Old 04-29-2010, 05:06 PM   #18991
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Robio View Post
Not too familar with the MM Pro. Does it have any type of timing advance like other brands? If it does, you'll use a lower FDR. Starting around 6.0. If it does'nt, you may try around low 4.0's to start. On mine I ran 4.3 on a medium asphalt track. 88x48 spur/pinion. My IDR is 2.43 as I have the Moorespeed. I believe yours is 2.1? Just some ideas to consider.
Rob.......
His will also be 2.4 if it's the black version unless the pulley's were changed. FDR will all depend on the speedo used. I'm sure someone with MM experience will be along to help him out.
STLNLST is offline   Reply With Quote
Old 04-29-2010, 05:10 PM   #18992
Ah, was'nt sure. I thought when the change to TC version it got the 18t pulleys.
Rob.........
*Restructuring* :)
Robio is offline   Reply With Quote
Old 04-29-2010, 07:12 PM   #18993
I've been using a battery tray weight. I'm going to ditch it. How much weight should I add and what's the front/rear bias?
Thanks, Rob.........
*Restructuring* :)
Old 04-30-2010, 03:58 AM   #18994
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Rob.........
the TC did get the lower internal ratio (18t pulleys) - but none of the 'earlier' cyclones came stock with 18t pulleys, they all have 16t ones
as far as a gearing issue - if you are running an 'advanced timing/turbo/boost' like speedo, you really don't need a super low FDR...A gearing start-point might be something to seriously ask in the MMM thread - in there you get guys running that speedo in everything, and you'd probably get a few more experts on the speedo as well
here, you get some MMM knowledge - but lots of cyclone knowledge
here's a 'for instance' in my cyclone (w/18t pulleys), i would gear the car for a 4.0-ish FDR with my tekin speedo (yes, i know its NOT a MMM), when tekin released v203 with all those extra timing features, i ended up gearing my car high (FDR around 5.5-6) and still had the speedo...so that might be something to consider when i said you may not need to get for a crazy-low FDR
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-30-2010, 02:08 PM   #18995
That's a good call on the MM thread.
Curious. What are the tracks you drive on like? Are you using a battery tray weight?
Rob......
*Restructuring* :)
Old 04-30-2010, 02:40 PM   #18996
k_bojar's Avatar
Rob......
mostly med-to-large parking lot tracks...we do have a real sweet setup in Jackson, NJ (http://www.jacksonrcracing.com/) - nice permanent facility with CURBS
on my 'standard' cyclone i AM running a lipo battery tray - mainly because i never really ran a 5000mah pack
on my cyclone TC, i am using an exotek chassis with the weighted battery retainers
Old 04-30-2010, 04:03 PM   #18997
eceer's Avatar
Rob.......
quick question, how are you managing to get a 88T spur on? I tried putting on a 84T and it bound up on the chassis.
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 04-30-2010, 04:04 PM   #18998
We're also on parking lots for the most part here. I'm fortunate enough to Mike from Exotek as a local racer. I may need to pick up one of his chassis.
May just need to test with weight until then.
Thanks, Rob.......
*Restructuring* :)
Old 04-30-2010, 04:09 PM   #18999
Where are you binding? Are you using 64pitch?
Rob........
*Restructuring* :)
Old 04-30-2010, 06:26 PM   #19000
tha Beast's Avatar
Trader Rating: 100 (99%+)
Originally Posted by tha Beast View Post
hi guys in running on a large asphalt here is a link http://www.mikes-hobbyshop.com/OnRoadTrack.html
anyway im going to run 13.5 on a TC not the older version so im looking to get some tips on gearing can any of you guys help me out with a starting point before i go buy a bunch of gears/pinions. anything will help hopefully some of you pro guys can hook a brotha up thanks in advance
seriously ANYONE?!?!?!?!
tha Beast is offline   Reply With Quote
Old 04-30-2010, 07:42 PM   #19001
ShaunMac's Avatar
Way too many varibles to just throw out a gear ratio for a 13.5. Include some info and someone will probably be able to help you out.
What 13.5?
What motor timing?
What ESC?
What ESC settings?
All these will affect optimum gearing significantly.
ShaunMac is offline   Reply With Quote
Old 04-30-2010, 11:08 PM   #19002
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Default pinion
So a solid pinion gear to start at would be a 26T with the variables being im running a SP17.5 with the new 2.1 pro stock speedo, track is midsize in FL. Let me know thankssss
Outtacontrol58 is offline   Reply With Quote
Old 04-30-2010, 11:45 PM   #19003
i havnt been on here much lately but has any had problems with the pins falling out of there DCJ's? mine are pretty much brand new only a couple of races old had one decent crash when my receiver died and now one of the pins on both sides have fallen out how are they fixed in? and how can i replace them?
T.O.P Photon
www.rcracer.co.nz
subdriftr is offline   Reply With Quote
Old 05-01-2010, 05:22 AM   #19004
I'm on large putfor asphalt.
Tekin RS Pro and Redline 13.5
4.6 FDR
Motor 6 timing
ESC 20 advance
Easy on the turbo
Motor is about 60C after a 5 minute run. Mild climate down here
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 05-01-2010, 11:00 AM   #19005
tha Beast's Avatar
4.6 FDR
Motor 6 timing
ESC 20 advance
Easy on the turbo
thanks what pinion and spur are you running??? im runnung 4.5 FDR but its SLOW ( with a Orion Race Spec ESC )im also gonna be using a Speed Passion GT2.0 ESC i dont have it yet so programing yet also running a Orion Pro Stock 13.5 motor
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
