, but we run on a med to high grip asphalt track that varies from technical to flowing depending on how the track directors feel like laying it out that Sunday. It measures 120' x 80' with a full 120' straight.
To anyone who has a answer for me, I really appreciate you taking the time to help me out.
Tony
Dee & Mee Hobbies Topeka, Ks.
Dee & Mee On Road Racing Club
Hooligan_ is offline   Reply With Quote
Old 06-08-2010, 02:26 PM   #19144
Luppi Stefano's Avatar
hi guys
with brushless motor mount, what is the maximum spur gear that can fit?
I want run with 4,5T motor, 108T spur is too small...
thanks!
Luppi Stefano is offline   Reply With Quote
Old 06-08-2010, 02:43 PM   #19145
ShaunMac's Avatar
Tony
On the stock motor mount you can fit 27T - 42T pinions with a 108T spur.
Your gearing is going to be severely affected by your speedo and it's settings. Not to mention, what 13.5 motor you're running. Some like a lot more or a lot less gear than others. Some are geared down in the 5's while others are up in the 8's.
ShaunMac is offline   Reply With Quote
Old 06-08-2010, 02:54 PM   #19146
ShaunMac's Avatar
Originally Posted by Luppi Stefano View Post
hi guys
thanks!
According to HB. 110 is MAX.
Old 06-08-2010, 03:03 PM   #19147
are you sure?
because brushless motor mount is 2mm high, 2+2=4mm for all Diameter of spur gear...108T is 43,3mm, 111T is 44,7mm, but the maximum diameter of spur(43,3 + 4mm) is 47,3mm
or not?
Old 06-08-2010, 04:41 PM   #19148
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Talking
I have an almost brand new Cyclone TC setup, Let me know if any of you are interested. Thanks!
Hot Bodies Cyclone TC, ONLY 5min test run, Tons of extras,ready to race,Speed Passion
Outtacontrol58 is offline   Reply With Quote
Old 06-08-2010, 05:00 PM   #19149
hi guys
thanks!
I'm using a 116 and there looks like room for maybe 118.
Lazer Guy is offline   Reply With Quote
Old 06-08-2010, 05:04 PM   #19150
ShaunMac's Avatar
are you sure?
or not?
I've never used the BL mount myself. Just going on what the HB guys have said before about the BL mount and what the HPI site says. It may have something to do with the fact that the largest HB spur is only 110. Another brands 111, 112 or larger may be able to squeeze in there fine.
Old 06-08-2010, 06:43 PM   #19151
STLNLST's Avatar
Trader Rating: 19 (100%+)
110-111 spur using the brushless motor mount. 112 sticks thru the bottom of the chassis sli
ghtly. You can go slightly larger but it will stick out of the bottom and the other thing to look for is the spur gear hitting the rear FRP/graphite plate.
STLNLST is offline   Reply With Quote
Old 06-08-2010, 07:02 PM   #19152
Owen RaCing's Avatar
My 107 sticks out the bottom on the stock mount. I'm pushing a 9.-- final drive using the 16 tooth pulleys.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 06-08-2010, 07:30 PM   #19153
STLNLST's Avatar
You sure cause that's whats on my car right now and it doesn't stick out.
Old 06-08-2010, 07:37 PM   #19154
It's not a significant amount sticking out, but if you roll something over the chassis cut out, the spur will move.
Old 06-09-2010, 05:29 AM   #19155
STLNLST's Avatar
Just used a header card and no movement. Did you use something with a straight edge?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
